Cisco 871W
tomholmes
Router defaults after I unplug the power?
6 Replies 6
Brandon Buffin
Are you saying your router goes back to defaults after losing power. If so, are you writing the configuration to memory after making changes? After making config changes, issue the "wr mem" command.
Hope this helps.
Brandon
How would I do this in SDM express?
Thanks Tom
Still does not work....
Can you telnet or console to the router and issue the "wr mem" command after making a config change and see if that helps?
Brandon
Could it be bad flash
