CISCO 5508 Wireless controller WEP-WEP2/PSK issues
mohammadadeel
Hi All,
I am experiencing a strange problem with my WLAN's. I have 2 wlan's running on wireless controller. 1 is used for cisco wireless phones and 2nd is used for Data to access LAN.
now the issue is I tried to change the PSK key 2 days ago to change the authentication key because the key was very old and every one was using it even on mobiles and my internet became very slow therefore I decided to change it.
after 2 days the key automatically resets to the previous key the one I used for the very first time, I do not know what is going on.
any help is highly appreciated.
Muhammad
shh5455
Level 3
Level 3
Did you click the Save Configuration link at the top of the screen after you made the change?  If not and your controller reboots it will revert to the old configuration.
shh5455
Level 3
Level 3
mohammadadeel
Thanks a lot, I believe this is the only thing I missed.
