Cisco 857 Question
amattas.mattas
Currently I have ATT (SBC) ADSL Service in Michigan and I have this horrible 2-wire modem that I keep having to have replaced.
I am curious if the 857 would be a good replacement for it, and if it would be compatible.
I have a block of static IP's as well so I need 1:1 NAT support alond with traditional NAT, so I can have certain hosts on the LAN have IP addresses such as
10.0.0.0/16
76.236.175.0/29
I'm assuming the unit has a built in DHCP server as well?
JORGE RODRIGUEZ
Level 10
Level 10
Anthony, you should be able to accomplish what you ask with the 857.. please go over these links specially the Q&A for broadband cable questions.. 857 does support all your questions including broadband DSL cable
Also Dynamic Host Control Protocol (DHCP) server/relay/client is supported.
http://www.cisco.com/en/US/products/ps6197/index.html
http://www.cisco.com/en/US/products/hw/routers/ps380/products_data_sheet0900aecd8028a9a9.html
Jorge
Jorge Rodriguez
n_parshina
It does
