Cisco 9300 tries to authenticate client MAC and not AP MAC
We have a stack of 2 9300L, running ISE port config.
Wireless APs on site are authenticated via MAC Auth, when authenticated applies a Macro with applicable config
The AP will work fine for a short while, authenticated etc but then the switchport will see a client MAC address and then marks the port as Unauthenticated and causing the AP to drop from the controller.
This only seems to be happening on these 2 9300L, rest of the site is on 3850 running the same setup with no issues
Port config once macro applied:
interface GigabitEthernet2/0/9
description ***** Aerohive Access Point *****
switchport access vlan xxx
switchport trunk native vlan xxx
switchport trunk allowed vlan xxxxxxxxxxxxxxxxxx
switchport trunk allowed vlan add xxxxxxxxxxxxx
switchport mode trunk
switchport nonegotiate
ip flow monitor PrimeNFMon input
no logging event link-status
authentication event fail action next-method
authentication event server dead action authorize
authentication event server alive action reinitialize
authentication host-mode multi-host
authentication order mab dot1x
authentication port-control auto
authentication periodic
authentication timer reauthenticate 1800
authentication violation restrict
mab
no snmp trap link-status
dot1x pae authenticator
dot1x timeout tx-period 3
macro description AEROHIVE_ACCESS_POINT
spanning-tree portfast trunk
8 Replies 8
do you have WLC ?
Yes, but not Cisco its Extreme
then auth via WLC not via SW
it hard what you try here with SW
The clients are supposed to go via the wlc but for some reason they are all getting sent to ISE.
The APs are meant to authenticate via ISE which works fine on other switch models
share the config of other SW
Port config from a 3850:
interface GigabitEthernet1/0/23
switchport access vlan 106
switchport trunk native vlan 910
switchport trunk allowed vlan 150-152,203,207,550-553,805,809,810,815,816,818
switchport trunk allowed vlan add 899,910-918,991-994
mab
end
Mac Address Table
Vlan Mac Address Type Ports
910 c413.e255.d480 STATIC Gi1/0/23
911 c413.e255.d480 DYNAMIC Gi1/0/23
With clients connected, only shows the 2 MACs of the AP - 1 in the native and 1 in the mgmt vlan
9300 port config:
interface GigabitEthernet1/0/10
switchport access vlan 109
authentication host-mode multi-auth
mab
end
 Take a look on this guide. It describe a very similar setup. You may find something missing.
The command  "authentication host-mode multi-host" is there to allow clients mac address to pass through the interface without causing problem but you may be missing something else.
 I assume you have the command "aaa authorization network" right?
https://www.cisco.com/c/en/us/support/docs/wireless/wireless-lan-controller-software/200492-Securing-a-flexconnect-AP-switchport-wit.html
I enabled command authentication host-mode multi-host on one of the switchports, what its doing now is authenticating the MAC of the AP for the native vlan but dropping all else. I am unsure why it is sending all clients to ISE
551 1002.b595.0277 DYNAMIC Drop
551 b89a.2aaa.9ee8 DYNAMIC Drop
910 c413.e25a.8d40 STATIC Gi1/0/10
911 c413.e25a.8d40 DYNAMIC Drop
991 6204.e7eb.b5ac DYNAMIC Drop
991 6634.a264.555f DYNAMIC Drop
991 e0d0.8329.e9e5 DYNAMIC Drop
