Cisco 9410 with dual sup engines software upgrade question
Neuromancer
I'm planning to upgrade from 16.9.4 to 16.9.5. I don't care about ISSU since I'm doing it during a maintenance window. Has anybody performed this before?
I read the release notes here but am looking for a sanity check that I'm following the right procedure: https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9400/software/release/16-9/release_notes/ol-16-9-9400.html#id_67619
1) Copy the image to the primary sup engine
2) Use the following command: install add file bootflash:filename activate commit
3) The switch will automatically copy the image from the primary sup engine to the secondary.
4) The upgrade process will continue and eventually reboot then it will be finished.
Step 3 is what I'm looking to confirm. I'm used to the old days where you had to manually copy the image to both sup engines. Any feedback would be appreciated.
Reza Sharifi
No, it is not done automatically. You would need to do it manually form primary sup to secondary.
example:
copy bootflash:<ios> stby-bootflash:<ios>
balaji.bandi
here is the good document still valid for dual supervisors :
https://www.cisco.com/c/en/us/support/docs/ip/trivial-file-transfer-protocol-tftp/212470-catalyst-9400-upgrading-dual-supervisor.html
BB
