CISCO 610N + SWITCH 2950 DHCP / MAC TABLE PROBLEM
Didier1966
I have in my test lab a small setup :
Small CISCO 610N ROUTER where I created a MAC TABLE to deliver a kind of FIX IP to my PRINTER and other network products.
When I connect the PRINTER direct to the CISCO WRT 610N , everything works has expected.
But , when I put the SWITCH 2950 in between , the PRINTER receive a IP in the range of the IP pool , but NOT the one I have put in the MAC TABLE.
I do not know if it is important to tell , but the ROUTER and SWITCH are in VLAN 3.
I do not undersand why the PRINTER can receive a IP from the DHCP SERVER of the WRT610N and why it is not the one I put in the table ?
How can I log / debug what is happening ?
Here bellow the complete script :
hostname SWITCH2950
clock timezone gmt+1 1
clock summer-time gmt+2 recurring last Sun Mar 2:00 last Sun Oct 3:00
ip subnet-zero
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
interface FastEthernet0/1
switchport access vlan 2
switchport mode access
interface FastEthernet0/2
switchport access vlan 3
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface Vlan1
no ip address
no ip route-cache
shutdown
interface Vlan3
ip address 192.168.1.250 255.255.255.0
no ip route-cache
no ip http server
line con 0
password 7 06021D3741441B4F5337
login
speed 115200
line vty 0 4
login
transport input telnet
line vty 5 15
password 7 1516191A092039727E13
login
end
Best Regards,
Didier
Didier1966
I just found my mistake.
I forgot to give a DEFAULT GATEWAY 192.168.1.254
When I have add this line it works directly.
Best Regards,
Didier.
