Bookmark
Subscribe
378
Cisco 7206VXR (NPE-G2)unexpected Booting with:Last reset from watchdog reset
krutibasa majhi
7206#show ver
Cisco IOS Software, 7200 Software (C7200P-ADVENTERPRISEK9-M), Version 12.2(33)SRC, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Fri 11-Jan-08 02:44 by prod_rel_team
ROM: System Bootstrap, Version 12.4(12.2r)T, RELEASE SOFTWARE (fc1)
 OR-CUT-7206 uptime is 1 hour, 6 minutes
System restarted at 15:44:22 IST Mon Aug 10 2015
System image file is "disk2:c7200p-adventerprisek9-mz.122-33.SRC.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 7206VXR (NPE-G2) processor (revision A) with 917504K/65536K bytes of memory.
Processor board ID 36579260
MPC7448 CPU at 1666Mhz, Implementation 0, Rev 2.2
6 slot VXR midplane, Version 2.11
PCI bus mb1 (Slots 1, 3 and 5) has a capacity of 600 bandwidth points.
Current configuration on bus mb1 has a total of 250 bandwidth points.
This configuration is within the PCI bus capacity and is supported.
PCI bus mb2 (Slots 2, 4 and 6) has a capacity of 600 bandwidth points.
Current configuration on bus mb2 has a total of 0 bandwidth points.
Please refer to the following document "Cisco 7200 Series Port Adaptor
Hardware Configuration Guidelines" on Cisco.com <http://www.cisco.com>
for c7200 bandwidth points oversubscription and usage guidelines.
1 FastEthernet interface
3 Gigabit Ethernet interfaces
15 Serial interfaces
1 Channelized STM-1 port
2045K bytes of NVRAM.
250880K bytes of ATA PCMCIA card at slot 2 (Sector size 512 bytes).
65536K bytes of Flash internal SIMM (Sector size 512K).
7206#
Automatically the router is reboot and work againg like normal .what will be the problem kindly suggest .
thanks
Mark Malone
Have a look at this may help talks about 7200VXR with npe-ge2
http://www.cisco.com/c/en/us/support/docs/field-notices/620/fn62514.html
And this contains your software version 12.2(33) but on npe-g1
https://tools.cisco.com/bugsearch/bug/CSCed93913/?referring_site=bugquickviewredir
