03-31-2009 08:52 AM - last edited on 03-25-2019 04:05 PM by ciscomoderator
I am having issue with a when i tried to my redanduant sup engine switchover manually it goes in to active but then module 1 goes offline and switch goes to rommon mode and I lost connectiviry to switch
someone has any suggestion on this?
03-31-2009 03:17 PM
Suggestion: Contact Cisco and raise a TAC so you can RMA your card. You may want to attach the TXT file to the case too.
Mar 31 03:41:13.780 EDT: %OIR-SP-3-LC_FAILURE: Module 1 has Major online diagnostic failure, Card will be powered reset
Mar 31 03:41:13.964 EDT: %C6KPWR-SP-4-DISABLED: power to module in slot 1 set off (Fabric channel errors)
03-31-2009 03:22 PM
Thanks I have opened up the TAC case with cisco and we have replaced the one of the sup-module
