Cisco 831 DHCP Help
justineyres
Hi, I have a Cisco 831 and I am fairly new with configuring cisco routers. What I have is
Internet>>>Modem>>>Router>>>Switch>>Computers
What I want to do is have the Router hand out IP's through DHCP
Heres my config
Building configuration...
Current configuration : 1306 bytes
version 12.4
no service pad
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
no ip dhcp use vrf connected
ip dhcp pool my_pool
   network 12.168.1.0 255.255.255.0
   default-router 192.168.1.1
   dns-server 24.226.1.93 24.226.10.193 24.226.1.94 24.226.10.194
ip cef
interface Ethernet0
ip nat inside
ip virtual-reassembly
interface Ethernet1
ip address dhcp
ip nat outside
duplex auto
interface Ethernet2
no ip address
shutdown
interface FastEthernet1
duplex auto
speed auto
interface FastEthernet2
duplex auto
speed auto
interface FastEthernet3
duplex auto
speed auto
interface FastEthernet4
duplex auto
speed auto
ip route 0.0.0.0 0.0.0.0 Ethernet1
no ip http server
no ip http secure-server
ip nat inside source list 117 interface Ethernet1 overload
access-list 103 deny   ip 10.0.0.0 0.255.255.255 any log
access-list 103 deny   ip 172.16.0.0 0.15.255.255 any log
access-list 117 permit ip 192.168.1.0 0.0.0.255 any
control-plane
line con 0
no modem enable
speed 115200
line aux 0
line vty 0 4
scheduler max-task-time 5000
end
RonMorrill
kyukim
From your config, you miss one statement and one typo.
one missing is "ip dhcp excluded-address 192.168.1.1"
one typo is "network 12.168.1.0 255.255.255.0". This should be "network 192.168.1.0 255.255.255.0"
you can confirm if you dhcp server is working by "sh ip dhcp pool" or "deb ip dhcp server pacekt or event"
Hope this helps.
KK
