04-29-2016 01:10 PM - edited 03-08-2019 05:33 AM
I just wanted to confirm if I can create an VLAN SVI's on an 887VA router and then associate the 4-port LAN switch ports to these different SVI's?
Basically, I am trying to use the Layer 2 LAN port as the Layer 3 WAN port for the Ethernet handoff.
I know logically it should work fine but wanted to again confirm and also know if there are any constraints for this router..... like do I need some specific IOS license etc like Advanced IP Services......
04-30-2016 12:20 AM
Yes you can, and it is in "base ip".
Create a vlan, assign it to an interface, and configure the SVI. Something like:
vlan 2
interface FastEthernet2
switchport mode access
switch access vlan 2
interface vlan 2
ip address ....
05-02-2016 06:26 AM
Thanks for confirming Philip.
