CISCO1841 Vlan Configuration in Packet Tracer
md.sakibnaz
Hello.
I am doing a CISCO 1841 Router simmulation of VLAN on packet tracer.
I can create VLAN Database on the router. But how to insert FE interface on the VLAN?
In the interface FE0/0 there are no option to add switchport.
Router(config-if)#?
  arp          Set arp type (arpa, probe, snap) or timeout
  bandwidth    Set bandwidth informational parameter
  cdp          CDP interface subcommands
  delay        Specify interface throughput delay
  description  Interface specific description
  duplex       Configure duplex operation.
  exit         Exit from interface configuration mode
  ip           Interface Internet Protocol config commands
  ipv6         IPv6 interface subcommands
  mac-address  Manually set interface MAC address
  no           Negate a command or set its defaults
  shutdown     Shutdown the selected interface
  speed        Configure speed operation.
Router(config-if)#
Is there any way to simulate real 1800 series IOS? I have check GNS3, but it did not support 1800 series.
Thanks.
Regards.
Sakibnaz.
Collin Clark
You can't. The physical interfaces on a router are routed ports only.
Hope it helps.
kyukim
You need a SW module, like HWIC-4ESW and HWIC-D-9ESW EtherSwitch Interface Cards.
