cisco 881 router issue
hi
I have installed cisco 881 router. line vty password configured.But  there is a problem. any one can't log to router.Please help to sort-out this problem.
Buddhika W.
5 Replies 5
Leo Laohoo
Would be nice if you post your config.
  line vty 0 4
  session-timeout 120
  access-class 23 in
  privilege level 15
  logging synchronous
  transport preferred none
  transport input telnet ssh
  transport output telnet ssh
post output of sh access-list 23
Regards.
Alain.
icewolf101
Make sure you have typed the "login" command, also you will need to set a enable secret password. Oh and obviously your router needs to be accesable from your LAN so see if you can ping it from a workstation.
line vty 0 4
password (/password/)
login
logging sync
exit
enable secret (/password/)
Anis Momin
Please help me with following post
https://supportforums.cisco.com/thread/2252633
