Cisco 9300 - HTTP/HTTPS doesn't work. Help
mik31
Frequent Visitor
Frequent Visitor
So I've enabled HTTP and HTTPS.
I'm able to get to the login page and login. However it takes me to what you would think the main dashboard/website but I only see the Cisco logo and the back button.
I've ran a debug ip http and I am getting the following error. If HTTPS is on or off.
HTTP:Enable sock read
6 Replies 6
Reza Sharifi
Can you post the output of "sh run"?
briankk1582
Frequent Visitor
Frequent Visitor
Did you try a different browser at all?
Yes multiple browsers.
I should add I tried another switch which is a 9200 that behaves the same way at this site.
The the switch offline (off the network) and connect the PC to this switch and see if it works.
Leo Laohoo
Depending on the firmware version, try a different browser, particularly older browser versions.
Mark Elsen
 - Upgrade to advisory software version (if applicable) : https://software.cisco.com/download/home/286315874/type/282046477/release/Amsterdam-17.3.4 . check if that can help.
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
