01-07-2019 11:59 AM - edited 03-08-2019 04:58 PM
I recently bought a Cisco 4221 with two NIM es2-8 modules.
I am going to use this as a Layer 3 switch.
The problem is that I can't send traffic between the two modules.
They act as two separate switches. I want them to act as one switch with 16 ports.
How can i configure that?
Donovan
01-07-2019 12:15 PM
They both can't be combined or stacked to make 16 ports but the ports can communicate with one another.
The LAN switch NIMs have a gigabit connection to the MGF and transparently integrate into the system. Connecting over the MGF enables the NIM to directly communicate with other MGF-enabled modules in the system without involving the router’s forwarding architecture (Figure 2). Throughput for direct module-to-module traffic using the MGF will thereby not be limited by the platform’s performance license levels. Layer 2 switching of packets is thus done at the full Gigabit Ethernet line rate, either local to each LAN switch NIM or when transferring the MGF with multiple MGF-enabled modules installed in the system; module-to-module MGF traffic throughput is limited to 1 Gbps.
see figure-2 in this link:
01-07-2019 12:36 PM
Okay so I need to configure MGF on device (ISR4221).
I cant find a document for this exact module.
Can you post the how to configure it here?
01-07-2019 12:47 PM
Have a look at this guide. It may provide the info you need:
01-07-2019 01:06 PM
Yes i have read that page many times but it still does not explain how to configure it.
