Cisco 6513 OSM-2OC48/1DPT-SL issue error
chenyizhen
Hello!
      My module OSM-2OC48/1DPT-SL on Cisco 6513 issue error any here is my message.
   My logging information:
?    Jun  9 11:21:11: %CONST_DIAG-SP-6-HM_MESSAGE: High traffic/CPU util seen on Module 7 [SP=8%,RP=98%,Traffic=0%]
    Jun  9 17:41:15: %SYS-5-CONFIG_I: Configured from console by mars on vty0 (10.101.153.5)
   Jun  9 17:41:22: %PFINIT-SP-5-CONFIG_SYNC: Sync'ing the startup configuration to the standby Router SLOT 9/0:
2y42w: %SYS-2-GETBUF: Bad getbuffer, bytes= 34149 -Process= "SCP Hybrid process", ipl= 0, pid= 40 -Traceback= 600A52E4 600A8400 6035DBD4 60366D44 6035FE94 SLOT 9/0:
2y43w: %SYS-2-GETBUF: Bad getbuffer, bytes= 34149 -Process= "SCP Hybrid process", ipl= 0, pid= 40 -Traceback= 600A52E4 600A8400 6035DBD4 60366D44 6035FE94 SLOT 9/0:
  My module information:
CORE6513#sho module
Mod Ports Card Type                              Model              Serial No.
7    2  Supervisor Engine 720 (Active)        WS-SUP720-BASE    SAD084405**
8    2  Supervisor Engine 720 (Hot)            WS-SUP720-BASE    SAD084405**
9    4  1-port OC-48c SRP SML                  OSM-2OC48/1DPT-SL  JAB0914002D
10  24  CEF720 24 port 1000mb SFP              WS-X6724-SFP      SAL084761**
11  24  CEF720 24 port 1000mb SFP              WS-X6724-SFP      SAL084761**
12  24  CEF720 24 port 1000mb SFP              WS-X6724-SFP      SAL084761**
13  48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX    SAL08445EHU
     My switch version:
   IOS (tm) s72033_rp Software (s72033_rp-PSV-M), Version 12.2(17a)SX4, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
   According to the analysis of the above information is what caused the problem any give me workaround?
2 Accepted Solutions
Derek Zhang
That means there is no side effect to the system when the message pops up and the module still behaves non-disruptive.
Derek Zhang
CSCed49872
Please refer to http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCed49872
The error messages are cosmetic, but no workaround.
Thanks for you reply.
Could You Resolve what "cosmetic"?  the Meaning is not affected ?
