Cisco 4403e Boot Problems
darren849
I am new to this and have ran into some problems. I butilt up my router I was able from the rom> prompt to get my router to boot from SLOT0:xxxxx
Then I did the copy command copy slot0:xxxxxxx bootflash:xxxxxxx
My router starts up fine. I did all my configurations and did my copy run start when I was done. As this is what I do on my 3750s.
My router lost power and rebooted and I lost everything it did not boot up to my last configuration.
How do I save my configurations when I am done ?
How do I get it to boot from that configuration every time?
Leo Laohoo
Command:  wr
Save the config using the "wr" command.  Everytime the router boots, it will always boot the startup-config file found in the NVRAM (command:  dir nvram:).
