Cisco 6509 Input Drops
ralvesso2009
Guys
Good afternoon
I would like to know if somebody can help me solving this problem.
Deal about a datacenter network where there is a switch 6509. In this switch at G2/41 interface is connected a server. My problem is the increase of input drops in this interface. No errors, no high utilization only input drops. I would appreciate for the help. thanks
GigabitEthernet2/41 is up, line protocol is up (connected)
  Hardware is C6k 1000Mb 802.3, address is 001f.6c91.d2b8 (bia 001f.6c91.d2b8)
  Description: W2K3TELHYP03_DADOS
  MTU 1500 bytes, BW 100000 Kbit, DLY 10 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, media type is 10/100/1000BaseT
  input flow-control is off, output flow-control is on
  Clock mode is auto
  Last input never, output 00:00:38, output hang never
  Last clearing of "show interface" counters 00:36:23
  Input queue: 0/2000/5448/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute output rate 98000 bits/sec, 97 packets/sec
     207 packets input, 28756 bytes, 0 no buffer
     Received 30 broadcasts (0 multicasts)
     0 watchdog, 0 multicast, 0 pause input
     634821 packets output, 87498322 bytes, 0 underruns
7 Replies 7
Reza Sharifi
Have a look at this doc for tips on troubleshooting input queue drops.
http://www.cisco.com/en/US/products/hw/routers/ps133/products_tech_note09186a0080094791.shtml#topic2
Thank you Reza. I have already read this doc, but it didn´t help me so much. Actually this doc make me understand cause the drops occurs, but didn´t help me how solve them.
Leo Laohoo
What is the line card is Slot 2?
leolaohoo
Follow the card below
2   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     SAL1209HJAX
francisco_1
Level 7
Level 7
post output for command "show show queueing interface GigabitEthernet2/41"
Follow below all log´s about this interface. I have cleared the counters, however the input and output drops don´t stop.
SWCI6509GAUDI01#sh int gigabitEthernet2/41
  Clock mode is auto
  Last input never, output 00:00:37, output hang never
  Last clearing of "show interface" counters 17:20:50
  Input queue: 0/2000/769/0 (size/max/drops/flushes); Total output drops: 11328956
  5 minute output rate 632000 bits/sec, 516 packets/sec
     43235 packets input, 7599524 bytes, 0 no buffer
     Received 880 broadcasts (0 multicasts)
     39 runts, 0 giants, 0 throttles
     769 input errors, 74 CRC, 0 frame, 0 overrun, 0 ignored
     85054279 packets output, 12959110952 bytes, 0 underruns
SWCI6509GAUDI01#show queueing interface GigabitEthernet2/41
Interface GigabitEthernet2/41 queueing strategy:  Weighted Round-Robin
  QoS is disabled globally
  Port is untrusted
  Extend trust state: not trusted [COS = 0]
  Default COS is 0
    Queueing Mode In Tx direction: mode-cos
    Transmit queues [type = 1p3q8t]:
    Queue Id    Scheduling  Num of thresholds
       01         WRR                 08
       02         WRR                 08
       03         WRR                 08
       04         Priority            01
    WRR bandwidth ratios:  100[queue 1]   0[queue 2]   0[queue 3]
    queue-limit ratios:    100[queue 1]   0[queue 2]   0[queue 3]   0[Pri Queue]
    queue tail-drop-thresholds
    1     100[1] 100[2] 100[3] 100[4] 100[5] 100[6] 100[7] 100[8]
    2     100[1] 100[2] 100[3] 100[4] 100[5] 100[6] 100[7] 100[8]
    3     100[1] 100[2] 100[3] 100[4] 100[5] 100[6] 100[7] 100[8]
    queue random-detect-min-thresholds
    queue random-detect-max-thresholds
    WRED disabled queues:      1  2  3
    queue thresh cos-map
    1     1      0 1 2 3 4 5 6 7
    1     2
    1     3
    1     4
    1     5
    1     6
    1     7
    1     8
    2     1
    2     2
    2     3
    2     4
    2     5
    2     6
    2     7
    2     8
    3     1
    3     2
    3     3
    3     4
    3     5
    3     6
    3     7
    3     8
    4     1
    Queueing Mode In Rx direction: mode-cos
    Receive queues [type = 1q8t]:
       01         WRR                 08
    1     1      0 1 2 3 4 5 6 7
    1     2
    1     3
    1     4
    1     5
    1     6
    1     7
    1     8
  Packets dropped on Transmit:
    BPDU packets:  0
    queue              dropped  [cos-map]
    1                 11328956  [0 1 2 3 4 5 6 7 ]
    2                        0  []
    3                        0  []
    4                        0  []
  Packets dropped on Receive:
    BPDU packets:  0
    1                        0  [0 1 2 3 4 5 6 7 ]
SWCI6509GAUDI01#
This looks like a faulty NIC downstream.
