Cisco 877 Load Balancing with external router
pcdoctorsg
I have a cisco 877, internet connection is on ATM0.1. I have a LAMP server running on my LAN, using NAT to point the public IP. I also have 3 IP camera and one DVR on NAT.
I wish to connect another external router which is running on 3G Wireless WAN. It is currently connected to FastEthernet3 and i config the IP on the external router to 192.168.2.9
I need advice on how to use both WAN to load balance?
My current config below (external IP not actual):
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname yourname
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret 5 $1$UZcu$egNFkzSWzYU.TR3XDnzGp0
aaa new-model
aaa authentication login default local
aaa authentication login ciscocp_vpn_xauth_ml_1 local
aaa authorization exec default local
aaa authorization network ciscocp_vpn_group_ml_1 local
aaa session-id common
crypto pki trustpoint TP-self-signed-3618654819
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3618654819
revocation-check none
rsakeypair TP-self-signed-3618654819
crypto pki certificate chain TP-self-signed-3618654819
certificate self-signed 01
  3082024F 308201B8 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 33363138 36353438 3139301E 170D3032 30333031 30303236
  32385A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 36313836
  35343831 3930819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100D70B 2129541B 89EF90DD 86FF5B51 74B529BC 35019050 DE383281 76BBCA53
  50E29597 E685A860 4DFC952B C1D14C10 7A6B5B28 B4138B08 A4499897 44FEBEF1
  B19C0604 FCFF62C0 750D7DEF 6FD5A908 83366275 BAD1CEAC 3C1CC19E 1B234370
  63DE1C2A E0F8E481 A0C208DF 3B24D0D6 E82651D6 3BF528E3 5727B503 6DE75223
  B94F0203 010001A3 77307530 0F060355 1D130101 FF040530 030101FF 30220603
  551D1104 1B301982 17796F75 726E616D 652E796F 7572646F 6D61696E 2E636F6D
  301F0603 551D2304 18301680 141919D9 350BB2E1 75759D21 281DBD38 F0CAFF17
  2B301D06 03551D0E 04160414 1919D935 0BB2E175 759D2128 1DBD38F0 CAFF172B
  300D0609 2A864886 F70D0101 04050003 81810083 5EBE06E7 1C2AEF1E 3D172F90
  9161162E 620CDA9C 2739D7FB 90D34052 8E003F03 AD4DD9BE 3407B16C DB742FC4
  A83EEFB8 B9916676 3B17C3E3 ACD76910 31B9D6D9 379DF8F6 2515A8F5 B10AD5A0
  F69164BF 0A3660FD 1E3986AF 941C9D89 102C3F44 2ECF2DC4 309A5E06 C5F1F492
  B936D118 81871C75 573D7767 4B4D2194 5810E5
      quit
dot11 syslog
no ip source-route
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.2.1 192.168.2.9
ip dhcp excluded-address 192.168.2.51 192.168.2.254
ip dhcp pool ccp-pool1
   import all
   network 192.168.2.0 255.255.255.0
   dns-server 8.8.8.8 165.21.83.88
   default-router 192.168.2.1
ip port-map user-protocol--1 port tcp 3000
ip port-map user-SMTP587 port tcp 587
ip port-map user-RTSP port tcp 555
ip port-map user-AVcontrol port tcp 4321
ip port-map user-Kloxo2 port tcp 7778
ip port-map user-ezvpn-remote port udp 10000
ip port-map user-Kloxo port tcp 7777
ip port-map user-AVcontrol2 port tcp 4322
no ip bootp server
ip domain name yourdomain.com
ip name-server 8.8.8.8
ip name-server 165.21.83.88
parameter-map type protocol-info yahoo-servers
server name scs.msg.yahoo.com
server name scsa.msg.yahoo.com
server name scsb.msg.yahoo.com
server name scsc.msg.yahoo.com
server name scsd.msg.yahoo.com
server name cs16.msg.dcn.yahoo.com
server name cs19.msg.dcn.yahoo.com
server name cs42.msg.dcn.yahoo.com
server name cs53.msg.dcn.yahoo.com
server name cs54.msg.dcn.yahoo.com
server name ads1.vip.scd.yahoo.com
server name radio1.launch.vip.dal.yahoo.com
server name in1.msg.vip.re2.yahoo.com
server name data1.my.vip.sc5.yahoo.com
server name address1.pim.vip.mud.yahoo.com
server name edit.messenger.yahoo.com
server name messenger.yahoo.com
server name http.pager.yahoo.com
server name privacy.yahoo.com
server name csa.yahoo.com
server name csb.yahoo.com
server name csc.yahoo.com
parameter-map type protocol-info aol-servers
server name login.oscar.aol.com
server name toc.oscar.aol.com
server name oam-d09a.blue.aol.com
parameter-map type protocol-info msn-servers
server name messenger.hotmail.com
server name gateway.messenger.hotmail.com
server name webmessenger.msn.com
parameter-map type regex ccp-regex-nonascii
pattern [^\x00-\x80]
password encryption aes
username admin privilege 15 secret 5 $1$U3/u$NMwNX.O3w0Jw7Ec0XbZAq1
username vpnuser privilege 15 secret 5 $1$.htH$f5yUSEZwT31bAwANxkm/R/
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp policy 2
group 2
crypto isakmp client configuration group vpnuser
key 6 fPgXAHFIIH]fHeLOBKcOMHP`BaCTIMJLe
pool SDM_POOL_1
acl 100
crypto isakmp profile ciscocp-ike-profile-1
   match identity group vpnuser
   client authentication list ciscocp_vpn_xauth_ml_1
   isakmp authorization list ciscocp_vpn_group_ml_1
   client configuration address respond
   virtual-template 7
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec profile CiscoCP_Profile1
set security-association idle-time 43200
set transform-set ESP-3DES-SHA
set isakmp-profile ciscocp-ike-profile-1
crypto ipsec client ezvpn CISCOCP_EZVPN_CLIENT_1
connect auto
group vpnuser key 6 Gd`eaCVaRCeIGQSPhZaP\\KKdViK^TdBE
mode client
peer 203.121.240.119
virtual-interface 8
xauth userid mode interactive
crypto ctcp port 10000
archive
log config
  hidekeys
ip ftp username sedap.me
ip ftp password 7 115E4F51151705
ip tcp synwait-time 10
class-map type inspect match-all sdm-nat-http-4
match access-group 103
match protocol http
class-map type inspect imap match-any ccp-app-imap
match  invalid-command
class-map type inspect match-all sdm-nat-http-1
match access-group 102
match protocol http
class-map type inspect match-all sdm-nat-user-protocol--1-1
match access-group 105
match protocol user-protocol--1
class-map type inspect match-all sdm-nat-http-2
class-map type inspect match-all sdm-nat-http-3
match access-group 104
match protocol http
class-map type inspect smtp match-any ccp-app-smtp
match  data-length gt 5000000
class-map type inspect match-any SDM_AH
match access-group name SDM_AH
class-map type inspect match-any ccp-skinny-inspect
match protocol skinny
class-map type inspect http match-any ccp-app-nonascii
match  req-resp header regex ccp-regex-nonascii
class-map type inspect match-any ccp-cls-insp-traffic
match protocol dns
match protocol https
match protocol icmp
match protocol imap
match protocol pop3
match protocol tcp
match protocol udp
class-map type inspect match-all ccp-insp-traffic
match class-map ccp-cls-insp-traffic
class-map type inspect match-any sdm-service-sdm-pol-NATOutsideToInside-1
match protocol http
match protocol user-RTSP
match protocol user-AVcontrol
match protocol user-AVcontrol2
class-map type inspect match-any SDM_ESP
match access-group name SDM_ESP
class-map type inspect match-any SDM_EASY_VPN_REMOTE_TRAFFIC
match protocol isakmp
match protocol ipsec-msft
match class-map SDM_AH
match class-map SDM_ESP
match protocol user-ezvpn-remote
class-map type inspect match-all SDM_EASY_VPN_REMOTE_PT
match class-map SDM_EASY_VPN_REMOTE_TRAFFIC
match access-group 107
class-map type inspect match-any SDM_IP
match access-group name SDM_IP
class-map type inspect match-any WebServer
match protocol imap
match protocol imaps
match protocol pop3
match protocol pop3s
match protocol smtp
match protocol ftp
match protocol ftps
match protocol http
match protocol ddns-v3
match protocol dns
match protocol dnsix
match protocol icmp
match protocol user-Kloxo
match protocol user-Kloxo2
match protocol user-SMTP587
class-map type inspect match-all sdm-nat--1
match access-group 106
match class-map WebServer
class-map type inspect match-any SDM_EASY_VPN_SERVER_TRAFFIC
class-map type inspect match-all SDM_EASY_VPN_SERVER_PT
match class-map SDM_EASY_VPN_SERVER_TRAFFIC
class-map type inspect match-any ccp-cls-icmp-access
match protocol icmp
match protocol tcp
match protocol udp
class-map type inspect match-any ccp-cls-protocol-im
match protocol ymsgr yahoo-servers
match protocol msnmsgr msn-servers
match protocol aol aol-servers
class-map type inspect match-all ccp-protocol-pop3
match protocol pop3
class-map type inspect match-any ccp-h225ras-inspect
match protocol h225ras
class-map type inspect pop3 match-any ccp-app-pop3
class-map type inspect match-any ccp-h323-inspect
match protocol h323
class-map type inspect match-all ccp-protocol-im
match class-map ccp-cls-protocol-im
class-map type inspect match-all ccp-icmp-access
match class-map ccp-cls-icmp-access
class-map type inspect match-all ccp-invalid-src
match access-group 101
class-map type inspect http match-any ccp-app-httpmethods
match  request method bcopy
match  request method bdelete
match  request method bmove
match  request method bpropfind
match  request method bproppatch
match  request method connect
match  request method copy
match  request method delete
match  request method edit
match  request method getattribute
match  request method getattributenames
match  request method getproperties
match  request method index
match  request method lock
match  request method mkcol
match  request method mkdir
match  request method move
match  request method notify
match  request method options
match  request method poll
match  request method post
match  request method propfind
match  request method proppatch
match  request method put
match  request method revadd
match  request method revlabel
match  request method revlog
match  request method revnum
match  request method save
match  request method search
match  request method setattribute
match  request method startrev
match  request method stoprev
match  request method subscribe
match  request method trace
match  request method unedit
match  request method unlock
match  request method unsubscribe
class-map type inspect match-any ccp-sip-inspect
match protocol sip
class-map type inspect http match-any ccp-http-blockparam
match  request port-misuse im
match  request port-misuse p2p
match  request port-misuse tunneling
match  req-resp protocol-violation
class-map type inspect match-all ccp-protocol-imap
match protocol imap
class-map type inspect match-all ccp-protocol-smtp
match protocol smtp
class-map type inspect match-all ccp-protocol-http
match protocol http
policy-map type inspect ccp-permit-icmpreply
class type inspect ccp-icmp-access
  inspect
class class-default
  pass
policy-map type inspect sdm-pol-NATOutsideToInside-1
class type inspect sdm-nat-http-1
  inspect
class type inspect sdm-nat-http-2
  inspect
class type inspect sdm-nat-http-3
  inspect
class type inspect sdm-nat-user-protocol--1-1
  inspect
class type inspect sdm-nat--1
  inspect
class type inspect sdm-nat-http-4
  inspect
class class-default
policy-map type inspect http ccp-action-app-http
class type inspect http ccp-http-blockparam
  log
  reset
class type inspect http ccp-app-httpmethods
  log
  reset
class type inspect http ccp-app-nonascii
  log
  reset
class class-default
policy-map type inspect smtp ccp-action-smtp
class type inspect smtp ccp-app-smtp
  reset
class class-default
policy-map type inspect imap ccp-action-imap
class type inspect imap ccp-app-imap
  log
  reset
class class-default
policy-map type inspect pop3 ccp-action-pop3
class type inspect pop3 ccp-app-pop3
  log
  reset
class class-default
policy-map type inspect ccp-inspect
class type inspect ccp-invalid-src
  drop log
class type inspect ccp-protocol-http
  inspect
  service-policy http ccp-action-app-http
class type inspect ccp-protocol-smtp
  inspect
  service-policy smtp ccp-action-smtp
class type inspect ccp-protocol-imap
  inspect
  service-policy imap ccp-action-imap
class type inspect ccp-protocol-pop3
  inspect
  service-policy pop3 ccp-action-pop3
  drop log
class type inspect ccp-insp-traffic
  inspect
class type inspect ccp-h323-inspect
  inspect
class type inspect ccp-h225ras-inspect
  inspect
class type inspect SDM_EASY_VPN_SERVER_PT
  pass
class type inspect SDM_EASY_VPN_REMOTE_PT
  pass
class class-default
policy-map type inspect sdm-permit-ip
class type inspect SDM_IP
  pass
class class-default
  drop log
zone security out-zone
zone security in-zone
zone security ezvpn-zone
zone-pair security ccp-zp-self-out source self destination out-zone
service-policy type inspect ccp-permit-icmpreply
zone-pair security sdm-zp-NATOutsideToInside-1 source out-zone destination in-zone
service-policy type inspect sdm-pol-NATOutsideToInside-1
zone-pair security ccp-zp-in-out source in-zone destination out-zone
service-policy type inspect ccp-inspect
zone-pair security ccp-zp-out-self source out-zone destination self
zone-pair security sdm-zp-in-ezvpn1 source in-zone destination ezvpn-zone
service-policy type inspect sdm-permit-ip
zone-pair security sdm-zp-ezvpn-in1 source ezvpn-zone destination in-zone
zone-pair security sdm-zp-out-ezpn1 source out-zone destination ezvpn-zone
zone-pair security sdm-zp-ezvpn-out1 source ezvpn-zone destination out-zone
interface Null0
no ip unreachables
interface ATM0
no ip address
no ip redirects
no ip unreachables
ip route-cache flow
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
description $ES_WAN$$FW_OUTSIDE$
ip address 203.121.240.119 255.255.255.252
ip verify unicast reverse-path
no ip redirects
no ip unreachables
ip nat outside
ip virtual-reassembly
zone-member security out-zone
pvc 8/35
  protocol ip 203.121.240.118 broadcast
  encapsulation aal5snap
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Virtual-Template7 type tunnel
ip unnumbered ATM0.1
no ip redirects
no ip unreachables
zone-member security ezvpn-zone
ip route-cache flow
tunnel mode ipsec ipv4
tunnel protection ipsec profile CiscoCP_Profile1
interface Virtual-Template8 type tunnel
no ip address
no ip redirects
no ip unreachables
ip route-cache flow
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$ES_LAN$$FW_INSIDE$
ip address 192.168.2.1 255.255.255.0
no ip redirects
no ip unreachables
ip nat inside
zone-member security in-zone
ip route-cache flow201.41.146.99
ip tcp adjust-mss 1452
crypto ipsec client ezvpn CISCOCP_EZVPN_CLIENT_1 inside
ip local pool SDM_POOL_1 192.168.2.10 192.168.2.50
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 ATM0.1 2
ip http server
ip http access-class 2
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface ATM0.1 overload
ip nat inside source static tcp 192.168.2.201 80 201.41.146.39 80 extendable
ip nat inside source static tcp 192.168.2.211 80 201.41.146.39 81 extendable
ip nat inside source static tcp 192.168.2.250 80 201.41.146.39 82 extendable
ip nat inside source static tcp 192.168.2.200 3000 201.41.146.39 3000 extendable
ip nat inside source static 192.168.2.240 201.41.146.99
ip access-list extended SDM_AH
remark CCP_ACL Category=1
permit ahp any any
ip access-list extended SDM_ESP
permit esp any any
ip access-list extended SDM_IP
permit ip any any
access-list 1 remark INSIDE_IF=Vlan1
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 192.168.2.0 0.0.0.255
access-list 2 remark HTTP Access-class list
access-list 2 remark CCP_ACL Category=1
access-list 2 permit 192.168.2.0 0.0.0.255
access-list 2 deny   any
access-list 100 remark CCP_ACL Category=4
access-list 100 permit ip 192.168.2.0 0.0.0.255 any
access-list 101 remark CCP_ACL Category=128
access-list 101 permit ip host 255.255.255.255 any
access-list 101 permit ip 127.0.0.0 0.255.255.255 any
access-list 101 permit ip 203.120.242.224 0.0.0.3 any
access-list 102 remark CCP_ACL Category=0
access-list 102 permit ip any host 192.168.2.201
access-list 103 remark CCP_ACL Category=0
access-list 103 permit ip any host 192.168.2.211
access-list 104 remark CCP_ACL Category=0
access-list 104 permit ip any host 192.168.2.250
access-list 105 remark CCP_ACL Category=0
access-list 105 permit ip any host 192.168.2.200
access-list 106 remark CCP_ACL Category=0
access-list 106 permit ip any host 192.168.2.240
access-list 107 remark CCP_ACL Category=128
access-list 107 permit ip host 203.121.240.118 any
no cdp run
control-plane
banner exec
% Password expiration warning.
Cisco Configuration Professional (Cisco CP) is installed on this device
and it provides the default username "cisco" for  one-time use. If you have
already used the username "cisco" to login to the router and your IOS image
supports the "one-time" user option, then this username has already expired.
You will not be able to login to the router with this username after you exit
this session.
It is strongly suggested that you create a new username with a privilege level
of 15 using the following command.
username <myuser> privilege 15 secret 0 <mypassword>
Replace <myuser> and <mypassword> with the username and password you
want to use.
banner login  Authorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!
line con 0
no modem enable
transport output telnet
line aux 0
line vty 0 4
transport input telnet ssh
scheduler max-task-time 5000
scheduler allocate 4000 1000
scheduler interval 500
end
5 Replies 5
rparames
What I understand your setup would look like this
             |---------------------- Router 1 ------- ISP 1
LAN-------                          |
                                       -----Router 2 --------- ISP 2
I would have 2 default routes on Router 1 (877)
along with the one you have , include "ip route 0.0.0.0 0.0.0.0 192.168.2.9 0"
(since you first static route next hop not specified and you use directly connected interface I have configured admin distance to be 0)
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080094195.shtml
Now you need to have similar NAT translations on Router 2.
Note : We have to make sure the load balancing on 877 is per destination and not per packet
By default I think it is per destination
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080094820.shtml
Rahul
The AD of a static route is always 1 whether the route points to an interface or a next-hop. AD of 0 is for directly connected routes.You can only set AD of static route between 1 and 255.If you could set it to 0 it would have been less than the actual route and so would have overidden the first route with a higher AD which would only appear when this one with lower AD was down.
Regards.
Alain.
When you include a static route , without the next hop IP but specify the exit interface, its admin distance is equal to 0,  its treated like a directly connected interface
Rack05R3#sh run | i ip route
ip route 0.0.0.0 0.0.0.0 Serial0/0/0
Rack05R3#sh ip route
Gateway of last resort is 0.0.0.0 to network 0.0.0.0
C       10.1.1.0 is directly connected, Serial0/0/0
S*   0.0.0.0/0 is directly connected, Serial0/0/0
I change the route and specify next hop IP rather than exit interface
Rack05R3#sh running-config | i ip route
ip route 0.0.0.0 0.0.0.0 10.1.1.2
Rack05R3#show ip route
Gateway of last resort is 10.1.1.2 to network 0.0.0.0
S*   0.0.0.0/0 [1/0] via 10.1.1.2    ----> SEE THE ADMIN DISTANCE IS 1
One thing I was wrong here is that you cannot specify a admin distance of 0 when you configure a static route.
So " ip route 0.0.0.0 0.0.0.0 192.168.2.9 0 " is not a valid command - Thanks for poiniting out
Couple of interesting observations I made
Scenario 1)
ip route 0.0.0.0 0.0.0.0 10.1.1.2 10
ip route 0.0.0.0 0.0.0.0 Serial0/0/1 10
One of the routes has next hop, other has exit interface
     20.0.0.0/30 is subnetted, 1 subnets
C       20.1.1.0 is directly connected, Serial0/0/1
     10.0.0.0/30 is subnetted, 1 subnets
S*   0.0.0.0/0 [10/0] via 10.1.1.2
Black holes the traffic as gateway is 10.1.1.2 is rechable via S0/0/0 , but routing table shows
Seanario 2)
Rack05R3(config)#do sh run | i ip route
ip route 0.0.0.0 0.0.0.0 Serial0/0/0 10
Both use exit interface
S*   0.0.0.0/0 is directly connected, Serial0/0/1
Which will work
Senario 3)
Both static route point to next hop IP
ip route 0.0.0.0 0.0.0.0 20.1.1.2
Gateway of last resort is 20.1.1.2 to network 0.0.0.0
S*   0.0.0.0/0 [1/0] via 20.1.1.2
               [1/0] via 10.1.1.2
This works fine as well
Conclusion : We cannot have 2 static default gateway, one pointing next hop IP and another exit interface
Coming to the original question as to how we can achieve load balancing
The only way it would work is when you have 2 static routes
1) pointing the existing defaulty gateway to next hop IP
ip route 0.0.0.0 0.0.0.0 X.X.X.X
2) Add another static route pointing to new router
Exit interface with ethernet is not recommended because the router will send out arp request for every new destination IP and the gateway must proxy reply for every destination
Rahul
Hi Rahul,
I disagree with you and you made the proof with scenario 1:
This means you have the 2 routes installed so they have the same AD which is one.
If you disable CEF as well as fast-switching you'll see per-packet load balancing with debug ip packet.
Your conclusion is not correct imho because all the scenarios you did install both routes in the routing table and a route pointing to a next-hop must do a recursive lookup to find the correct interface.
Exit interface with ethernet is not recommended because the router will  send out arp request for every new destination IP and the gateway must  proxy reply for every destination  Totally agree a static route pointing to interface should only be configured for point-to-point links, in the case of frame-relay this is still worse because there is no proxy inARP.
Regards.
Alain.
Hi Alain,
I misread the output in senario 1
I  remembered reading while preparing for my certification that when a  static route points out of an exit interface rather than a next hop IP,  it would select exit interface as that had AD equal to that of connected  interface. But it looks like both have same AD and both are programmed.
Verified it in my lab
Thanks Again
-Rahul
