Cisco 881W problems with DHCP and Wireless
james.ochs
Hi all,
I have a cisco 881W that I am having a strange issue with.  I can't seem to get my details past whatever filter they have put on this site as I keep getting this message:
This message can not be displayed due to its content. Please use the contact us link with any questions.
But in a nutshell, two laptops don't get a dhcp address, one tablet also can not, but two phones can when connected to the wireless network.  All of the devices I am having trouble with are made by a manufacturer named after a fruit.
When the devices that do not get an ip connect, I see them associate with the AP, but I don't see any activity under sho ip dhcp server stat
border-1#sho run
Building configuration...
Current configuration : 3263 bytes
! Last configuration change at 23:07:31 PCTime Tue Jan 7 2014 by
! NVRAM config last updated at 22:34:20 PCTime Tue Jan 7 2014 by
version 15.0
no service pad
service password-encryption
hostname border-1
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 10
clock timezone PCTime -5
service-module wlan-ap 0 bootimage autonomous
no ip source-route
ip dhcp excluded-address 10.10.10.1 10.10.10.10
ip dhcp excluded-address 10.10.30.1 10.10.30.10
ip dhcp pool vlan1pool
  import all
  network 10.10.10.0 255.255.255.0
  default-router 10.10.10.1
  dns-server 8.8.8.8 8.8.4.4
ip dhcp pool vlan3pool
  network 10.10.30.0 255.255.255.0
  default-router 10.10.30.1
ip cef
no ip domain lookup
ip domain name froody.org
ip inspect name IPV4Rule dns
ip inspect name IPV4Out tcp
ip inspect name IPV4Out udp
ip inspect name IPV4Out ftp
ip inspect name IPV4Out icmp
ipv6 unicast-routing
ipv6 cef
ipv6 inspect name IPV6Rule udp
ipv6 inspect name IPV6Rule ftp
ipv6 inspect name IPV6Rule icmp
ipv6 inspect name IPV6Rule tcp
ipv6 dhcp pool poolv6
license boot module c880-data level advipservices
ip ssh version 2
bridge irb
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
switchport access vlan 2
interface FastEthernet3
interface FastEthernet4
ip address dhcp
ip nat outside
ip inspect IPV4Out out
ip virtual-reassembly
duplex auto
speed auto
ipv6 address autoconfig default
ipv6 enable
ipv6 dhcp client pd tw-ipv6
ipv6 inspect IPV6Rule out
ipv6 traffic-filter wan-in in
ipv6 traffic-filter wan-out out
interface wlan-ap0
description Service module interface to manage the embedded AP
ip unnumbered Vlan1
arp timeout 0
interface Wlan-GigabitEthernet0
description Internal switch interface connecting to the embedded AP
switchport mode trunk
interface Vlan1
ip address 10.10.10.1 255.255.255.0
ip nat inside
interface Vlan2
ip address 10.10.20.1 255.255.255.0
ip nat inside
interface Vlan3
ip address 10.10.30.1 255.255.255.0
ip nat inside
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 3 interface FastEthernet4 overload
ip access-list extended INBOUND
deny  ip any any
access-list 1 permit 0.0.0.0 255.255.255.0
access-list 3 permit 10.10.10.0 0.0.0.255
access-list 3 permit 10.10.30.0 0.0.0.255
ipv6 access-list wan-in
sequence 100 deny ipv6 any any
ipv6 access-list wan-out
permit tcp any any reflect REFLECTOUT
permit udp any any reflect REFLECTOUT
deny ipv6 FEC0:0:0:201::/64 any
control-plane
bridge 1 protocol ieee
bridge 1 route ip
line con 0
no modem enable
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
line vty 0 4
access-class 3 in
login local
transport input ssh
scheduler max-task-time 5000
end
And the Access Point:
ap#sho run
Current configuration : 2310 bytes
version 12.4
no service pad
hostname ap
no aaa new-model
dot11 syslog
dot11 vlan-name vlan1 vlan 1
dot11 vlan-name vlan3 vlan 3
dot11 ssid WLAN1
  vlan 1
  authentication open
  authentication key-management wpa version 2
  mbssid guest-mode
  wpa-psk ascii 0 Test123
dot11 ssid WLAN-GUEST
  vlan 3
  authentication open
  mbssid guest-mode
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 1 mode ciphers tkip
encryption vlan 3 mode ciphers tkip
ssid WLAN1
ssid WLAN-GUEST
antenna gain 0
mbssid
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.2
encapsulation dot1Q 3
no ip route-cache
bridge-group 3
bridge-group 3 subscriber-loop-control
bridge-group 3 block-unknown-source
no bridge-group 3 source-learning
no bridge-group 3 unicast-flooding
bridge-group 3 spanning-disabled
interface GigabitEthernet0
description the embedded AP GigabitEthernet 0 is an internal interface connecting AP with the host router
no ip address
no ip route-cache
interface GigabitEthernet0.1
no ip route-cache
bridge-group 1
interface GigabitEthernet0.2
no ip route-cache
bridge-group 3
interface BVI1
ip address 10.10.10.2 255.255.255.0
no ip route-cache
ip http server
bridge 1 route ip
banner login ^CC
^C
line con 0
privilege level 15
login local
line vty 0 4
login local
end
james.ochs
To clarify, when I connect either laptop directly to the wired switch on the router, I get an IP address and everything works normally.
If I connect either of the phones to the 802.11n network (either SSID) they both get an IP address and everything works normally.
If I connect either laptop to the 802.11n network, both associate to the access point, but neither one gets and IP address.
If I do sho ip dhcp server stat I see the statistics increment if the phones are connected to the wireless network, or if the laptops are connected to the wired network.  I don't see the statistics increment when the laptops are connected to the wireless network.
tcpdump does show the laptops sending dhcp discover packets, so it looks like the access point is not forwarding the laptop dhcp requests for some reason.
the router is running ios 15.0M and the ap has 12.4 something on it.
It could be that your AP is in 802.11n mode only. Try enabling it for 802.11 a/b/g/n on both the 2.4 and 5 GHZ radio
see the following link http://support.apple.com/kb/ht4199
It seems like a wireless isssue ;however have you tried to put a static ip on the laptop from the DHCP server and then try to check if you are able to connect/ping across it.
in case if there is any vulnerablity related to Wireless standard 802.11n , then it should bve reported to TAC for the analysis;however first action will have to be to test it with the static ip.
2. Share the output of debug dhcp
The AP in the 881W only has a 2.4GHZ radio.  I took a look at the apple support link and there wasn't anything that really helps, but some good tips none the less.
Here's the dhcp server debug output when connecting with a phone:
on the ap:
*Mar  1 00:04:22.915: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   8853.956b.1cbf Associated KEY_MGMT[WPAv2 PSK]
on the router side:
Jan 11 04:17:35.467: DHCPD: Sending notification of DISCOVER:
Jan 11 04:17:35.467:   DHCPD: htype 1 chaddr 8853.956b.1cbf
Jan 11 04:17:35.467:   DHCPD: remote id 020a00000a0a0a0100000001
Jan 11 04:17:35.467:   DHCPD: circuit id 00000000
Jan 11 04:17:35.467: DHCPD: Seeing if there is an internally specified pool class:
Jan 11 04:17:35.467: DHCPD: Found previous server binding
Jan 11 04:17:36.479: DHCPD: Sending notification of ASSIGNMENT:
Jan 11 04:17:36.479:  DHCPD: address 10.10.10.13 mask 255.255.255.0
Jan 11 04:17:36.479:   DHCPD: htype 1 chaddr 8853.956b.1cbf
Jan 11 04:17:36.479:   DHCPD: lease time remaining (secs) = 86400
When the laptop connects I see the associate message on the AP, but no activity on the dhcp server on the router side.
Heres the dhcp request from the laptop:
23:24:56.036120 IP 0.0.0.0.bootpc > broadcasthost.bootps: BOOTP/DHCP, Request from 00:23:6c:9a:2f:42 (oui Unknown), length 300
