Cisco 9500-16X-E Not booting into Exec mode
pappyjjboi1
The switch is not still booting to the exec mode ......it hangs as in the attached image. when i press enter or no ..it doesn't go further. Pls help
10 Replies 10
Mark Elsen
           - And what happens if you answer yes ?
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Can't press yes or no. Just hang
Leo Laohoo
Check the console settings.
I've checked it very well no headway
9600 baud
• 8 data bits
• 1 stop bit
• No parity
• None (flow control)
What happens if you use an ordinary USB to micro-USB as a console?
pappyjjboi1
Can't access through web as well but I could get management IP through dhcp from d switch.
 - That's a bit irrelevant at this stage , you need to get the basic configuration done first , as prompted on the console. What is your console terminal/operator  equipment look like ?
 M.
       Beauty and terror
      Just keep going
       No feeling is final
I used this same cable forthe other  C9200 nd it work fine
          - For sanity reasons, try to use a native cisco console cable. Usually gets delivered with the device (too).
 M.
       Beauty and terror
      Just keep going
       No feeling is final
pappyjjboi1
@Mark Elsen...the switch later boot successfully after several tries.
Thanks everybody
