02-22-2018 04:30 AM - edited 03-08-2019 01:59 PM
Hi Guys,
One of my customer routers is having strange issue, it reboots itself after the clock updates.but no one is taken console that switch. Below is the log
*Feb 16 07:37:55.831: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
*Feb 16 07:37:57.367: %C4K_IOSMODPORTMAN-6-MODULEONLINE: Module 1 (WS-C4900M S/N: JAE15330A9C Hw: 1.8) is online
*Feb 16 07:37:57.367: %C4K_IOSMODPORTMAN-6-MODULEONLINE: Module 2 (WS-X4920-GB-RJ45 S/N: JAE15320HFH Hw: 1.2) is online
*Feb 16 07:37:57.367: %C4K_IOSMODPORTMAN-6-MODULEONLINE: Module 3 (WS-X4920-GB-RJ45 S/N: JAE15320HGN Hw: 1.2) is online
*Feb 16 13:07:57.979 IST: %SYS-6-CLOCKUPDATE: System clock has been updated from 07:37:57 UTC Fri Feb 16 2018 to 13:07:57 IST Fri Feb 16 2018, configured from console by console.
*Feb 16 13:07:58.919 IST: %SYS-5-CONFIG_I: Configured from memory by console
*Feb 16 13:07:59.072 IST: %SYS-5-RESTART: System restarted --
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500e-ENTSERVICESK9-M), Version 15.0(2)SG9, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Thu 25-Sep-14 04:35 by prod_rel_team
*Feb 16 13:07:59.132 IST: %SSH-5-ENABLED: SSH 1.99 has been enabled
*Feb 16 13:07:59.468 IST: %SNMP-5-COLDSTART: SNMP agent on host ABM-HO-CoreSw1 is undergoing a cold start
*Feb 16 13:07:59.504 IST: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 192.168.245.45 Port 514 started - CLI initiated
*Feb 16 13:07:59.504 IST: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 192.168.243.150 Port 514 started - CLI initiated
*Feb 16 13:08:08.973 IST: %EC-5-BUNDLE: Interface Gi3/2 joined port-channel Po6
*Feb 16 13:08:09.017 IST: %EC-5-BUNDLE: Interface Gi2/20 joined port-channel Po6
*Feb 16 13:08:11.073 IST: %C4K_IOSINTF-5-TRANSCEIVERINSERTED: Slot=1 Port=1: Transceiver has been inserted
*Feb 16 13:08:12.061 IST: %C4K_IOSINTF-5-TRANSCEIVERINSERTED: Slot=1 Port=2: Transceiver has been inserted
*Feb 16 13:08:15.061 IST: %EC-5-BUNDLE: Interface TenGigabitEthernet1/1 joined port-channel Port-channel5
*Feb 16 13:08:15.077 IST: %EC-5-BUNDLE: Interface TenGigabitEthernet1/2 joined port-channel Port-channel5
*Feb 16 13:08:16.713 IST: %PKI-4-NOAUTOSAVE: Configuration was modified. Issue "write memory" to save new certificate
*Feb 16 13:08:19.134 IST: %TRACKING-5-STATE: 10 ip sla 10 reachability Up->Down
*Feb 16 13:08:34.135 IST: %TRACKING-5-STATE: 1 ip sla 1 reachability Up->Down
*Feb 16 13:08:36.444 IST: %PIM-5-DRCHG: DR change from neighbor 0.0.0.0 to 172.20.0.5 on interface Vlan41
*Feb 16 13:08:36.444 IST: %PIM-5-DRCHG: DR change from neighbor 0.0.0.0 to 192.168.60.5 on interface Vlan45
*Feb 16 13:08:36.444 IST: %PIM-5-DRCHG: DR change from neighbor 0.0.0.0 to 172.20.80.5 on interface Vlan46
*Feb 16 13:08:36.444 IST: %PIM-5-DRCHG: DR change from neighbor 0.0.0.0 to 142.1.0.48 on interface Vlan100
*Feb 16 13:08:36.444 IST: %PIM-5-DRCHG: DR change from neighbor 0.0.0.0 to 192.168.247.7 on interface Vlan106
*Feb 16 13:08:36.444 IST: %PIM-5-DRCHG: DR change from neighbor 0.0.0.0 to 192.168.245.7 on interface Vlan215
*Feb 16 13:08:36.448 IST: %PIM-5-DRCHG: DR change from neighbor 0.0.0.0 to 192.168.45.9 on interface Vlan320
*Feb 16 13:08:37.568 IST: %PIM-5-NBRCHG: neighbor 192.168.60.13 UP on interface Vlan45
*Feb 16 13:08:37.572 IST: %PIM-5-DRCHG: DR change from neighbor 192.168.60.5 to 192.168.60.13 on interface Vlan45
*Feb 16 13:08:45.221 IST: %HSRP-5-STATECHANGE: Vlan41 Grp 10 state Listen -> Active
*Feb 16 13:08:45.249 IST: %HSRP-5-STATECHANGE: Vlan200 Grp 10 state Listen -> Active
*Feb 16 13:08:45.297 IST: %HSRP-5-STATECHANGE: Vlan47 Grp 20 state Listen -> Active
*Feb 16 13:08:45.317 IST: %HSRP-5-STATECHANGE: Vlan48 Grp 20 state Listen -> Active
*Feb 16 13:08:45.329 IST: %HSRP-5-STATECHANGE: Vlan46 Grp 10 state Listen -> Active
*Feb 16 13:08:45.329 IST: %HSRP-5-STATECHANGE: Vlan100 Grp 10 state Listen -> Active
*Feb 16 13:08:45.457 IST: %HSRP-5-STATECHANGE: Vlan216 Grp 20 state Listen -> Active
*Feb 16 13:08:45.477 IST: %HSRP-5-STATECHANGE: Vlan54 Grp 10 state Listen -> Active
--More-- *Feb 16 13:08:45.709 IST: %HSRP-5-STATECHANGE: Vlan45 Grp 10 state Listen -> Active
*Feb 16 13:08:45.737 IST: %HSRP-5-STATECHANGE: Vlan215 Grp 10 state Listen -> Active
*Feb 16 13:08:45.753 IST: %HSRP-5-STATECHANGE: Vlan310 Grp 10 state Listen -> Active
*Feb 16 13:08:45.825 IST: %HSRP-5-STATECHANGE: Vlan31 Grp 20 state Listen -> Active
*Feb 16 13:08:45.869 IST: %HSRP-5-STATECHANGE: Vlan106 Grp 20 state Listen -> Active
*Feb 16 13:08:45.905 IST: %HSRP-5-STATECHANGE: Vlan6 Grp 10 state Listen -> Active
*Feb 16 13:08:45.917 IST: %HSRP-5-STATECHANGE: Vlan43 Grp 20 state Listen -> Active
*Feb 16 13:08:46.013 IST: %HSRP-5-STATECHANGE: Vlan44 Grp 20 state Listen -> Active
*Feb 16 13:08:48.789 IST: %PIM-5-NBRCHG: neighbor 192.168.60.14 UP on interface Vlan45
*Feb 16 13:08:48.789 IST: %PIM-5-DRCHG: DR change from neighbor 192.168.60.13 to 192.168.60.14 on interface Vlan45
*Feb 16 13:08:56.986 IST: %PIM-5-NBRCHG: neighbor 172.20.0.6 UP on interface Vlan41
*Feb 16 13:08:56.990 IST: %PIM-5-DRCHG: DR change from neighbor 172.20.0.5 to 172.20.0.6 on interface Vlan41
*Feb 16 13:09:05.459 IST: %PIM-5-NBRCHG: neighbor 192.168.245.8 UP on interface Vlan215
*Feb 16 13:09:05.463 IST: %PIM-5-DRCHG: DR change from neighbor 192.168.245.7 to 192.168.245.8 on interface Vlan215
*Feb 16 13:09:07.215 IST: %PIM-5-NBRCHG: neighbor 172.20.80.6 UP on interface Vlan46
*Feb 16 13:09:07.215 IST: %PIM-5-DRCHG: DR change from neighbor 172.20.80.5 to 172.20.80.6 on interface Vlan46
Solved! Go to Solution.
02-23-2018 12:15 AM
02-23-2018 05:51 AM
02-22-2018 04:59 AM
02-22-2018 09:36 PM
Show Version
Image text-base: 0x10000000, data-base: 0x12FE0F00
ROM: 12.2(44r)SG10
Sushi Revision 11, Tatooine Revision 141, Forerunner Revision 1.79
ABM-HO-CoreSw1 uptime is 3 days, 19 hours, 28 minutes
System returned to ROM by abort at PC 0x0
System restarted at 20:47:55 IST Fri Feb 16 2018
System image file is "bootflash:cat4500e-entservicesk9-mz.150-2.SG9.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C4900M (MPC8548) processor (revision 2) with 1048576K bytes of memory.
Processor board ID JAE153306DJ
MPC8548 CPU at 1.33GHz, Cisco Catalyst 4900M
Last reset from System Crash
23 Virtual Ethernet interfaces
40 Gigabit Ethernet interfaces
8 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
02-22-2018 11:26 AM
02-22-2018 09:47 PM
Already tried to get crashinfo but user not enabled crashinfo
02-23-2018 12:15 AM
02-23-2018 05:43 AM
Hi Malone,
kindly provide the solution of this case. if IOS crash mean can i update the IOS ?
02-23-2018 05:51 AM
