cisco 887w wireless
Network Pro
hi,
could anyone please post configuration for wireless on the cisco 887w? i would like wireless and wired users on the same vlan if possible
i am trying to bring the radio up but it says reset and down and cant get it to bring it up ( i have done vlan1, ip unmbered vlan1 bit and logged onto ap using service-module wlan-ap0 session command)
Also is wpa 2 enterprise possible on the cisco 887 w ( if possible i would like it to authenticate with our acs servers on our main site)
8 Replies 8
Leo Laohoo
thanks for this but please note this is 887 w and not 877.
i am getting the error message :
*Jan 13 02:57:09.703: %DOT11-4-NO_SSID_OR_NO_VLAN: No SSID configured. Dot11Radi
o0 not started.xi
o0 not started.xi
It's the same thing.  Wireless is still wireless.  Configuration you require is does not discriminate what model of router you have unless you want, say 802.11n, nor not.
fb_webuser
Level 6
Level 6
Check if you configured the SSID in Global config.
How its the interface radio? is admintravely down, or protocol down?
Configure the Wireless and the vlan using BVIs like this:
bridge irb
dot11 ssid Corporate
max-associations 64
authentication open
authentication shared
authentication key-management wpa
wpa-psk ascii PasswordKey
interface Dot11Radio0
no ip address
no ip unreachables
no ip proxy-arp
no logging event link-status
logging event subif-link-status
no dot11 extension aironet
encryption mode ciphers tkip
ssid Corporate
channel 2412
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
no ip address
load-interval 30
bridge-group 1
interface BVI1
description == LAN ==
ip address 192.168.26.254 255.255.255.0
ip directed-broadcast
no ip proxy-arp
ip tcp adjust-mss 1412
bridge 1 route ip
This is a configuration with bridge interfaces, one SSID one VLAN on a bridged interface BVI.
If you want more ssids, use subinterfaces on the interface radio and multiple vlans and bridge it together.
Also this config is for wpa-psk, but try to change the encryption mode to your needs.
Cheers
Pedro
Posted by WebUser Pedro Seabra Ávila from Cisco Support Community App
thanks for this
actually i found out what hthe issue is.
it first needs definining ssid on dot1radio and then ssid globally
https://supportforums.cisco.com/docs/DOC-4262
no ip address
no ip route-cache
encryption mode ciphers aes-ccm
encryption vlan 1 mode ciphers tkip
ssid test
dot11 ssid test
ssid test
then the radio comes UP and hten you can add ssid globally
dot11 ssid Test
   authentication open
   authentication key-management wpa version 2
AND i cant create an vlan on the ap itselt - there is no command as int vlan 1 - the only possible thing  i can do is int vlan bvi 1
now second problem, is wpa2 enterprise (authentication with ACS servers on Main site) possible ?
Please let me know
any ideas please?
Create subinterfaces both in dotradio0.x and fast0.x like this. So you can link the SSID to the vlan that you pretend.
Interface BVI1 is for management on vlan 1, and the SSID Corporate its on the VLAN2.
interface BVI1
no ip route-cache
no keepalive
arp timeout 60
exit
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service password-encryption
service sequence-numbers
hostname AP:2_XXXXX
logging buffered 16384 debugging
no logging console
no logging monitor
clock timezone Portugal 0
ip subnet-zero
no ip source-route
no ip gratuitous-arps
ip telnet hidden addresses
no ip domain lookup
aaa new-model
aaa authentication login default local
aaa session-id common
bridge irb
dot11 location isocc pt cc 351 ac 999
dot11 network-map 60
interface Dot11Radio0.1
description Rede Gestao
encapsulation dot1Q 1 native
no ip address
no ip route-cache
bridge-group 1
exit
interface Dot11Radio0.2
description Rede Users
encapsulation dot1Q 2
no ip address
ip access-group 101 in
no ip route-cache
no ip unreachables
no ip proxy-arp
bridge-group 2
bridge-group 2 port-protected
bridge-group 2 subscriber-loop-control
bridge-group 2 block-unknown-source
no bridge-group 2 source-learning
no bridge-group 2 unicast-flooding
bridge-group 2 spanning-disabled
exit
interface FastEthernet0
no ip address
no ip unreachables
no ip proxy-arp
no ip route-cache
speed 10
full-duplex
no keepalive
arp timeout 60
no cdp enable
hold-queue 100 out
exit
interface FastEthernet0.1
no ip address
no ip route-cache
bridge-group 1
exit
interface FastEthernet0.2
no ip address
no ip unreachables
no ip proxy-arp
no ip route-cache
no keepalive
arp timeout 60
no cdp enable
bridge-group 2
exit
no ip address
no ip unreachables
no ip proxy-arp
no ip route-cache
ssid Corporate
world-mode
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
rts threshold 2312
station-role root
rts retries 32
power local cck 50
power client 50
packet retries 32
channel 6
fragment-threshold 2338
payload-encapsulation dot1h
no keepalive
no cdp enable
no short-slot-time
exit
    vlan 2
    max-associations 64
    authentication open
    guest-mode
    exit
ip default-gateway 192.168.1.254
control-plane
bridge 1 route ip
thanks 4023672. its sorted now
