Cisco 6504-E VSS problem
info00001111111111
Community Member
I have two Cisco 6504-E switches. I configured VSS. Problem is switch 1's NVRAM is erased.
Now switch 2 is working normal, switch one dont have any configuration. how do recover this switch 1,
8 Replies 8
Leo Laohoo
Before we proceed any further, can someone verify if the config-registry is correct?  It should be 0x2102 (recommended) or 0x2101.
in booting process nvram in trouble, messaging should erase nvram, so i erased it
So does the secondary unit have any configuration?
i dont know understand secondary unit,
second switch have configuration and still working
If the switches are in a VSS, it doesn't matter if the primary switch doesn't have a configuration then it's just a matter of configuring the the Virtual Domain and Switch Number and configuring the VSL Ports.
first, I configure Virtual domain and switch number and VSL ports in primary switch then i copy start-up config from switch 2 to primary switches start-up config,
next connect cables and boot switch 1, it is okay???
Why copy the config from switch 2 to switch 1?  VSS takes care of that.
if connect VSS, i think switch 1's config copied to switch 2, so i afraid switch 2's config will delete,
