Cisco 887VA - No OSPF commands
Configured a Cisco 887VA with ospf, everything functional.
However after a reboot of the router, now the ospf command is not visible in the command list and can't configure ospf. What is the issue?
edge-router-01(config)#router ?
  odr     On Demand stub Routes
  ospfv3  OSPFv3
  rip     Routing Information Protocol (RIP)
edge-router-01#sh license
Index 1 Feature: advipservices
        Period left: Life time
        License Type: Permanent
        License State: Active, Not in Use
        License Count: Non-Counted
        License Priority: Medium
Index 2 Feature: advsecurity
        License State: Active, In Use
think i found it, had to do a 'license boot module c880-data level advipservices'
I just spent the last 5 minutes figuring out/resetting my Cisco login just so I can say THANKYOU.
I had the same problem and this fixed it.
Reza Sharifi
Glad you found it. Also, usually "sh ver" is an easier command to look for the type of license you have and what it will boot to on the next reboot,
Deepak Kumar
HI,
As I am looking that your Advance IP services license is not in use:
You must run command to make it active in the boot and reload the router.
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
