Cisco 4948E to Ciena 311v
ALIAOF_
Level 6
Level 6
I am dealing with a point to point gig connection Provider is using a single mode fiber and connecting to a Ciena 311v device (1550).  Then they are handing it off to us as multi mode (850).  This connection was connected to a 2960 switch using a fiber sfp running 12.xxx IOS.  I took this and connected it to a 4948E switch with the same SFP but running 15.xxx IOS I did not get a link light.  When I connect that 4948E to another Cisco device using the same sfp and cable link comes up.  (Note:  This is a Tengig port supports 1Gig and 10 Gig)
I connect it back to 2960 and link comes up.  Next I upgrade the IOS on the 2960 to 15.0 and no link again.  I downgrade the IOS and it works.  Provider is telling me with absolute confidence that the issue is with the Cisco.
Any thoughts, experience with Ciena 311v and connecting it to a Cisco switch particularly 4948E with 1/10gig ports?
robert.horrigan
Level 2
Level 2
Have you tried hte basics?
speed 1000
no speed
speed noneg
dupl auto
dupl full
hw-module uplink select 1gig
I have tried all but the last one, as that command is not available.
