Cisco 881W switch connection issue
bryanlooi
I have a cisco 881W which seems to have an issue connecting to s 3COM Smart switch. Systems connected to the 3COM would not register an ip address. HOwever if i switch the 3COM to a unmanaged switch, the problems dissapears. I was wondering if there is a configuration that is needed to ensure than the cisco 881W can communicate with a smart switch. The WAM connection is coming from a modem with ADSL
This is my current configuration.
Any help would be gratefull.
version 15.2
hostname yourname
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
ip dhcp excluded-address 10.10.10.51 10.10.10.254
ip dhcp pool ccp-pool
import all
network 10.10.10.0 255.255.255.0
default-router 10.10.10.1
dns-server 202.188.0.133 8.8.8.8
lease infinite
ip domain name yourdomain.com
ip name-server 202.188.0.133
ip name-server 8.8.8.8
ip cef
no ipv6 cef
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
switchport mode trunk
no ip address
interface FastEthernet4
ip address dhcp
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface Wlan-GigabitEthernet0
description Internal switch interface connecting to the embedded AP
no ip address
interface wlan-ap0
description Service module interface to manage the embedded AP
ip unnumbered Vlan1
interface Vlan1
ip address 10.10.10.1 255.255.255.0
ip directed-broadcast
no ip proxy-arp
ip nat inside
ip tcp adjust-mss 1452
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 199 interface FastEthernet4 overload
access-list 199 permit ip any any
no cdp run
line con 0
login local
no modem enable
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
stopbits 1
line vty 0 4
privilege level 15
login local
transport input telnet ssh
line vty 5 15
access-class 23 in
privilege level 15
login local
scheduler allocate 20000 1000
end
18 Replies 18
Wilson Bonilla
Level 3
Level 3
Hello Bryan.
It could be the interface going into err-disable, maybe the interface stays down due to spanning-tree or some kind of incompatibility.
Can you recreate the issue?
Can you post the output of the show interface command when the issue is happening?
Can you post the output of the show interface status err-disable ?
... Show log
Regards.
Wilson B.
Thanks for the reply Wilson.
Do you want the output from the 3COM switch or the Cisco Router.
And how do i go around showing these logs?
Sorry for these question. I am new to this.
Bryan Looi
Bryan,
Wilson is asking you to run the commands show interfaces and show interfaces status err-disabled from the CLI and post the output.
You might also make sure the 3COM switch does not have any conflicting VLAN configuration.
Julio Carvajal
It would be good if you also run a debug dhcp for the client process on that interface.
As a side note to the main discussion:
Using a permit ip any any for the NAT setup will cause way to many issues.
Be as specific as possible and never use any as the source.
Remember to rate all of our posts.
Regards.
Jcarvaja
Sent from Cisco Technical Support Android App
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
bryanlooi
Thanks all.
Addressing wilson's request. When i try
show interface status err-disable nothing appears.
This is the show interface.
Here are the configurations.
FastEthernet0 is down, line protocol is down
  Hardware is Fast Ethernet, address is c067.af1c.4bc6 (bia c067.af1c.4bc6)
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
  Keepalive set (10 sec)
  Auto-duplex, Auto-speed
  Last input never, output never, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     1865454 packets input, 237913828 bytes, 0 no buffer
     Received 270 broadcasts (0 multicasts)
     0 watchdog, 0 multicast, 0 pause input
     1793228 packets output, 723463102 bytes, 0 underruns
     0 output errors, 0 collisions, 2 interface resets
     0 unknown protocol drops
     1 lost carrier, 0 no carrier, 0 pause output
FastEthernet1 is up, line protocol is down
  Hardware is Fast Ethernet, address is c067.af1c.4bc7 (bia c067.af1c.4bc7)
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 multicasts)
     0 packets output, 0 bytes, 0 underruns
     0 lost carrier, 0 no carrier, 0 pause output
FastEthernet2 is up, line protocol is down
  Hardware is Fast Ethernet, address is c067.af1c.4bc8 (bia c067.af1c.4bc8)
FastEthernet3 is up, line protocol is up
  Hardware is Fast Ethernet, address is c067.af1c.4bc9 (bia c067.af1c.4bc9)
  Full-duplex, 100Mb/s
  5 minute input rate 4000 bits/sec, 7 packets/sec
  5 minute output rate 119000 bits/sec, 12 packets/sec
     850987 packets input, 83160538 bytes, 0 no buffer
     Received 1624 broadcasts (0 multicasts)
     1062568 packets output, 438702498 bytes, 0 underruns
FastEthernet4 is up, line protocol is up
  Hardware is PQ3_TSEC, address is c067.af1c.4bca (bia c067.af1c.4bca)
  Internet address is 192.168.1.2/24
  Full-duplex, 100Mb/s, 100BaseTX/FX
  Last input 00:00:00, output 00:00:00, output hang never
  5 minute input rate 118000 bits/sec, 12 packets/sec
  5 minute output rate 3000 bits/sec, 7 packets/sec
     4347982 packets input, 2792086202 bytes
     Received 11 broadcasts (0 IP multicasts)
     0 watchdog
     4338620 packets output, 945319234 bytes, 0 underruns
NVI0 is administratively down, line protocol is down
  Hardware is NVI
  MTU 1514 bytes, BW 56 Kbit/sec, DLY 5000 usec,
  Encapsulation UNKNOWN, loopback not set
     Received 0 broadcasts (0 IP multicasts)
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
Vlan1 is up, line protocol is up
  Hardware is EtherSVI, address is c067.af1c.4bc6 (bia c067.af1c.4bc6)
  Description: $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$
  Internet address is 10.10.10.1/24
  Keepalive not supported
  Last input 00:00:00, output never, output hang never
  5 minute input rate 7000 bits/sec, 10 packets/sec
  5 minute output rate 132000 bits/sec, 12 packets/sec
     4426572 packets input, 971501619 bytes, 0 no buffer
     Received 2916 broadcasts (660 IP multicasts)
     4382063 packets output, 2794285378 bytes, 0 underruns
     0 output errors, 1 interface resets
     14 unknown protocol drops
Wlan-GigabitEthernet0 is up, line protocol is up
  Hardware is WLAN Gigabit Ethernet, address is c067.af1c.4bca (bia c067.af1c.4bca)
  Description: Internal switch interface connecting to the embedded AP
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
  Full-duplex, 1000Mb/s
  Last input 00:00:19, output never, output hang never
  5 minute input rate 1000 bits/sec, 2 packets/sec
  5 minute output rate 2000 bits/sec, 3 packets/sec
     1741190 packets input, 671924153 bytes, 0 no buffer
     Received 1071 broadcasts (0 multicasts)
     1858154 packets output, 1694495886 bytes, 0 underruns
     2496 unknown protocol drops
wlan-ap0 is up, line protocol is up
  Hardware is wlan-ap
  Description: Service module interface to manage the embedded AP
  Interface is unnumbered. Using address of Vlan1 (10.10.10.1)
  MTU 1514 bytes, BW 8000000 Kbit/sec, DLY 5000 usec,
  Encapsulation LOOPBACK, loopback not set
  Output queue: 0/0 (size/max)
Addressing Daniel's question. The VLAN on the switch is already at VLAn 1, untagged. I firts though this was the problem as well, however, i used this setup on my old 871W router and there was no problem. Also connecting the cable modem direct to the switch also works. Only when the cisco rouiter is placed in between the cable moem and switch problem occurs.
Addressing Julio.  How do i go about running a debug DHCP? and I was not to osure about tha NAT. So i used my old configurations which NAT was enabled for the WAN interface FE4 and also NAT for the inside traffic. How to i specify?
Thanks all for the help. Really appreciate it.
Julio Carvajal
Hello bud,
It seems it has an IP address.
So u are missing just thr route
Ip route 0.0.0.0 0.0.0.0 fasteth 0/4
For the nat
Ip access-list extended NAT
Permit ip inside_Subnet any
Ip nat inside source list NAT int fa 0/4 overload
Rate all of the helpful posts buddy
Julio Carvajal
Hey Julio,
How to I enable the route?
But I can use an unmanaged switch and it will work fine. Only with this 3COM smart switch, the problem persist.
The NAT if i leave it it should be fine correct?
Thanks Julio for all the help. Really appreciate it
Julio Carvajal
Leave the nat the way it is for the moment.
For the route
Config te
Ip route 0.0.0.0 0.0.0.0 x.x.x.x
Where x.x.x.x is the IP address of the ISP modem.
If u do noy have it use
Ip route 0.0.0.0 0.0.0.0 fast 0/4
Julio Carvajal
Hey Julio
But isnt this config for the ISP modem to the router? For the WAN interface?
Currently the issue isnt here. I can connect to the ISP modem.
Or is this the commands to speccify an IP for the lan interfaces. Currently all my interfaces have no ip address. But i think the VLAN is assignned to the ports. So thats how im getting internet and IP address.
Why is that when i use an unmanaged switch it works?
Thanks for all your help.
Julio Carvajal
Hello.
So I misunderstood ur post..
Thanks for the explanation.
Also share
Show interface fas x/x switchport
Where x/x is the interface connected to the switch
This a really fair and simple configuration.
I do not think the issue is on this device but
Then provide us
Show run interface fastethernet x/x
Where x/x is the interface going to the switch.
Julio Carvajal
Hello Julio
The commands above return an error. And the err-disabled command return a blnk screen. So im not too sure what is going on.
Bryan Looi
so if you do show interface fast 0/x switchport you get an syntax error??
What's the interface connecting to the switch???
Rate all of the helpful posts!!!
Jcarvaja
Follow me on http://laguiadelnetworking.com
Julio Carvajal
Hello Julio
Yes, Running
Gets me an error
Its connected to FA0 currently. This problem only occurs on this switch, On an unmanaged switch, no problem.
Hello Bryan,
Then share
show interface fas 0 switchport
show run interface fast 0
Jcarvaja
Julio Carvajal
