Switch Licence, quarry
kousikdutta
Model is : WS-C3560X-24T-S
Licence is :
Index 1 Feature: ipservices
Period left: 8 weeks 4 days
License Type: Evaluation
License State: Active, Not in Use, EULA not accepted
License Priority: None
License Count: Non-Counted
Index 2 Feature: ipbase
Period left: Life time
License Type: Permanent
License State: Active, In Use
License Priority: Medium
Index 3 Feature: lanbase
Period left: 0 minute 0 second
Is this possible to run ospf protocol of the current licence the switch have.
If I'm reading your posted license information correctly, I believe you only have a permanent license for IPBase which I recall does not support full OSPF (I recall it might support a subset of OSPF for running a version of OSPF on the edge). Further, you could enable (it may already be active with 8 weeks and 4 days left on its "clock") IPServices, under an evaluation license, which should support all the OSPF features the platform supports, but that's would only be an temporary solution.
7 Replies 7
Mark Malone
yes
IP Base: Enterprise Access Layer 3 Switching, including OSPF (Open Shortest Path First) for routed access
Joseph W. Doherty
The full version of OSPF or just a subset? For a limited time or permanently?
Hi Joseph,
That's my quarry, is this licence is enough to run full ospf feature supporyed by Cisco
And one more point. I wanted to to run ospf permanently
Thank you Joseph for your quick response. It's helpful.
Thanks Joseph for your quick response. It's helpful.
