Cisco 6509 FWSM module
Mihai Ciuraru
Hello guys,
I have a FWSM module that does not boot (it gets rebooted a few times by the diagnostic utility and then it powers off)
I'm able to boot it in maintenance mode and access it by session command and trying to follow "Installing Application Software from the Maintenance Partition" from here link
I got stuck at reaching the FWSM module from VLAN1, it just doesn't respond. Everything seems to be in order:
Interface to the FWSM and native VLAN
#sh firewall switch 1 module 1 state
Firewall module 1:
Switchport: Enabled
Administrative Mode: trunk
Operational Mode: static access
Administrative Trunking Encapsulation: negotiate
Operational Trunking Encapsulation: native
Negotiation of Trunking: Off
Access Mode VLAN: 1 (default)
Trunking Native Mode VLAN: 1 (default)
Trunking VLANs Enabled: 1
Pruning VLANs Enabled: 2-1001
Vlans allowed on trunk: 1
Vlans allowed and active in management domain: 1
Vlans in spanning tree forwarding state and not pruned:
#show firewall switch 1 module 1 traffic
Firewall module 1:
Specified interface is up line protocol is up (connected)
Hardware is EtherChannel, address is f866.f299.f429 (bia f866.f299.f42d)
MTU 1500 bytes, BW 6000000 Kbit, DLY 10 usec,
Full-duplex, 1000Mb/s, media type is unknown
input flow-control is on, output flow-control is on
Members in this channel: Gi1/1/1 Gi1/1/2 Gi1/1/3 Gi1/1/4 Gi1/1/5 Gi1/1/6
Last input never, output never, output hang never
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute output rate 1000 bits/sec, 2 packets/sec
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
6206 packets output, 425491 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
0 lost carrier, 0 no carrier
Configuration on the FWSM maintenance os:
root@localhost.localdomain#show ip
IP address : 10.15.1.3
Subnet Mask : 255.255.255.0
IP Broadcast : 10.15.1.255
DNS Name : localhost.localdomain
Default Gateway : 10.15.1.114
Nameserver(s) :
Maintenace Image version:
root@localhost.localdomain#show version
Maintenance image version: 2.1(4)
mp.2-1-4.bin : Thu Jan 31 21:08:48 GMT 2008 : integ@kplus-build-lx.cisco.com
Line Card Number :WS-SVC-FWM-1
Number of Pentium-class Processors : 1
BIOS Vendor: Phoenix Technologies Ltd.
BIOS Version: 4.0-Rel 6.0.9
Total available memory: 1004 MB
Size of compact flash: 122 MB
Daughter Card Info: Number of DC Processors: 3
Size of DC Processor Memory (per proc): 32 MB
Nothing seems to enable access to the FWSM module. Does any one managed to do this?
While searching for solutions I've found this post: https://supportforums.cisco.com/discussion/10999451/fwsm-boot-failure
so if someone has a working FWSM and is willing to share the CF image please let me know.
Thank you,
M.
0 Replies 0
