Cisco 877 trun 2 vlan
facundoo23
I need to connect 2 vlan on a Cisco router VLAN 877 and the second does not connect to anything. PING only to itself, being one who hangs on a switch where there is another router with an IP in the range of VLAN 2. VLAN 1 works well.
interface FastEthernet0
interface FastEthernet1
switchport access vlan 2
interface FastEthernet2
interface FastEthernet3
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$
ip address 143.104.1.41 255.255.0.0
ip access-group no-inet in
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1368
ip policy route-map red-143109
crypto ipsec client ezvpn vpn inside
hold-queue 100 out
interface Vlan2
ip address 10.104.1.41 255.255.0.0
ip flow ingress
ip nat inside
5 Replies 5
krahmani323
Level 3
Level 3
Hello Facundo Cesar.
Regarding to the problem description, I was wondering about the configuration on the Switch interface connected to the Cisco877 Fa1...Could you please post the interface configuration of the connected switch ? Is it a trunk ?
As you can ping internally I suppose the VLAN 2 interface status is up/up
In fact I am thinking it could maybe be due to a STP port type  mismatch between Fa1 of the Cisco877 and the connected switch interface...I have been facing this issue in the past.
What is the output of  Cisco877# show spanning-tree interface FastEthernet 1 ?
If it is something like => Port 2 (FastEthernet1) of VLAN2 is broken (Port Type Mismatch) this is the issue.
If not we will have to continue the investigations :-(
Kind regards :-)
Karim
PING VLAN2 Response.
show spanning-tree
     Port 1 (F0) Vlan1 Forwarding
     Port 2 (F1) VLAN2 Forwarding
show vlans
     No Virtual LANS configured
show vlans-switch
VLAN Name                             Status    Ports
1    default                          active    Fa0, Fa2, Fa3
2    RedNueva                         active    Fa1
1002 fddi-default                     act/unsup
1003 token-ring-default               act/unsup
1004 fddinet-default                  act/unsup
1005 trnet-default                    act/unsup
What may be happening is you have to build a trunking on Switch 2960 which hangs 877. But in 1710 I have no problem.
johnlloyd_13
Level 9
Level 9
Do you have a L2 VLAN created on your 877?
Router(config)#vlan 2
Kindly post your running config, show vlan-switch brief and show ip interface brief output.
facundoo23
show spanning-tree
show vlans
show vlans-switch
facundoo23
show spanning-tree
show vlans
show vlans-switch
