Cisco 891F Configuration Guide
I want to test  some features for CIsco 891F model, I can find a configuration guide but it has details only about some basic things & about Static & Dynamic Routing. It doesn't cover about SNMP, NTP etc . Can anyone help me in finding the proper configuration guide for CISCO 891F router model which could have all the supported features that can be configured for testing .
Mark Elsen
 You could use the link below and get info on functionality with Search This Products' Documentation ; it seems that standard  SNMP and NTP are  supported. Use configuration settings as you can find them in other IOS documentation (e.g.) :
    https://www.cisco.com/c/en/us/support/routers/c891f-integrated-services-routers/model.html
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
