Cisco 881W with smart switch issue
bryanlooi
I cant seem to connect my cisco 881W to a 3COM smart switch. The switch does not seem to receive any dhcp IP address that is given by the router when devices are conneceted to the switch. However if I use an unmanaged switch, i can get an Ip address. I am wondering if there is a onfiguration that is needed to ensure that the router can be used with a smart switch that already is set to be used with DHCP.
These are the current config
Any help would be grateful.
version 15.2
hostname yourname
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
ip dhcp excluded-address 10.10.10.51 10.10.10.254
ip dhcp pool ccp-pool
import all
network 10.10.10.0 255.255.255.0
default-router 10.10.10.1
dns-server 202.188.0.133 8.8.8.8
lease infinite
ip name-server 202.188.0.133
ip name-server 8.8.8.8
ip cef
no ipv6 cef
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
switchport mode trunk
no ip address
interface FastEthernet4
ip address dhcp
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface Wlan-GigabitEthernet0
description Internal switch interface connecting to the embedded AP
no ip address
interface wlan-ap0
description Service module interface to manage the embedded AP
ip unnumbered Vlan1
interface Vlan1
ip address 10.10.10.1 255.255.255.0
ip directed-broadcast
no ip proxy-arp
ip nat inside
ip tcp adjust-mss 1452
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 199 interface FastEthernet4 overload
access-list 199 permit ip any any
no cdp run
line con 0
login local
no modem enable
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
stopbits 1
line vty 0 4
privilege level 15
login local
transport input telnet ssh
line vty 5 15
access-class 23 in
privilege level 15
login local
scheduler allocate 20000 1000
end
12 Replies 12
John Blakley
Does the 3com have vlans configured on it? The only vlan that needs to be on there is vlan 1, and it needs to be untagged.
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
Thanks for the reply John,
But the 3COM switch is already on Vlan 1, Untagged. I have restored the configuration of the switch to factory default, but the problem still exist.
However i think that it is a VLAN issue as an unmanged switch does not seem to have a problem.
On the router, must vlan be turned on? It seems so. The interface for FE0,1,2,3 are assigned to vlan 1 with the DHCP Pool. Is there away i can disable this. On my cisco configuration pro software, the FE LAN 0,1,2,3 does not have an ip address. But i can use the internet. I think the VLAN is assignning it to them.
Are you saying that hosts connected to the switch don't get an address from your Cisco router? The configuration of the router is fa0 - 3 are members of vlan 1, and interface fa4 is a wan port, so the configuration is correct for that part of it. If you connect a normal switch, dhcp works? What port are you connecting the switch to from the 3com?
HTH,
John
Yes, that is correct. Any computers connected to the 3COM switch does not get an ip adrress from the cisco router. However if i connect a normal oswitch which is an unmanaged Dlink switch, i can get an IP address and use the internet as normal. Im connecting the 3COM switch to port 1. And the unmanaged to port 3.
Bryan
Can you post "sh int fa1" and can you post the configuration of the switchport of the 3com that you're connected to? Is this 3com a l2 or l3 switch? Do you have a model number?
HTH,
John
What do you mean by sh int fa 1?
Again what do you mean the switchport configuration of the 3COM that youre connected to. Do you mkean the configuration of the 3COM itself or what?
This is a l2 switch. Its a 3COM baseline 2226 SFP Plus.
Thanks.
Are you telnetted or consoled into the router? If so, run that command "sh int fa1" and copy/paste the results. If you're using a web browser to manage the router, I'm not versed in that enough to help walk you through it unfortunately.
Each port will have a configuration on the switch and the router. I wanted to see the configuration of the 3com switch to see how it was configured.
HTH,
John
Yes, I am connected via telnet. This is the results for that command
FastEthernet1 is up, line protocol is down
  Hardware is Fast Ethernet, address is c067.af1c.4bc7 (bia c067.af1c.4bc7)
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
  Keepalive set (10 sec)
  Auto-duplex, Auto-speed
  Last input never, output never, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 multicasts)
     0 watchdog, 0 multicast, 0 pause input
     0 packets output, 0 bytes, 0 underruns
     0 output errors, 0 collisions, 2 interface resets
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
The 3COM switch is set to factory default.
Im sorry for asking some basic questions. I am new to this. Everyhelp is appreciated.
Thank you
No problem. The interface is up/down at the moment. Can you check the port of the 3com to make sure it's in Auto/Auto? Also, do you have a crossover cable that you can use to connect this switch to the router? The 3com may not support auto-mdix and needs a crossover cable to make a connection. You did have it connected at the time you do the above command correct?
HTH,
John
Yes, the 3COM switch are all auto MDI/MDIX ports. And i also tried using a cross over but still it does not work.
No, to get the results from the command i took off the 3COM switch and plugged it directly to the router. If i went through the switch i cant get a connection as there is no IP.
Im totally confused why this is happening as my prvious cisco was a 871W. and it worke dperfectly fine. The only difference was that last time i did not need to set a vlan to the FE 0,1,2,3 and the FE0,1,2,3 has an ip directly. Not too sure what the difference is here.
The 3Com switch is set to a static ip of 169.254.166.34. using a DHCP address also does not work. But if i connected straight from my cable modem to the 3Com switch it works. Currently my set up is Cable modem > Cisco Router > 3Com Switch which does not work but previously on the 871W it did. But if i did cable modem > 3Com switc. it will work.
Do you have another 3com that you could test? It's not a vlan issue with the Cisco or you wouldn't get an address when connected directly to it or with the unmanaged switch.
Out of curiosity, what port are you connecting to on the 3com? Do you at least get link lights when connected?
HTH,
John
No i dont have another 3COM switch. Because on the 871W it works, but on the new 881W it deosnt. And it will work if connected directly do a DLINK cable modem. Only doesnt work when connected to the cisco.
Im connecting FA1 to port 1 of the 3COM. Ive swapped to diiferent ports also but it still does not work. And yes. I get the activity lights when connected. Only not an IP address.
This is extremely weird.
Bryan.
