Cisco 9300 Wired QoS Policy for MS Teams - IOS-XE 17.6.3
DLGNOC
Good afternoon, we have a 1Gb/s internet circuit, which, for reasons we fully understand often gets fully utilised due to business need.
All switches are 9300s' running 17.6.3
We dont currently have a QoS policy on the wired network (Wireless is another matter)
During times of peak congestion, we have MS Teams Audio/Video issues, and thus was to implement a basic policy to
A) Mark traffic at the access port, only for MS Teams
B) Prioritise traffic on DSCP value at the WAN edge.
C) All other traffic will be marked down to DSCP default inbound/outbound
We dont intend to do any priority queueing upstream from access to core as links are in 20Gb/s etherchannel and utilisation never goes above 10%, plus DSCP is honoured by default on the 9300 platform.
Core switch is connected via LAG to our edge firewalls, which terminate the 1Gb/s WAN circuit.
Would anyone be able to state whether this looks reasonable please?
Access Switch - Class Maps
class-map match-any ms-teams-audio
match protocol ms-teams-audio
class-map match-any ms-teams-video
match protocol ms-teams-video
class-map match-any ms-teams-share
match protocol ms-teams-app-sharing
Access Switch - Policy Map
policy-map ms-teams-access-port
class ms-teams-audio
 set dscp ef
class ms-teams-video
 set dscp af41
class ms-teams-share
 set dscp af21
class class-default
 set dscp default
Access Switch - Interface
interface GigabitEthernet1/0/1
switchport access vlan 100
switchport mode access
spanning-tree portfast
service-policy input ms-teams-access-port
service-policy output ms-teams-access-port
Core Switch - Class Maps
class-map match-any ms-teams-audio-dscp
match dscp ef
class-map match-any ms-teams-video-dscp
match dscp af41
class-map match-any ms-teams-share-dscp
match dscp 21
Core Switch - Policy Maps
policy-map ms-teams-wan-outbound
class ms-teams-audio-dscp
  priority level 1
  police rate percent 10
class ms-teams-video-dscp
  priority level 2
  police rate percent 20
class ms-teams-share-dscp
  bandwidth remaining percent 15
  queue-buffers ratio 15
class class-default
  bandwidth remaining percent 25
  queue-buffers ratio 25
Core Switch - WAN Uplink
interface Port-channel1
 switchport access vlan 4093
 switchport nonegotiate
 service-policy output ms-teams-wan-outbound
5 Replies 5
Thank you for your completely useless answer.
I don’t wish to use AutoQos, i have no intent on classifying, marking or prioritising any other traffic apart from MS Teams, you haven’t even taken note of my comments.
Jubei
I'm having the same issue as well, did your configurations work?
gghai
Did it work? I'm setting up something similar
If @DLGNOC doesn't respond, in answer to his original question, "Would anyone be able to state whether this looks reasonable please?", yes it's, IMO, reasonable.  (Possibly I missed original posting and the @Jubei follow up - but that's surprising, as I have special interest in QoS - possibly his response to @Jitendra Kumar 's reply is why I didn't reply before.)
Could this approach be better?  Possibly.
May it require, not just benefit from, changes?  Also possibly.
