Cisco 4948 switch - Vlan routing issues
Aaron Alvarado
I am setting up a new cisco 4948 switch for SAN traffic and so far it is looking very good with exeptions of not being able to ping the SAN default gateway inside the switch. Also I am  not able to hit the switch ouside of the LAN it only works internally.
Vlan229 is assiged for SAN and Vlan224 is for Data and management. I cannnot ping my SAN Gateway inside of the switch 10.23.229.5. This gateway is coming from my core. Secondly, I am not able to reach the switch 10.23.224.21 outside of the LAN. This is the first 4948 deployed in my shop and most likely I am missing something basic. Your expert advised will be greatly apreciated.
Please take a pick at my simple config..
Current configuration : 3835 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
service compress-config
hostname USBLRLS008
boot-start-marker
boot-end-marker
enable password 7 012339255658145E224D
no aaa new-model
ip subnet-zero
ip vrf mgmtVrf
vtp mode transparent
power redundancy-mode redundant
spanning-tree mode pvst
vlan internal allocation policy ascending
vlan 224,229
interface FastEthernet1
ip vrf forwarding mgmtVrf
no ip address
speed auto
duplex auto
interface GigabitEthernet1/1
description Uplink to USBLRELS001
switchport mode trunk
interface GigabitEthernet1/2
description SAN Ports
switchport access vlan 229
switchport mode access
mtu 9198
spanning-tree portfast
interface GigabitEthernet1/3
mtu 9198
interface GigabitEthernet1/4
mtu 9198
interface GigabitEthernet1/5
mtu 9198
interface GigabitEthernet1/6
description iSCSI pambappbck01 nic1
interface GigabitEthernet1/7
description iSCSI pambappbck01 nic2
interface GigabitEthernet1/8
interface GigabitEthernet1/9
interface GigabitEthernet1/10
interface Vlan1
no ip address
interface Vlan224
ip address 10.23.224.21 255.255.255.0
ip http server
control-plane
line con 0
stopbits 1
line vty 0 4
login
length 0
line vty 5
password 7 113926241A41195D072B
login
line vty 6 15
login
end
Aaron
Not sure why your 3560s work without a default gateway or a default route. It may be something to do with proxy arp on your core switch but that is just a guess and i may be completely off track with that suggestion.
I would still try adding the default gateway of 10.23.224.5 to the 4948.
So if you do a "sh ip route" on a 3560 what does it actually show ?
Jon
9 Replies 9
Jon Marshall
Aaron
So this switch is meant to be acting as L2 switch or a L3 switch. From the looks of it, it is L2. If so you need to add a default gateway so you can reach it from remote subnets eg.
ip default-gateway 10.23.224.x
so the actual address is the vlan 224 SVI IP address on the L3 switch that does the inter vlan routing.
Jon
Joh
Correct this is an L2 switch and the L3 routing is comming from my core stack. From my other 3560's the ip default-gateway is not set and it routes correctly, so I thought i did not have to add it. How is it possible that the other switches router without the gateway harcoded?  Thanks
From my core these are the interface vlan gateways:
interface Vlan224
ip address 10.23.224.5 255.255.255.0
ip helper-address 10.23.224.24
interface Vlan229
ip address 10.23.229.5 255.255.255.0
ip route 0.0.0.0 0.0.0.0 10.23.224.1
Aaron
Jon
Jon,
  This is the 3560 I copied the config  for the 4948 and did the sh ip route as shown below and it seems empty but I am able to ping the SAN gateway 10.23.229.5 and it is reacheable from the outside. My two issues remain in the 4948 I am not able to ping the SAN gateway and I cant reach it out of the LAN. I added the defaulr gateway and still no luck out of the LAN.
I attached the copy of 3560 i copied from so
3560 below
sw#sh ip route
Default gateway is not set
Host               Gateway           Last Use    Total Uses  Interface
ICMP redirect cache is empty
sw#ping 10.23.229.5
Sending 5, 100-byte ICMP Echos to 10.23.229.5, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/4/9 ms
sw#ping 10.23.224.5
Sending 5, 100-byte ICMP Echos to 10.23.224.5, timeout is 2 seconds:
sw#
3560 configuration:
Current configuration : 16924 bytes
version 12.2
no service pad
hostname myname
username admin privilege 15
username goc privilege 15 secret 5 $1$GSJY$PT.qhBRRkCV4BQHXz/iez1
aaa new-model
aaa session-id common
system mtu routing 1500
ip subnet-zero
mls qos map cos-dscp 0 8 16 26 32 46 48 56
mls qos srr-queue input bandwidth 90 10
mls qos srr-queue input threshold 1 8 16
mls qos srr-queue input threshold 2 34 66
mls qos srr-queue input buffers 67 33
mls qos srr-queue input cos-map queue 1 threshold 2  1
mls qos srr-queue input cos-map queue 1 threshold 3  0
mls qos srr-queue input cos-map queue 2 threshold 1  2
mls qos srr-queue input cos-map queue 2 threshold 2  4 6 7
mls qos srr-queue input cos-map queue 2 threshold 3  3 5
mls qos srr-queue input dscp-map queue 1 threshold 2  9 10 11 12 13 14 15
mls qos srr-queue input dscp-map queue 1 threshold 3  0 1 2 3 4 5 6 7
mls qos srr-queue input dscp-map queue 1 threshold 3  32
mls qos srr-queue input dscp-map queue 2 threshold 1  16 17 18 19 20 21 22 23
mls qos srr-queue input dscp-map queue 2 threshold 2  33 34 35 36 37 38 39 48
mls qos srr-queue input dscp-map queue 2 threshold 2  49 50 51 52 53 54 55 56
mls qos srr-queue input dscp-map queue 2 threshold 2  57 58 59 60 61 62 63
mls qos srr-queue input dscp-map queue 2 threshold 3  24 25 26 27 28 29 30 31
mls qos srr-queue input dscp-map queue 2 threshold 3  40 41 42 43 44 45 46 47
mls qos srr-queue output cos-map queue 1 threshold 3  5
mls qos srr-queue output cos-map queue 2 threshold 3  3 6 7
mls qos srr-queue output cos-map queue 3 threshold 3  2 4
mls qos srr-queue output cos-map queue 4 threshold 2  1
mls qos srr-queue output cos-map queue 4 threshold 3  0
mls qos srr-queue output dscp-map queue 1 threshold 3  40 41 42 43 44 45 46 47
mls qos srr-queue output dscp-map queue 2 threshold 3  24 25 26 27 28 29 30 31
mls qos srr-queue output dscp-map queue 2 threshold 3  48 49 50 51 52 53 54 55
mls qos srr-queue output dscp-map queue 2 threshold 3  56 57 58 59 60 61 62 63
mls qos srr-queue output dscp-map queue 3 threshold 3  16 17 18 19 20 21 22 23
mls qos srr-queue output dscp-map queue 3 threshold 3  32 33 34 35 36 37 38 39
mls qos srr-queue output dscp-map queue 4 threshold 1  8
mls qos srr-queue output dscp-map queue 4 threshold 2  9 10 11 12 13 14 15
mls qos srr-queue output dscp-map queue 4 threshold 3  0 1 2 3 4 5 6 7
mls qos queue-set output 1 threshold 1 138 138 92 138
mls qos queue-set output 1 threshold 2 138 138 92 400
mls qos queue-set output 1 threshold 3 36 77 100 318
mls qos queue-set output 1 threshold 4 20 50 67 400
mls qos queue-set output 2 threshold 1 149 149 100 149
mls qos queue-set output 2 threshold 2 118 118 100 235
mls qos queue-set output 2 threshold 3 41 68 100 272
mls qos queue-set output 2 threshold 4 42 72 100 242
mls qos queue-set output 1 buffers 10 10 26 54
mls qos queue-set output 2 buffers 16 6 17 61
mls qos
no file verify auto
vlan 224-226,228
interface FastEthernet0/48
description uplink to Core Stack
srr-queue bandwidth share 10 10 60 20
srr-queue bandwidth shape  10  0  0  0
priority-queue out
mls qos trust cos
auto qos voip trust
interface Vlan1
no ip address
interface Vlan224
ip address 10.23.224.4 255.255.255.0
ip classless
ip http server
ip http authentication aaa login-authentication default
ip http authentication aaa exec-authorization default
1646
control-plane
line con 0
line vty 0 4
length 0
line vty 5
line vty 6 15
end
Aaron
From one your earlier posts -
interface Vlan224
interface Vlan229
what is 10.23.224.1 ie. what device  ?
what device(s) are the core switches ?
can you from a 3560 do a traceroute to a remote LAN and post the results
can you from the 4948 do a traceroute to the same remote LAN and post the results
Finally i recently was involved in a thread about a new 4500-X switch that was also only L2 but did not use it's default gateway. The documentation was rather vague as to when you would need a default route instead of a default gateway. The 4948 shares the same IOS as the 4500s (or it did) so, although i am not a big fan of just making changes for changes sake it might be worth trying to replace the default gateway on the 4948 with a default route pointing to the same IP address.
Perhaps try the traceroute from the 4948 first though before you try adding the default route.
Jon
Thanks much and yes this ios is quite different the rest of the 3560's. Below are my asnwers
what is 10.23.224.1 ie. what device ? This IP address is the AT&T routers converted locally into 10.23.224.5
what device(s) are the core switches ? 2x 48port 3750 Stack
Can you from a 3560 do a traceroute to a remote LAN and post the results?
USBLRLS001#ping 10.23.232.253
Sending 5, 100-byte ICMP Echos to 10.23.232.253, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 42/43/50 ms
USBLRLS001#trace
USBLRLS001#traceroute 10.23.232.253
Tracing the route to 10.23.232.253
  1 10.23.224.2 0 msec 0 msec 0 msec This is one of the dual AT&T routers in EIGRP  mode set as default gt 10.23.224.1
  2 32.3.178.133 17 msec 25 msec 17 msec
  3 32.3.174.74 42 msec *  *
USBLRLS008>ping 10.23.232.253
Success rate is 0 percent (0/5)
USBLRLS008>tra
USBLRLS008>traceroute 10.23.232.253
  1  *  *  *
  2  *  *  *
  3  *  *  *
  4  *  *  *
  5  *  *  *
  6  *  *  *
  7  *  *  *
  8  *  *  *
Aaron
Thanks for that. When a host  has no defaut gateway (and a L2 switch acts as a host in respect of it's management interface) it arps out for every destination IP. I suspect there may be some form of proxy arp going on with the AT&T routers.
The 4948, as i mentioned my well not be using it's default gateway ie. it is not acting like a host so can you add the default route and retest.
Jon
I removed the previously hardcoded gateway on the 4948 abd added  the ip router as suggested and I am now both of my problems were resolved. Althought the other switches did not require the iproute or gateway I found out all of these switches have a comand "Ip Classless" which I am not able to set in the 4948. Just a thought maybe it is not related at all.
Thanks for all the help.
Aaron
Thanks for letting me know. The documentation on the 4500/4900 switches in terms of when to use a default gateway vs a default route is, as i say, very vague so it was worth a try and it's good to know it worked.
I don't think it is ip classless as i suspect the 4948 is running that anyway ie. you can't turn it off.
What i would say though is i still think your other switches may be working via proxy arp so bear that in mind if you ever decide you want to turn it off or you replace one of the AT&T routers.
Jon
