Cisco 887va VDSL connectivity problem!
cameran93m
Dear Friends, Hello First of all, sorry for my weak English! I've got a Cisco 887va-K9 and I want to connect it to my ISP (A1-Austria) with the credential they gave me. (I am sure that my username and password are correct. I already connected to internet with these username and password by another VDSL modem that my ISP provided.) The problem is: The CD-LED (Carrier Detect) comes shortly green and quickly (after 10-15 Sec.) start blinking again. When it is green, the "Show ip interface brief" result is: R887VA(config-if)#do show ip inter br Interface IP-Address OK? Method Status Protocol ATM0 unassigned YES NVRAM administratively down down Dialer1 unassigned YES NVRAM up up Ethernet0 unassigned YES NVRAM up up Ethernet0.2 unassigned YES unset up up FastEthernet0 unassigned YES unset up down FastEthernet1 unassigned YES unset up down FastEthernet2 unassigned YES unset up down FastEthernet3 unassigned YES unset up up NVI0 unassigned YES unset administratively down down Virtual-Access1 unassigned YES unset up up Vlan1 192.168.1.138 YES NVRAM up up And same time the “Show controller vdsl 0” result is: R887VA#show controller vdsl 0 Controller VDSL 0 is UP Daemon Status: Up XTU-R (DS) XTU-C (US) Chip Vendor ID: 'BDCM' 'BDCM' Chip Vendor Specific: 0x0000 0xB1A9 Chip Vendor Country: 0xB500 0xB500 Modem Vendor ID: 'CSCO' ' ' Modem Vendor Specific: 0x4602 0x0000 Modem Vendor Country: 0xB500 0x0000 Serial Number Near: FCZ1907C0WD C887VA-K 15.3(3)M4 Serial Number Far: eq_nr multiline_cpe software_rev Modem Version Near: 15.3(3)M4 Modem Version Far: 0xb1a9 Modem Status: TC Sync (Showtime!) DSL Config Mode: AUTO Trained Mode: G.993.2 (VDSL2) Profile 17a TC Mode: PTM Selftest Result: 0x00 DELT configuration: disabled DELT state: not running Trellis: ON ON SRA: disabled disabled SRA count: 0 0 Bit swap: enabled enabled Bit swap count: 0 0 Line Attenuation: 0.0 dB 0.0 dB Signal Attenuation: 0.0 dB 0.0 dB Noise Margin: 29.0 dB 27.6 dB Attainable Rate: 100452 kbits/s 34198 kbits/s Actual Power: 12.2 dBm 2.3 dBm Per Band Status: D1 D2 D3 U0 U1 U2 U3 Line Attenuation(dB): 9.7 23.1 35.4 3.5 18.1 27.7 N/A Signal Attenuation(dB): 9.7 23.1 35.4 3.5 18.1 27.7 N/A Noise Margin(dB): 0.0 0.0 0.0 27.6 27.6 27.6 N/A Total FECC: 2 0 Total ES: 50 0 Total SES: 50 0 Total LOSS: 50 0 Total UAS: 1247 1247 Total LPRS: 0 0 Total LOFS: 44 0 Total LOLS: 0 0 Full inits: 8 Failed full inits: 1 Short inits: 0 Failed short inits: 5 Firmware Source File Name (version) -------- ------ ------------------- VDSL embedded VDSL_LINUX_DEV_01212008 (1) Modem FW Version: 130205_1433-4.02L.03.A2pv6C035j.d23j Modem PHY Version: A2pv6C035j.d23j Vendor Version: Ap6v35j.23j 68 DS Channel1 DS Channel0 US Channel1 US Channel0 Speed (kbps): 0 31352 0 6272 SRA Previous Speed: 0 31352 0 6272 Previous Speed: 0 31352 0 6272 Reed-Solomon EC: 0 0 0 0 CRC Errors: 3165 3165 0 0 Header Errors: 0 0 0 0 Interleave (ms): 0.00 0.00 0.00 0.00 Actual INP: 2.01 41.00 4.00 39.00 Training Log : Stopped Training Log Filename : flash:vdsllog.bin But when the CD-LED is flashing: R887VA(config-if)#do show ip inter br Interface IP-Address OK? Method Status Protocol ATM0 unassigned YES NVRAM administratively down down Dialer1 unassigned YES NVRAM up up Ethernet0 unassigned YES NVRAM down down Ethernet0.2 unassigned YES unset down down FastEthernet0 unassigned YES unset up down FastEthernet1 unassigned YES unset up down FastEthernet2 unassigned YES unset up down FastEthernet3 unassigned YES unset up up NVI0 unassigned YES unset administratively down down Virtual-Access1 unassigned YES unset up up Vlan1 192.168.1.138 YES NVRAM up up Again after 2 min. Controller VDSL 0, changed state to up for around 15 sec. and again Controller VDSL 0, changed state to down … and this story is repeated in the same way! This is my router settings: R887VA(config)#do show runn Building configuration... Current configuration : 2743 bytes ! ! Last configuration change at 17:09:04 UTC Thu Apr 27 2017 by admin version 15.3 service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption ! hostname R887VA ! boot-start-marker boot-end-marker ! aqm-register-fnf ! enable secret 5 $1$10fQ$OCN4w00RKk4CFbv7UN.xo. ! no aaa new-model ! ! ! ! ! ! ! ! ! ! ip cef no ipv6 cef ! ! ! ! ! multilink bundle-name authenticated ! ! ! ! ! ! ! license udi pid C887VA-K9 sn FCZ1907C0WD ! ! vtp mode transparent username admin password 0 321 ! ! ! ! ! controller VDSL 0 ! vlan 2 name POS state suspend ! ! ! ! ! ! ! ! ! ! ! interface ATM0 no ip address no ip redirects no ip unreachables no ip proxy-arp load-interval 30 shutdown no atm ilmi-keepalive no snmp trap link-status pvc 8/48 tx-ring-limit 3 pppoe-client dial-pool-number 1 ! ! interface Ethernet0 no ip address pppoe enable group global pppoe-client dial-pool-number 1 ! interface Ethernet0.2 encapsulation dot1Q 2 pppoe enable group global pppoe-client dial-pool-number 1 ! interface FastEthernet0 no ip address ! interface FastEthernet1 no ip address ! interface FastEthernet2 no ip address ! interface FastEthernet3 no ip address ! interface Vlan1 description LAN ip address 192.168.1.138 255.255.255.0 ip nat inside ip virtual-reassembly in ! interface Dialer1 description ** WAN Interface (Dialer interface for VDSL) ** mtu 1492 ip address negotiated no ip redirects no ip unreachables no ip proxy-arp ip nbar protocol-discovery ip flow ingress ip nat outside ip virtual-reassembly in encapsulation ppp ip tcp adjust-mss 1452 load-interval 30 dialer pool 1 dialer-group 1 ppp mtu adaptive ppp authentication pap chap callin ppp chap hostname xxx3469xxx ppp chap password 0 xxxxxx ppp pap sent-username xxx3469xxx password 0 xxxxxx ppp ipcp dns request ppp ipcp route default ppp ipcp address accept no cdp enable ! ip forward-protocol nd no ip http server no ip http secure-server ! ! ip nat inside source list NAT interface Dialer1 overload ip route 0.0.0.0 0.0.0.0 Dialer1 ! ip access-list extended NAT remark --- NATed Traffic allowed from inside to outside --- permit ip 192.168.1.0 0.0.0.255 any ! dialer-list 1 protocol ip permit ! ! control-plane ! ! ! mgcp behavior rsip-range tgcp-only mgcp behavior comedia-role none mgcp behavior comedia-check-media-src disable mgcp behavior comedia-sdp-force disable ! mgcp profile default ! ! ! ! alias exec s show ip inter brief alias exec sr show run ! line con 0 exec-timeout 30 0 password 321 logging synchronous login local no modem enable line aux 0 line vty 0 4 exec-timeout 30 0 logging synchronous login transport input all ! scheduler allocate 20000 1000 ! end Does anyone can help to solve this problem?
0 Replies 0
