Cisco 861w and playstation 3.
orelavi123
Hello
I have 861W router.
After it was installed my PS3 can't connect through the wireless to the internet.
The PS3 does not "see" the SSID of the router (its not exist).
The PS3 find my linksys router but not the 861W.
Do you have a solution?
6 Replies 6
riroe
Level 3
Level 3
Thank you for your question.  This community is for Cisco Small Business products and your question is in reference to a Cisco Elite/Classic product.  Please post your question in the Cisco NetPro forums located here:
- Routers ----> Network Infrastructure Forum http://forum.cisco.com/eforum/servlet/NetProf;jsessionid=E0EEC3D9CB4E5165ED16933737822748.SJ3A?page=Network_Infrastructure_discussion
This forum has subject matter experts on Cisco Elite/Classic products that may be able to answer your question.
THANKS
Maybe the ssid is not broadcasted.
Can you do a sh run | in ssid
Regards.
Alain.
The SSID is broadcast (i can see it at my computer and phone).
It doesn't appear int the list of wireless networks? what if  you enter it manually, it can't connect?
Regards.
Alain.
It does not appear in the list of wireless.
Also manual does not work...
Can you post a diagram of your topology along with IP and mask as well as SSIDs/channel
Regards.
Alain.
