Cisco 4500-X netflow issue
mohamed fayz
Hai All,
Kindly check the below alerts i am getting when trying to send netflow performance monitor to Cisco PRIME NCS 1.3
*Dec 29 13:06:37.376: %PERF_MONITOR_RESOURCE-1-RM_SET: RESOURCE EVENT RAISE.
Loss of Confidence in the measurement due to Event Type - clone packet drop, Event description - due to a situation such as a full clone path buffer or rate limiting
Please let me know, if anybody got these type of aerts.
Fayz
mohamed fayz
Hai ,
ANy help on the above query is much appreciated.
Jan  4 10:02:40.400: %PERF_MONITOR_RESOURCE-1-RM_SET: RESOURCE EVENT RAISE.
Hi Fayz,
Had a check on the error message. Although not much aware about the error message the description of the error says some issue with the buffer. Will try finding some mor information.
Error Message    %PERF_MONITOR_RESOURCE-1-RM_SET: RESOURCE EVENT RAISE. Loss of
Confidence in the measurement due to Event Type - %s, Event description - %s
Explanation    A Resource Manager Event is logged when certain resources are not available.
The event type and event description provide the nature of the lack of resources. Measurements reported by Performance Monitoring are not accurate either for entire device, specific monitor or specific flow until the event is cleared.
Recommended Action    No action is required.
Sathvik K V
dan.letkeman
Level 4
Level 4
Any resolution to this problem?
