Cisco 6509 Sup720 Redundancy Question
ahmad82pkn
Level 3
Level 3
            Hi. i have two SUP 720 in cisco 6500 switch running in IOS mode.  ( Recently upgraded from CAT to OS )
show redundancy is showing different Image set in Image Version ( 12.2 - 18 Active ) and ( 12.2- 33 Standby )
My question is, do i need to be worried about it? Like if failover happen, will it cause any issues? except 2 ,3 minute disconnection because standby SUP is in Cold mode?
Also i have 12.2 (18) IOS in External Disk of both SUP.
its boothflash that is having different IOS on both SUP.
any helpful information will be appreciated.
sh sup-bootflash
-#- --length-- -----date/time------ path
1     80222724 May 19 2010 19:17:50 s72033-ipservicesk9_wan-mz.122-18.SXF17.bin
431800320 bytes available (80224256 bytes used)
sh slavesup-bootflash
1     33554432 Jun 30 2010 09:41:08 sea_console.dat
2     33554432 Jun 30 2010 09:44:00 sea_log.dat
3     73631204 Jun 30 2010 09:44:56 s72033-ipservices_wan-mz.122-33.SXH5.bin
sh redundancy
Redundant System Information :
       Available system uptime = 3 years, 13 weeks, 5 days, 10 hours, 53 minutes
Switchovers system experienced = 2
              Standby failures = 44
        Last switchover reason = active unit removed
                 Hardware Mode = Duplex
    Configured Redundancy Mode = rpr-plus
     Operating Redundancy Mode = rpr
              Maintenance Mode = Disabled
                Communications = Up
Current Processor Information :
               Active Location = slot 5
        Current Software state = ACTIVE
       Uptime in current state = 3 years, 11 weeks, 5 days, 11 hours, 27 minutes
                 Image Version = Cisco Internetwork Operating System Software
IOS (tm) s72033_rp Software (s72033_rp-IPSERVICESK9_WAN-M), Version 12.2(18)SXF17, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by cisco Systems, Inc.
Compiled Fri 25-Sep-09 10:53 by ccai
                          BOOT = disk0:s72033-ipservicesk9_wan-mz.122-18.SXF17.bin,1;
                       BOOTLDR =
        Configuration register = 0x2102
Peer Processor Information :
              Standby Location = slot 6
        Current Software state = STANDBY COLD
       Uptime in current state = 2 years, 49 weeks, 6 days, 3 hours, 40 minutes
                 Image Version = Cisco IOS Software, s72033_rp Software (s72033_rp-IPSERVICES_WAN-M), Version 12.2(33)SXH5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Thu 16-Apr-09 19:18 by prod_rel_team
InayathUlla Sharieff
Ahmad,
Yes you are correct. As the redundancy state of standby module is in STANDBY COLD there would be delay in failover(i.e when the ctive goes down and standby taking over the active role) other than that there is nothing much to worry about.
But still as a best practice it is advisable to have same software version on Active and Standby module .
Inayath
thank you for your response Inayat.
i have few questions which i am unable to find answers for, i hope if you can educate me.
1- How can i confirm my running config is getting saved to secondary SUP NVRAM? or if i can see running config of backup SUP?
2- If my Primary SUP Failes then Secondary sup will load with 12.2 (18)  or   12.2(33) ?
3- same question if there are different IOS in External Flash Disk0(bootflash of MSFC)   and Sup-BootFlash(SP/SUP), then which path is preferred to load IOS?
