Cisco 9300 WebUI Provision?
barrybulbtas
I'm trying to follow the documentation here in order to get the best practice configuration on a new 9300:
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9300/hardware/install/b_c9300_hig/b_c9300_hig_chapter_01000.html
It's not working however, sometimes the switch will provide a dhcp lease to my laptop but not allow me to connect to webui with the default credentials.
I've factory reset and loaded the latest firmware on the switch, however still the same result.
Alternatively, has anyone got a configuration template they use for a single uplink switch?  I'm coming back to Cisco after spending time with Extreme's and HPs, would be nice to follow best practice.
Thanks in advance!
destru2348
Bought the new Cisco Catalyst 9200 had the same issues, here is my solution.
Create a new User, since there is no cisco user neither webui created on the switch:
get putty (https://putty.org/)
connect via com port to console (Serial)
switch> enable
switch# conf ter
switch# username YOURUSER privilege 15 password 0 YOURPASSWORD
Connect to your switch via LAN:
set your Network Adapter to ip: 192.168.1.5
open browser
open https://192.168.1.1
enter YOURUSER enter YOURPASSWORD
click the button
finally
P.S. DHCP is not running either
Hi .hope it’s ok to join this thread.
I also have the 0day webui problem with passwords. I tried to create new level 15 password as you described.but keep getting an notes that 0 passwords are no longer supported
Factory default all and stared again serval times
any help would be appreciated lots
