Cisco 861 DHCP+ public static IPs + NAT/DNAT. Help.
sebionofrei
I used to use a CentOS self-made server for intranet for my little office, but I bouth few days ago a Cisco 861 router to replace the linux box.
My requirements:
1. I have 2 public IP classes from my ISP. 1 class is limitted to 80mbit upload, the other to 30mbit upload. So I need some sort of DNAT to be able to know exactly which intranet computer uses big internet and which one limitted internet.
2. I need DHCP server and with static IP addresses (one computer must always have the same IP address, etc).. i have my needs for this.
3. Also I need external access to some servers inside (web, ftp, etc)
Settings:
Intranet (dhcp): 10.11.12.x 255.255.255.0)
Public Internet 1: 89.45.204.118 255.255.255.248 (89.45.204.117 as gateway)
Public internet 2: some other IP in same class (let's assume 89.45.204.58/24 for example)
DNS: 89.45.200.1
So far so good, all looks simple and I can achieve this in 2 hours on a centos linux box (correct routes, ip forwarding enabled and few iptables rules for NAT/SNAT/DNAT).
But on this brand new Centos router ... well, i'm not even successful in pinging the outside world, nor the inside world I'm tired of reading the forums, the documentation... i want (at first) a simple scenario: vlan+dhcp, fa4 with 1 public ip address and ACCESS to the real world. I wasn't able to achieve not even that much.
ok, first, here is a copy of the running config:
Building configuration...
Current configuration : 5826 bytes
version 15.1
no service pad
hostname cisco861
boot-start-marker
boot-end-marker
enable secret 5 [removed-from-context]
enable password [removed-from-context]
no aaa new-model
memory-size iomem 10
crypto pki trustpoint TP-self-signed-2459631067
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2459631067
revocation-check none
rsakeypair TP-self-signed-2459631067
crypto pki certificate chain TP-self-signed-2459631067
certificate self-signed 01
      quit
ip source-route
ip dhcp excluded-address 10.11.12.1
ip dhcp excluded-address 10.11.12.251 10.11.12.254
ip dhcp pool cisco861-iasi
import all
network 10.11.12.0 255.255.255.0
domain-name cisco861.iasi
dns-server 10.11.12.1 89.45.200.1
default-router 10.11.12.1
netbios-name-server 10.11.12.2 10.11.12.3
ip dhcp pool testPC
host 10.11.12.111 255.255.255.0
client-identifier 0100.c030.1012.09
client-name testpc-01
ip cef
ip domain name cisco861.iasi
ip name-server 89.45.200.1
license udi pid CISCO861-K9 sn [removed-from-context]
username admin privilege 15 secret 4 [removed-from-context]
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface FastEthernet4
description external$ETH-LAN$
ip address 89.45.204.118 255.255.255.248
ip nat outside
ip virtual-reassembly in
duplex full
speed auto
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$
ip address 10.11.12.1 255.255.255.0
ip nat inside
ip tcp adjust-mss 1452
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 23 interface FastEthernet4 overload
ip route 0.0.0.0 0.0.0.0 89.45.204.117
access-list 23 permit 10.11.12.0 0.0.0.255
dialer-list 1 protocol ip permit
snmp-server community cisco861.iasi RO
line con 0
login local
line aux 0
line vty 0 4
access-class 23 in
privilege level 15
login local
transport input telnet ssh
end
( i found no CODE or QUOTE like on other forums... so i tried to indent the config for you guys)
Also, here are some troubleshooting commands I've used, maybe they can help some of you find out what's wrong
cisco861#show ip interface brief
Interface                  IP-Address      OK? Method Status                Prot
ocol
FastEthernet0              unassigned      YES unset  up                   up
FastEthernet1              unassigned      YES unset  down                  down
FastEthernet2              unassigned      YES unset  down                  down
FastEthernet3              unassigned      YES unset  down                  down
FastEthernet4              89.45.204.118    YES manual up                   up
NVI0                       89.45.204.118    YES unset  up                    up
Vlan1                      10.11.12.1      YES manual up                    up
cisco861#show mac-address-table
Destination Address  Address Type  VLAN  Destination Port
xxxx.xxxx.xxxx          Dynamic       1     FastEthernet0
xxxx.xxxx.xxxx          Self          1     Vlan1
WEIRD: there is no mac-address for the connected FastEthernet 4. How comes? I changed 3 cables. All cables are OK.
cisco861#show ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
       + - replicated route, % - next hop override
Gateway of last resort is 89.45.204.117 to network 0.0.0.0
S*    0.0.0.0/0 [1/0] via 89.45.204.117
      10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C        10.11.12.0/24 is directly connected, Vlan1
L        10.11.12.1/32 is directly connected, Vlan1
      89.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C        89.45.204.117/29 is directly connected, FastEthernet4
L        89.45.204.118/32 is directly connected, FastEthernet4
router#show interfaces FastEthernet 4
FastEthernet4 is up, line protocol is up
  Hardware is PQII_PRO_UEC, address is xxxx.xxxx.xxxx (bia xxxx.xxxx.xxxx)
  Description: external$ETH-LAN$
  Internet address is 89.45.204.118/29
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, 100BaseTX/FX
  Last input 00:02:54, output 00:00:00, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     28 packets input, 3909 bytes
     Received 14 broadcasts (0 IP multicasts)
     0 watchdog
     110 packets output, 25366 bytes, 0 underruns
     0 output errors, 0 collisions, 3 interface resets
     0 unknown protocol drops
     1 lost carrier, 0 no carrier
router#show interfaces vlan 1
Vlan1 is up, line protocol is up
  Hardware is EtherSVI, address is xxxx.xxxx.xxxx (bia xxxx.xxxx.xxxx)
  Description: $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$
  Internet address is 10.11.12.1/24
  Keepalive not supported
  Last input 00:00:06, output never, output hang never
     512 packets input, 53381 bytes, 0 no buffer
     Received 185 broadcasts (0 IP multicasts)
     180 packets output, 13248 bytes, 0 underruns
     0 output errors, 1 interface resets
Also, I have tried other combinations, as following
  1. ip route static inter-vfr
  2. ip default-gateway 89.45.204.117 (ofc combined with no ip routing). I can ping 8.8.8.8 in this scenario, but not other IP addresses. WTF ?!
  3. ip default-network 89.45.204.117 (the gateway) - nothing
  4. ip default-network 89.45.204.118 - bothing
  5. ip route 0.0.0.0 0.0.0.0 FastEthernet 4 (with or without 89.45.204.117 and with or without permanent keyword)
Please have mercy and help me.
P.S. I have also attached the config and the troubleshooting files if it will be easier for you to follow them this way.
Many thanks and God bless you!
hello,
ip nat inside source static 10.11.12.33 89.45.204.120 ( host - to - host)
ip nat inside source static tcp 10.11.12.33 80  89.45.204.120  80 ( port translation  host- to - host)
res
Paul
Please don't forget to rate this post if it has been helpful.
Kind Regards
Paul
6 Replies 6
hello
i am not able to view your config and output from my phone so cannot check.
anyway can
1- ping your nexthop the isps lan interface which is your router wan interface connection
2- have you tried your connection first without applying nat
3- have reloaded the isp modem
res
paul
Kind Regards
Paul
Hi Paul,
1. Yes, i tried pinging the gateway, also the intranet connected computer - no luck
2. tried without the nat rules - no luck
3. there's no ISP modem. Direct fiber optic line comes to my place and the eth cable into a switch, where I plugged this router also. Plugging laptop directly to the line and using the static IP works, but via the router doesn't.
Thanks though.
hello
try spoofing the wan interface with your pc macaddress
res paul
Kind Regards
Paul
Hi Paul,
Indeed clonning the MAC address made pings work, also browsing.
How about DNAT ? I want for example local IP 10.11.12.33 to go out on the net via 89.45.204.120 (and not 89.45.204.118 which will be the default).
Many thanks.
hello,
res
Paul
Kind Regards
Paul
Thanks very much Paul.
One last note. Will ip address x.x.x.x x.x.x.x secondary declare a second class of IPs for the external interface? or there will be other way to do this? Also, would this require 2 ip routes for both gateways ?
Many thanks.
