Cisco 877w DHCP and routing problem
Lukeager1
Hi guys, I am studying my ccna and have had a cisco 3725 router set up at home for a while but wanted wireless back in my house and so swapped for 877w.
There is no wireless covered in the ccna so I am kinda learning this as i go.
I am with BT (in the UK) and have a fibre modem and so have eventually figuried out how to connect using VDSL and am able to ping websites from the command line...
however I have 2 problems.
1.. I have set up DHCP (wrong obviously) and supposed to be running NAT inside but when i plug my laptop into one of the FE ports it does not pick up an IP address. (I have checked adapter settings.
The WAN connection is in VLAN1 and my Internal Access ports are in VLAN2. and I assigned my internal vlan with a dhcp pool but nothing is happening.
i know i must have messed up but dont know where.
and 2...
If i set my laptop IP manually, I can ping the VLAN Ip address but still cannot get off my network...what am i missing to be able to route between these 2 vlans?
thanks in advance..
here is my config, in full since I am not sure what the issue is. (p.s wireless isnt set up yet.)
hostname Router
boot-start-marker
dot11 syslog
ip cef
no ip dhcp use vrf connected
ip dhcp pool DHCPSERVER
import all
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1 255.255.255.0
dns-server 212.159.13.49 212.159.13.50
ip dhcp pool DSL_DHCP
import all
ip name-server 212.159.13.49
ip name-server 212.159.13.50
archive
log config
hidekeys
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
dsl operating-mode auto
interface FastEthernet0
switchport access vlan 2
speed 100
pppoe enable group global
pppoe-client dial-pool-number 10
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Dot11Radio0
no ip address
shutdown
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Vlan1
description INTERNAL NETWORK
ip address 192.168.1.254 255.255.255.0
ip nat inside
ip virtual-reassembly
interface Vlan2
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
interface Dialer1
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 10
ppp authentication chap callin
ppp chap hostname @@@@@@@@@@
ppp chap password 0 @@@@@@@@
router rip
version 2
network 192.168.1.0
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer1
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface Dialer1 overload
ip access-list extended NAT
permit ip 192.168.1.0 0.0.0.255 any
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
login
scheduler max-task-time 5000
end
cadet alain
1° your NAT statement references an inexistent ACL
no ip nat inside source list 1 interface Dialer1 overload
ip nat inside source list NAT interface Dialer1 overload
2° get rid of the DSL_DHCP pool and edit your first pool
no ip dhcp pool DSL_DHCP
no default-router 192.168.1.1 255.255.255.0
3° so your modem is not in bridged mode and you are connected to it with one of your switched port(L2 port) in vlan 1
and your internal leg of the modem is 192.168.1.x ?
if so then Vlan 1 is your outside leg and not your inside leg but vlan 2 is your inside leg.
you will also need to put a static IP to vlan 2 for DHCP to work and change your pool to lease you addresses in another subnet like 192.168.2.0/24 for example.
Tell me if I understood correctly and I'll post the changes to be made.
Alain
