Cisco 6500 redundant supervisor port channel
Sudhir Menon
Hello Friends,
I have a Cisco 6500 series switch with VS-C6509E-S720-10G ,I have two redundant supervisors between two chassis on the LAN with no add-on line cards
I need to know if I can use the redundant supervisor 10 Gb uplinks to form a layer-2 Port channel between the two 6500 switches as i do not want to use want to keep the port idle additionally I need more bandwidth between the two switches for my server farm
Thanks in advance ....
Sudhir
nkarpysh
Yes you can.
Nik
HTH,
Niko
