Cisco 9500-48Y4C core and access switch Connectivity Issue
fikadu abdisa
I have recently deployed 2 cisco 9500-48Y4C core switches and a stackwise virtualization configuration is implemented on the core switches. but the some ports of the second core switch on the stack didn't send normal user traffic when an SFP is connected to it. that same SFP is working on the 1st core switch.
anyone who faced such issues?
6 Replies 6
Reza Sharifi
What version of IOS are you running? Also, can you post the output of "show run"?
INU-COLL_CORE-SW-01#sh run
Building configuration...
Current configuration : 32775 bytes
! Last configuration change at 09:22:33 UTC Wed May 3 2023
version 17.3
service password-encryption
service call-home
platform punt-keepalive disable-kernel-core
hostname INU-COLL_CORE-SW-01
vrf definition Mgmt-vrf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
enable secret 9 $9$kDC98jwCbpXqIE$GIK.I4MnQxbMXQmYKxLsd4Tw2DHDewduYdT1B2VelCw
aaa new-model
aaa authentication login default local enable
aaa session-id common
clock timezone UTC 3 0
switch 1 provision c9500-48y4c
switch 2 provision c9500-48y4c
boot system bootflash:packages.conf
fhrp version vrrp v3
stackwise-virtual
domain 100
no ip domain lookup
ip domain name admin.local
ip dhcp excluded-address 172.16.2.1 172.16.3.254
ip dhcp excluded-address 172.16.4.1 172.16.4.20
ip dhcp excluded-address 172.16.11.1 172.16.11.254
ip dhcp excluded-address 172.16.12.1 172.16.12.20
ip dhcp excluded-address 172.16.17.1 172.16.17.254
ip dhcp excluded-address 172.16.19.1 172.16.19.254
ip dhcp excluded-address 172.16.23.1 172.16.23.254
ip dhcp excluded-address 172.16.25.1 172.16.25.254
ip dhcp excluded-address 172.16.27.1 172.16.27.254
ip dhcp excluded-address 172.16.29.1 172.16.29.254
ip dhcp excluded-address 172.16.31.1 172.16.31.254
ip dhcp excluded-address 172.16.33.1 172.16.33.254
ip dhcp excluded-address 172.16.35.1 172.16.35.254
ip dhcp excluded-address 172.16.37.1 172.16.37.254
ip dhcp excluded-address 172.16.39.1 172.16.39.254
ip dhcp excluded-address 172.16.41.1 172.16.41.254
ip dhcp excluded-address 172.16.42.1 172.16.42.20
ip dhcp excluded-address 172.16.44.1 172.16.44.20
ip dhcp excluded-address 172.16.46.1 172.16.46.20
ip dhcp excluded-address 172.16.48.1 172.16.48.20
ip dhcp excluded-address 172.16.50.1 172.16.50.20
ip dhcp excluded-address 172.16.52.1 172.16.52.20
ip dhcp excluded-address 172.16.84.1 172.16.84.20
ip dhcp excluded-address 172.16.6.1 172.16.6.20
ip dhcp excluded-address 172.16.14.1 172.16.14.40
ip dhcp excluded-address 172.16.128.1 172.16.128.20
ip dhcp excluded-address 172.16.130.1 172.16.130.20
ip dhcp excluded-address 172.16.132.1 172.16.132.20
ip dhcp excluded-address 172.16.136.1 172.16.136.20
ip dhcp excluded-address 172.16.21.151 172.16.21.254
ip dhcp excluded-address 172.16.20.151 172.16.20.199
ip dhcp excluded-address 172.16.160.0 172.16.160.50
ip dhcp pool VLAN02
network 172.16.2.0 255.255.254.0
domain-name inu.edu.et
default-router 172.16.2.1
dns-server 172.16.2.7 213.55.96.166 8.8.8.8
ip dhcp pool VLAN04
network 172.16.4.0 255.255.254.0
default-router 172.16.4.1
ip dhcp pool VLAN06
network 172.16.6.0 255.255.254.0
default-router 172.16.6.1
ip dhcp pool VLAN08
network 172.16.8.0 255.255.254.0
default-router 172.16.8.1
ip dhcp pool VLAN10
network 172.16.10.0 255.255.254.0
default-router 172.16.10.1
ip dhcp pool VLAN12
network 172.16.12.0 255.255.254.0
default-router 172.16.12.1
ip dhcp pool VLAN14
network 172.16.14.0 255.255.254.0
default-router 172.16.14.1
lease 0 12
ip dhcp pool VLAN16
network 172.16.16.0 255.255.254.0
default-router 172.16.16.1
ip dhcp pool VLAN18
network 172.16.18.0 255.255.254.0
default-router 172.16.18.1
ip dhcp pool VLAN20
network 172.16.20.0 255.255.254.0
default-router 172.16.20.1
ip dhcp pool VLAN22
network 172.16.22.0 255.255.254.0
default-router 172.16.22.1
ip dhcp pool VLAN24
network 172.16.24.0 255.255.254.0
default-router 172.16.24.1
ip dhcp pool VLAN26
network 172.16.26.0 255.255.254.0
default-router 172.16.26.1
ip dhcp pool VLAN28
network 172.16.28.0 255.255.254.0
default-router 172.16.28.1
ip dhcp pool VLAN30
network 172.16.30.0 255.255.254.0
default-router 172.16.30.1
ip dhcp pool VLAN32
network 172.16.32.0 255.255.254.0
default-router 172.16.32.1
ip dhcp pool VLAN34
network 172.16.34.0 255.255.254.0
default-router 172.16.34.1
ip dhcp pool VLAN36
network 172.16.36.0 255.255.254.0
default-router 172.16.36.1
ip dhcp pool VLAN38
network 172.16.38.0 255.255.254.0
default-router 172.16.38.1
ip dhcp pool VLAN40
network 172.16.40.0 255.255.254.0
default-router 172.16.40.1
ip dhcp pool VLAN42
network 172.16.42.0 255.255.254.0
default-router 172.16.42.1
ip dhcp pool VLAN44
network 172.16.44.0 255.255.254.0
default-router 172.16.44.1
ip dhcp pool VLAN46
network 172.16.46.0 255.255.254.0
default-router 172.16.46.1
ip dhcp pool VLAN48
network 172.16.48.0 255.255.254.0
default-router 172.16.48.1
ip dhcp pool VLAN50
network 172.16.50.0 255.255.254.0
default-router 172.16.50.1
ip dhcp pool VLAN52
network 172.16.52.0 255.255.254.0
default-router 172.16.52.1
ip dhcp pool VLAN84
network 172.16.84.0 255.255.254.0
default-router 172.16.84.1
ip dhcp pool VLAN128
network 172.16.128.0 255.255.254.0
default-router 172.16.128.1
ip dhcp pool VLAN130
network 172.16.130.0 255.255.254.0
default-router 172.16.130.1
ip dhcp pool VLAN132
network 172.16.132.0 255.255.252.0
default-router 172.16.132.1
ip dhcp pool VLAN136
network 172.16.136.0 255.255.252.0
default-router 172.16.136.1
ip dhcp pool INU-STUDENT-WLAN
network 172.16.160.0 255.255.224.0
default-router 172.16.160.1
dns-server 213.55.96.166 8.8.8.8
lease 0 23 59
login on-success log
no device-tracking logging theft
wireless-controller
crypto pki trustpoint TP-self-signed-4005660614
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-4005660614
revocation-check none
rsakeypair TP-self-signed-4005660614
crypto pki trustpoint SLA-TrustPoint
enrollment terminal
revocation-check crl
crypto pki certificate chain TP-self-signed-4005660614
certificate self-signed 01
30820330 30820218 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 34303035 36363036 3134301E 170D3231 31323136 30333137
34345A17 0D333131 32313630 33313734 345A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D34 30303536
36303631 34308201 22300D06 092A8648 86F70D01 01010500 0382010F 00308201
0A028201 0100A58E 89301999 7DCE2644 371A4AC6 7760D6DC 657AE164 4E3A5087
C0D3F30B 2C49B603 C5AA006F EF71F51D 76874F63 F0CAEC87 188C1A9B 3FB443FA
DB79D388 3420116C 63A65B20 013D98C7 2AE3DB65 E20CD7AE 381C913A AE74DE13
9715BEAA 27E37C60 D10666B7 1E53F65A 07D301D8 943AB175 ED75E514 F39DE6C7
811EBD36 9FCC78B2 B5FF7AE6 34E0B7C6 6552EBA9 4768170B 3DF46D02 37782496
90C53796 4BCDF63D 4ED8A9E2 A064C313 B82DF581 25D26EA5 B6B2C167 643D4A16
0CC04EF7 BF79D1E5 50DEFE09 5EF1E3D3 9D93D34F 81B2048D 5531A519 3F134888
57F40252 D9EF2382 1EEB4491 020E87A4 28013ACB EEAC9F4F CC9C2168 F3FD2CF0
0D965BB0 EB850203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF
301F0603 551D2304 18301680 14AF3C34 6EE0CCE6 5B86CCD2 AF48481C F810D343
77301D06 03551D0E 04160414 AF3C346E E0CCE65B 86CCD2AF 48481CF8 10D34377
300D0609 2A864886 F70D0101 05050003 82010100 40EF6ADC A8303658 4F1E5665
E745A494 4083BC1B C0F70E45 53FE5967 F501B770 84DA7869 0DE6CF3E 45C6DC26
A98BCD50 3EBA0D9B A6C4718E 1CDB3040 5A6A01E6 5FC09E3B 2263616E 14A83B96
190B4D84 FDE39DD8 D35E2103 73297CED 2FBCA991 2BBEC041 F55EC24F 227996BF
D2C4411F 2E0B0922 F5A8F1C8 48D021D3 16DA851C 68E2E095 35CD43EB 54793E22
187B85FE 5CFE1E87 600FDEE4 45CDC473 F7122AF6 E1DEEFBF CCD7066E 09CFE9E0
B02C5F5A 2591683A 541D2267 86EF4076 56E3D9F3 A19EDE8B 6B74CCB2 E5DFF658
FA6DCFF5 A28158B8 2719A4F1 F0887CD1 8083EC84 51F34527 37B67EF1 F6B15FEA
B6533EB3 221F5F0A 4F86900B 58B5E0AD 81155B1E
quit
crypto pki certificate chain SLA-TrustPoint
certificate ca 01
30820321 30820209 A0030201 02020101 300D0609 2A864886 F70D0101 0B050030
32310E30 0C060355 040A1305 43697363 6F312030 1E060355 04031317 43697363
6F204C69 63656E73 696E6720 526F6F74 20434130 1E170D31 33303533 30313934
3834375A 170D3338 30353330 31393438 34375A30 32310E30 0C060355 040A1305
43697363 6F312030 1E060355 04031317 43697363 6F204C69 63656E73 696E6720
526F6F74 20434130 82012230 0D06092A 864886F7 0D010101 05000382 010F0030
82010A02 82010100 A6BCBD96 131E05F7 145EA72C 2CD686E6 17222EA1 F1EFF64D
CBB4C798 212AA147 C655D8D7 9471380D 8711441E 1AAF071A 9CAE6388 8A38E520
1C394D78 462EF239 C659F715 B98C0A59 5BBB5CBD 0CFEBEA3 700A8BF7 D8F256EE
4AA4E80D DB6FD1C9 60B1FD18 FFC69C96 6FA68957 A2617DE7 104FDC5F EA2956AC
7390A3EB 2B5436AD C847A2C5 DAB553EB 69A9A535 58E9F3E3 C0BD23CF 58BD7188
68E69491 20F320E7 948E71D7 AE3BCC84 F10684C7 4BC8E00F 539BA42B 42C68BB7
C7479096 B4CB2D62 EA2F505D C7B062A4 6811D95B E8250FC4 5D5D5FB8 8F27D191
C55F0D76 61F9A4CD 3D992327 A8BB03BD 4E6D7069 7CBADF8B DF5F4368 95135E44
DFC7C6CF 04DD7FD1 02030100 01A34230 40300E06 03551D0F 0101FF04 04030201
06300F06 03551D13 0101FF04 05300301 01FF301D 0603551D 0E041604 1449DC85
4B3D31E5 1B3E6A17 606AF333 3D3B4C73 E8300D06 092A8648 86F70D01 010B0500
03820101 00507F24 D3932A66 86025D9F E838AE5C 6D4DF6B0 49631C78 240DA905
604EDCDE FF4FED2B 77FC460E CD636FDB DD44681E 3A5673AB 9093D3B1 6C9E3D8B
D98987BF E40CBD9E 1AECA0C2 2189BB5C 8FA85686 CD98B646 5575B146 8DFC66A8
467A3DF4 4D565700 6ADF0F0D CF835015 3C04FF7C 21E878AC 11BA9CD2 55A9232C
7CA7B7E6 C1AF74F6 152E99B7 B1FCF9BB E973DE7F 5BDDEB86 C71E3B49 1765308B
5FB0DA06 B92AFE7F 494E8A9E 07B85737 F3A58BE1 1A48A229 C37C1E69 39F08678
80DDCD16 D6BACECA EEBC7CF9 8428787B 35202CDC 60E4616A B623CDBD 230E3AFB
418616A9 4093E049 4D10AB75 27E86F73 932E35B5 8862FDAE 0275156F 719BB2F0
D697DF7F 28
quit
license boot level network-advantage addon dna-advantage
diagnostic bootup level complete
spanning-tree mode rapid-pvst
memory free low-watermark processor 290409
no errdisable detect cause gbic-invalid
errdisable recovery cause udld
errdisable recovery cause bpduguard
errdisable recovery cause security-violation
errdisable recovery cause channel-misconfig
errdisable recovery cause pagp-flap
errdisable recovery cause dtp-flap
errdisable recovery cause link-flap
errdisable recovery cause sfp-config-mismatch
errdisable recovery cause gbic-invalid
errdisable recovery cause l2ptguard
errdisable recovery cause psecure-violation
errdisable recovery cause port-mode-failure
errdisable recovery cause dhcp-rate-limit
errdisable recovery cause pppoe-ia-rate-limit
errdisable recovery cause mac-limit
errdisable recovery cause storm-control
errdisable recovery cause inline-power
errdisable recovery cause arp-inspection
errdisable recovery cause link-monitor-failure
errdisable recovery cause oam-remote-failure
username admin privilege 15 password 7 0519570C285F4D064B554540
redundancy
mode sso
transceiver type all
monitoring
lldp run
class-map match-any system-cpp-police-ewlc-control
description EWLC Control
class-map match-any system-cpp-police-topology-control
description Topology control
class-map match-any system-cpp-police-sw-forward
description Sw forwarding, L2 LVX data packets, LOGGING, Transit Traffic
class-map match-any system-cpp-default
description EWLC Data, Inter FED Traffic
class-map match-any system-cpp-police-sys-data
description Openflow, Exception, EGR Exception, NFL Sampled Data, RPF Failed
class-map match-any system-cpp-police-punt-webauth
description Punt Webauth
class-map match-any system-cpp-police-l2lvx-control
description L2 LVX control packets
class-map match-any system-cpp-police-forus
description Forus Address resolution and Forus traffic
class-map match-any system-cpp-police-multicast-end-station
description MCAST END STATION
class-map match-any system-cpp-police-high-rate-app
description High Rate Applications
description MCAST Data
class-map match-any system-cpp-police-l2-control
description L2 control
class-map match-any system-cpp-police-dot1x-auth
description DOT1X Auth
class-map match-any system-cpp-police-data
description ICMP redirect, ICMP_GEN and BROADCAST
class-map match-any system-cpp-police-stackwise-virt-control
description Stackwise Virtual OOB
class-map match-any non-client-nrt-class
class-map match-any system-cpp-police-routing-control
description Routing control and Low Latency
class-map match-any system-cpp-police-protocol-snooping
description Protocol snooping
class-map match-any system-cpp-police-dhcp-snooping
description DHCP snooping
class-map match-any system-cpp-police-ios-routing
description L2 control, Topology control, Routing control, Low Latency
class-map match-any system-cpp-police-system-critical
description System Critical and Gold Pkt
class-map match-any system-cpp-police-ios-feature
description ICMPGEN,BROADCAST,ICMP,L2LVXCntrl,ProtoSnoop,PuntWebauth,MCASTData,Transit,DOT1XAuth,Swfwd,LOGGING,L2LVXData,ForusTraffic,ForusARP,McastEndStn,Openflow,Exception,EGRExcption,NflSampled,RpfFailed
policy-map system-cpp-policy
interface Loopback0
description EWC-loopback0
ip address 2.2.2.2 255.255.255.255
interface Loopback1
ip address 1.1.1.1 255.255.255.255
interface Port-channel1
description POC-LINK-TO-CORE-SW
switchport mode trunk
interface Port-channel11
description POC-LINK-TO_ICT-AS-GD-FL
interface Port-channel12
description POC-LINK-TO_ACC_SW
interface Port-channel14
interface Port-channel15
interface Port-channel16
interface Port-channel18
interface Port-channel19
interface Port-channel20
interface Port-channel21
interface Port-channel22
interface Port-channel23
interface Port-channel24
interface Port-channel100
description POC-LINK-TO-FW01
switchport access vlan 100
switchport mode access
interface Port-channel101
description POC-LINK-TO-FW02
interface GigabitEthernet0/0
vrf forwarding Mgmt-vrf
no ip address
negotiation auto
interface TwentyFiveGigE1/0/1
description POC-100-LINK-TO-FW01
channel-group 100 mode active
interface TwentyFiveGigE1/0/2
description POC-101-LINK-TO-FW02
channel-group 101 mode active
interface TwentyFiveGigE1/0/3
description DOWN-link-to-ACC-ICT-AS-GD-FL
channel-group 11 mode active
interface TwentyFiveGigE1/0/4
description DOWN-link-to-ACC-ICT-AS-1ST-FL
channel-group 12 mode active
interface TwentyFiveGigE1/0/5
description DOWN-link-to-ACC-ICT-AS-2ND-FL
interface TwentyFiveGigE1/0/6
description DOWN-link-to-ACC-ICT-AS-3RD-FL
channel-group 14 mode active
interface TwentyFiveGigE1/0/7
description DOWN-link-to-ACC-ICT-AS-4TH-FL
channel-group 15 mode active
interface TwentyFiveGigE1/0/8
description DOWN-link-to-ACC-REG-AS-GD-FL
channel-group 16 mode active
interface TwentyFiveGigE1/0/9
interface TwentyFiveGigE1/0/10
description DOWN-link-to-ACC-REG-AS-2ND-FL
channel-group 18 mode active
interface TwentyFiveGigE1/0/11
description DOWN-link-to-ACC-REG-AS-3RD-FL
channel-group 19 mode active
interface TwentyFiveGigE1/0/12
description DOWN-link-to-ACC-REG-AS-4TH-FL
channel-group 20 mode active
interface TwentyFiveGigE1/0/13
description DOWN-link-to-ACC-MAIN-STORE-AS-GD-FL
channel-group 21 mode active
interface TwentyFiveGigE1/0/14
description DOWN-link-to-ACC-LIB-AS-GD-FL
channel-group 22 mode active
interface TwentyFiveGigE1/0/15
description DOWN-link-to-ACC-LIB-AS-1ST-FL
channel-group 23 mode active
interface TwentyFiveGigE1/0/16
description DOWN-link-to-ACC-LIB-AS-2ND-FL
channel-group 24 mode active
interface TwentyFiveGigE1/0/17
interface TwentyFiveGigE1/0/18
interface TwentyFiveGigE1/0/19
interface TwentyFiveGigE1/0/20
interface TwentyFiveGigE1/0/21
interface TwentyFiveGigE1/0/22
interface TwentyFiveGigE1/0/23
interface TwentyFiveGigE1/0/24
interface TwentyFiveGigE1/0/25
interface TwentyFiveGigE1/0/26
interface TwentyFiveGigE1/0/27
interface TwentyFiveGigE1/0/28
interface TwentyFiveGigE1/0/29
interface TwentyFiveGigE1/0/30
interface TwentyFiveGigE1/0/31
interface TwentyFiveGigE1/0/32
interface TwentyFiveGigE1/0/33
interface TwentyFiveGigE1/0/34
interface TwentyFiveGigE1/0/35
interface TwentyFiveGigE1/0/36
interface TwentyFiveGigE1/0/37
interface TwentyFiveGigE1/0/38
interface TwentyFiveGigE1/0/39
interface TwentyFiveGigE1/0/40
interface TwentyFiveGigE1/0/41
interface TwentyFiveGigE1/0/42
interface TwentyFiveGigE1/0/43
interface TwentyFiveGigE1/0/44
interface TwentyFiveGigE1/0/45
interface TwentyFiveGigE1/0/46
stackwise-virtual link 1
interface TwentyFiveGigE1/0/47
interface TwentyFiveGigE1/0/48
stackwise-virtual dual-active-detection
interface HundredGigE1/0/49
interface HundredGigE1/0/50
interface HundredGigE1/0/51
interface HundredGigE1/0/52
interface TwentyFiveGigE2/0/1
interface TwentyFiveGigE2/0/2
interface TwentyFiveGigE2/0/3
interface TwentyFiveGigE2/0/4
interface TwentyFiveGigE2/0/5
interface TwentyFiveGigE2/0/6
interface TwentyFiveGigE2/0/7
interface TwentyFiveGigE2/0/8
interface TwentyFiveGigE2/0/9
interface TwentyFiveGigE2/0/10
interface TwentyFiveGigE2/0/11
interface TwentyFiveGigE2/0/12
interface TwentyFiveGigE2/0/13
interface TwentyFiveGigE2/0/14
interface TwentyFiveGigE2/0/15
interface TwentyFiveGigE2/0/16
interface TwentyFiveGigE2/0/17
interface TwentyFiveGigE2/0/18
interface TwentyFiveGigE2/0/19
interface TwentyFiveGigE2/0/20
interface TwentyFiveGigE2/0/21
interface TwentyFiveGigE2/0/22
interface TwentyFiveGigE2/0/23
interface TwentyFiveGigE2/0/24
interface TwentyFiveGigE2/0/25
interface TwentyFiveGigE2/0/26
interface TwentyFiveGigE2/0/27
interface TwentyFiveGigE2/0/28
interface TwentyFiveGigE2/0/29
interface TwentyFiveGigE2/0/30
interface TwentyFiveGigE2/0/31
interface TwentyFiveGigE2/0/32
interface TwentyFiveGigE2/0/33
interface TwentyFiveGigE2/0/34
interface TwentyFiveGigE2/0/35
interface TwentyFiveGigE2/0/36
interface TwentyFiveGigE2/0/37
interface TwentyFiveGigE2/0/38
interface TwentyFiveGigE2/0/39
interface TwentyFiveGigE2/0/40
interface TwentyFiveGigE2/0/41
interface TwentyFiveGigE2/0/42
interface TwentyFiveGigE2/0/43
interface TwentyFiveGigE2/0/44
interface TwentyFiveGigE2/0/45
interface TwentyFiveGigE2/0/46
interface TwentyFiveGigE2/0/47
interface TwentyFiveGigE2/0/48
interface HundredGigE2/0/49
interface HundredGigE2/0/50
interface HundredGigE2/0/51
interface HundredGigE2/0/52
interface Vlan1
no ip address
shutdown
interface Vlan2
description INU-SIMS-SVI
ip address 172.16.2.1 255.255.254.0
interface Vlan4
description INU-REG-SVI
ip address 172.16.4.1 255.255.254.0
interface Vlan6
description INU-LIB-SVI
ip address 172.16.6.1 255.255.254.0
interface Vlan8
description INU-HR-SVI
ip address 172.16.8.1 255.255.254.0
interface Vlan10
description INU-ADMIN-SVI
ip address 172.16.10.1 255.255.254.0
interface Vlan12
description INU-MAIN-LAB-SVI
ip address 172.16.12.1 255.255.254.0
interface Vlan14
description INU-ICT-SVI
ip address 172.16.14.1 255.255.254.0
interface Vlan16
description INU-MINI-LAB-SVI
ip address 172.16.16.1 255.255.254.0
interface Vlan18
description INU-STUD-LOUNGE-SVI
ip address 172.16.18.1 255.255.254.0
interface Vlan20
description INU-MGMT_SVI
ip address 172.16.20.1 255.255.254.0
interface Vlan22
description INU-STAFF-LOUNGE-SVI
ip address 172.16.22.1 255.255.254.0
interface Vlan24
description INU-CHS-SVI
ip address 172.16.24.1 255.255.254.0
interface Vlan26
description INU-STEM-CENTER-SVI
ip address 172.16.26.1 255.255.254.0
interface Vlan28
description INU-CLINIC-SVI
ip address 172.16.28.1 255.255.254.0
interface Vlan30
description INU-CL-ROOM-01-SVI
ip address 172.16.30.1 255.255.254.0
interface Vlan32
description INU-CMHS-AS-GD-SVI
ip address 172.16.32.1 255.255.254.0
interface Vlan34
description INU-CL-ROOM-03-SVI
ip address 172.16.34.1 255.255.254.0
interface Vlan36
description INU-CL-ROOM-04-SVI
ip address 172.16.36.1 255.255.254.0
interface Vlan38
description INU-STUD-CAFE-SVI
ip address 172.16.38.1 255.255.254.0
interface Vlan40
description INU-MAIN-GATE-SVI
ip address 172.16.40.1 255.255.254.0
interface Vlan42
description INU-STORE-SVI
ip address 172.16.42.1 255.255.254.0
interface Vlan44
description INU-DORM-01-SVI
ip address 172.16.44.1 255.255.254.0
interface Vlan46
description INU-DORM-02-SVI
ip address 172.16.46.1 255.255.254.0
interface Vlan48
description INU-DORM-03-SVI
ip address 172.16.48.1 255.255.254.0
interface Vlan50
description INU-DORM-04-SVI
ip address 172.16.50.1 255.255.254.0
interface Vlan52
description INU-DORM-05-SVI
ip address 172.16.52.1 255.255.254.0
interface Vlan54
description INU-DORM-06-SVI
ip address 172.16.54.1 255.255.254.0
interface Vlan56
description INU-DORM-07-SVI
ip address 172.16.56.1 255.255.254.0
interface Vlan58
description INU-DORM-08-SVI
ip address 172.16.58.1 255.255.254.0
interface Vlan60
description INU-DORM-09-SVI
ip address 172.16.60.1 255.255.254.0
interface Vlan62
description INU-DORM-10-SVI
ip address 172.16.62.1 255.255.254.0
interface Vlan64
description INU-DORM-11-SVI
ip address 172.16.64.1 255.255.254.0
interface Vlan66
description INU-SEMINAR-01-SVI
ip address 172.16.66.1 255.255.254.0
interface Vlan68
description INU-SEMINAR-02-SVI
ip address 172.16.68.1 255.255.254.0
interface Vlan70
description INU-ADMIN-01-SVI
ip address 172.16.70.1 255.255.254.0
interface Vlan72
description INU-RES-SVI-01
ip address 172.16.72.1 255.255.254.0
interface Vlan74
description INU-RES-SVI-02
ip address 172.16.74.1 255.255.254.0
interface Vlan76
description INU-RES-SVI-03
ip address 172.16.76.1 255.255.254.0
interface Vlan78
description INU-RES-SVI-04
ip address 172.16.78.1 255.255.254.0
interface Vlan80
description INU-RES-SVI-05
ip address 172.16.80.1 255.255.254.0
interface Vlan82
description INU-RES-SVI-06
ip address 172.16.82.1 255.255.254.0
interface Vlan84
description INU-RES-SVI-07
ip address 172.16.84.1 255.255.254.0
interface Vlan86
description INU-RES-SVI-08
ip address 172.16.86.1 255.255.254.0
interface Vlan88
description INU-RES-SVI-09
ip address 172.16.88.1 255.255.254.0
interface Vlan90
description INU-RES-SVI-10
ip address 172.16.90.1 255.255.254.0
interface Vlan92
description INU-RES-SVI-11
ip address 172.16.92.1 255.255.254.0
interface Vlan94
description INU-RES-SVI-12
ip address 172.16.94.1 255.255.254.0
interface Vlan100
ip address 172.16.100.2 255.255.255.248
ip ospf 1 area 0
interface Vlan128
ip address 172.16.128.1 255.255.252.0
interface Vlan136
ip address 172.16.136.1 255.255.248.0
interface Vlan160
ip address 172.16.160.1 255.255.224.0
router ospf 1
router-id 1.1.1.1
network 172.16.0.0 0.0.255.255 area 0
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
control-plane
service-policy input system-cpp-policy
banner login ^CAUTHORISED ACCESS ONLY!
UNAUTHORISED ACCESS TO THIS DEVICE IS PROHIBITED.
NETWORK AND SYSTEM ADMINISTRATOR TEAM
INJIBARA UNIVERSITY^C
banner motd ^C
You must have explicit permission to access this device. All activities performed on this device
are logged and violations of this policy will result in disciplinary and/or legal action.
NETWORK AND SYSTEM ADMINISTRATOR TEAM | INJIBARA UNIVERSITY
^C
line con 0
exec-timeout 0 0
password 7 02050D4808095D711E1C
stopbits 1
line aux 0
stopbits 1
line vty 0 4
password 7 0214555802150C2E1E1E5B4B0B
transport input ssh
line vty 5 15
transport input ssh
call-home
! If contact email address in call-home is configured as sch-smart-licensing@cisco.com
! the email address configured in Cisco Smart License Portal will be used as contact email address to send SCH notifications.
contact-email-addr sch-smart-licensing@cisco.com
profile "CiscoTAC-1"
active
destination transport-method http
wireless aaa policy default-aaa-policy
wireless cts-sxp profile default-sxp-profile
wireless profile airtime-fairness default-atf-policy 0
wireless profile flex default-flex-profile
description "default flex profile"
wireless profile mesh default-mesh-profile
description "default mesh profile"
wireless profile policy default-policy-profile
description "default policy profile"
wireless tag site default-site-tag
description "default site tag"
wireless tag policy default-policy-tag
description "default policy-tag"
wireless tag rf default-rf-tag
description "default RF tag"
wireless fabric control-plane default-control-plane
ap dot11 24ghz rf-profile Low_Client_Density_rf_24gh
coverage data rssi threshold -90
coverage level 2
coverage voice rssi threshold -90
description "pre configured Low Client Density rfprofile for 2.4gh radio"
high-density rx-sop threshold low
rate RATE_12M supported
rate RATE_24M supported
rate RATE_6M supported
tx-power v1 threshold -65
no shutdown
ap dot11 24ghz rf-profile High_Client_Density_rf_24gh
description "pre configured High Client Density rfprofile for 2.4gh radio"
high-density rx-sop threshold medium
rate RATE_11M disable
rate RATE_12M mandatory
rate RATE_1M disable
rate RATE_2M disable
rate RATE_5_5M disable
rate RATE_6M disable
tx-power min 7
no shutdown
ap dot11 24ghz rf-profile Typical_Client_Density_rf_24gh
description "pre configured Typical Client Density rfprofile for 2.4gh radio"
no shutdown
ap dot11 24ghz rate RATE_12M supported
ap dot11 24ghz rate RATE_24M supported
ap dot11 24ghz rate RATE_6M supported
ap dot11 5ghz rf-profile Low_Client_Density_rf_5gh
coverage level 2
description "pre configured Low Client Density rfprofile for 5gh radio"
rate RATE_24M mandatory
rate RATE_6M mandatory
tx-power v1 threshold -60
no shutdown
ap dot11 5ghz rf-profile High_Client_Density_rf_5gh
description "pre configured High Client Density rfprofile for 5gh radio"
rate RATE_9M disable
tx-power min 7
no shutdown
ap dot11 5ghz rf-profile Typical_Client_Density_rf_5gh
description "pre configured Typical Density rfprofile for 5gh radio"
no shutdown
ap dot11 5ghz rate RATE_12M mandatory
ap dot11 5ghz rate RATE_24M mandatory
ap dot11 5ghz rate RATE_6M mandatory
ap tag-source-priority 2 source filter
ap tag-source-priority 3 source ap
ap profile default-ap-profile
description "default ap profile"
trapflags ap crash
trapflags ap noradiocards
trapflags ap register
end
Cisco IOS XE Software, Version 17.03.04
Cisco IOS Software [Amsterdam], Catalyst L3 Switch Software (CAT9K_IOSXE), Version 17.3.4, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2021 by Cisco Systems, Inc.
Compiled Sat 03-Jul-21 01:55 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2021 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
BOOTLDR: System Bootstrap, Version 17.3.1r[FC2], RELEASE SOFTWARE (P)
INU-COLL_CORE-SW-01 uptime is 16 hours, 37 minutes
Uptime for this control processor is 16 hours, 40 minutes
System returned to ROM by PowerOn
System image file is "bootflash:packages.conf"
Last reload reason: PowerOn
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Technology Package License Information:
Technology-package Technology-package
Current Type Next reboot
network-advantage Smart License network-advantage
dna-advantage Subscription Smart License dna-advantage
AIR License Level: AIR DNA Advantage
Next reload AIR license Level: AIR DNA Advantage
Active PKG Information:
State (St): C - Committed, U - Uncommitted
Type Package_Type Version St Filename
PKG C9800-Wirele 17.03.04. C C9800-SW-iosxe-wlc.17.03.04.SPA.bin
Smart Licensing Status: Registration Not Applicable/Not Applicable
cisco C9500-48Y4C (X86) processor with 2904230K/6147K bytes of memory.
Processor board ID FDO25501DT7
52 Virtual Ethernet interfaces
96 TwentyFive Gigabit Ethernet interfaces
8 Hundred Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
16002876K bytes of physical memory.
11161600K bytes of Bootflash at bootflash:.
11161600K bytes of Bootflash at bootflash-2:.
1638400K bytes of Crash Files at crashinfo:.
1638400K bytes of Crash Files at crashinfo-2:.
Base Ethernet MAC Address : 14:a2:a0:e7:93:00
Motherboard Assembly Number : 4873
Motherboard Serial Number : FDO25501DT7
Model Revision Number : V02
Motherboard Revision Number : 5
Model Number : C9500-48Y4C
System Serial Number : FDO25501DT7
Switch 02
Base Ethernet MAC Address : 14:a2:a0:e7:a5:c0
Motherboard Serial Number : FDO25501DSV
System Serial Number : FDO25501DSV
I follow other thread,  can you do
show inventory<<- check the VID of both SW is it same or not
INU-COLL_CORE-SW-01#show inventory
NAME: "Switch 1 Chassis", DESCR: "Cisco Catalyst 9500 Series Chassis"
PID: C9500-48Y4C , VID: V04 , SN: FDO25501DT7
NAME: "Switch 1 Power Supply Module 1", DESCR: "Cisco Catalyst 9500 Series 650W AC Power Supply"
PID: C9K-PWR-650WAC-R , VID: V01 , SN: DCI255021NC
NAME: "Switch 1 Fan Tray 0", DESCR: "Cisco Catalyst 9500 Series Fan Tray"
PID: C9K-T1-FANTRAY , VID: , SN:
NAME: "Switch 1 Fan Tray 1", DESCR: "Cisco Catalyst 9500 Series Fan Tray"
NAME: "Switch 1 Slot 1 Supervisor", DESCR: "Cisco Catalyst 9500 Series Router"
NAME: "TwentyFiveGigE1/0/1", DESCR: "GE LX"
PID: GLC-LH-SMD , VID: V01 , SN: OPM241209MX
NAME: "TwentyFiveGigE1/0/2", DESCR: "GE LX"
PID: GLC-LH-SMD , VID: V01 , SN: OPM241209XG
NAME: "TwentyFiveGigE1/0/3", DESCR: "SFP+ 10GBASE-LR"
PID: SFP-10G-LR , VID: V04 , SN: CZX50120271
NAME: "TwentyFiveGigE1/0/4", DESCR: "SFP+ 10GBASE-LR"
PID: SFP-10G-LR , VID: V04 , SN: CZX50120222
NAME: "TwentyFiveGigE1/0/5", DESCR: "SFP+ 10GBASE-LR"
PID: SFP-10G-LR , VID: V04 , SN: CZX50120205
NAME: "TwentyFiveGigE1/0/6", DESCR: "SFP+ 10GBASE-LR"
PID: SFP-10G-LR , VID: V04 , SN: CZX50120027
NAME: "TwentyFiveGigE1/0/7", DESCR: "SFP+ 10GBASE-LR"
PID: SFP-10G-LR , VID: V04 , SN: CZX50120024
NAME: "TwentyFiveGigE1/0/8", DESCR: "SFP+ 10GBASE-LR"
PID: SFP-10G-LR , VID: V04 , SN: CZX50120249
NAME: "TwentyFiveGigE1/0/9", DESCR: "SFP+ 10GBASE-LR"
PID: SFP-10G-LR , VID: V04 , SN: CZX50120284
NAME: "TwentyFiveGigE1/0/10", DESCR: "SFP+ 10GBASE-LR"
PID: SFP-10G-LR , VID: V04 , SN: CZX50120281
NAME: "TwentyFiveGigE1/0/11", DESCR: "SFP+ 10GBASE-LR"
PID: SFP-10G-LR , VID: V04 , SN: CZX50120286
NAME: "TwentyFiveGigE1/0/13", DESCR: "SFP+ 10GBASE-LR"
PID: SFP-10G-LR , VID: V04 , SN: CZX50120283
NAME: "TwentyFiveGigE1/0/14", DESCR: "SFP+ 10GBASE-LR"
PID: SFP-10G-LR , VID: V04 , SN: CZX50120219
NAME: "TwentyFiveGigE1/0/15", DESCR: "SFP+ 10GBASE-LR"
PID: SFP-10G-LR , VID: V04 , SN: CZX50120290
NAME: "TwentyFiveGigE1/0/16", DESCR: "SFP+ 10GBASE-LR"
PID: SFP-10G-LR , VID: V04 , SN: CZX50120282
NAME: "TwentyFiveGigE1/0/17", DESCR: "GE LX"
PID: GLC-LH-SMD , VID: V01 , SN: OPM241209BS
NAME: "TwentyFiveGigE1/0/18", DESCR: "SFP+ 10GBASE-LR"
PID: SFP-10G-LR , VID: V04 , SN: CZX50120021
NAME: "TwentyFiveGigE1/0/19", DESCR: "SFP+ 10GBASE-LR"
PID: SFP-10G-LR , VID: V04 , SN: CZX50120232
NAME: "TwentyFiveGigE1/0/20", DESCR: "SFP+ 10GBASE-LR"
PID: SFP-10G-LR , VID: V04 , SN: CZX50120278
NAME: "TwentyFiveGigE1/0/21", DESCR: "SFP+ 10GBASE-LR"
PID: SFP-10G-LR , VID: V04 , SN: CZX50120230
NAME: "TwentyFiveGigE1/0/22", DESCR: "SFP+ 10GBASE-LR"
PID: SFP-10G-LR , VID: V04 , SN: CZX50120028
NAME: "TwentyFiveGigE1/0/23", DESCR: "SFP+ 10GBASE-LR"
PID: SFP-10G-LR , VID: V04 , SN: CZX50120280
NAME: "TwentyFiveGigE1/0/24", DESCR: "SFP+ 10GBASE-LR"
PID: SFP-10G-LR , VID: V04 , SN: CZX50120279
NAME: "TwentyFiveGigE1/0/25", DESCR: "SFP+ 10GBASE-LR"
PID: SFP-10G-LR , VID: V04 , SN: CZX50120293
NAME: "TwentyFiveGigE1/0/26", DESCR: "SFP+ 10GBASE-LR"
PID: SFP-10G-LR , VID: V04 , SN: CZX50120237
NAME: "TwentyFiveGigE1/0/27", DESCR: "SFP+ 10GBASE-LR"
PID: SFP-10G-LR , VID: V04 , SN: CZX50120277
NAME: "TwentyFiveGigE1/0/28", DESCR: "SFP+ 10GBASE-LR"
PID: SFP-10G-LR , VID: V04 , SN: CZX50120253
NAME: "TwentyFiveGigE1/0/29", DESCR: "SFP+ 10GBASE-LR"
PID: SFP-10G-LR , VID: V04 , SN: CZX50120252
NAME: "TwentyFiveGigE1/0/30", DESCR: "SFP+ 10GBASE-LR"
PID: SFP-10G-LR , VID: V04 , SN: CZX50120234
NAME: "TwentyFiveGigE1/0/31", DESCR: "SFP+ 10GBASE-LR"
PID: SFP-10G-LR , VID: V04 , SN: CZX50120251
NAME: "TwentyFiveGigE1/0/32", DESCR: "SFP+ 10GBASE-LR"
PID: SFP-10G-LR , VID: V04 , SN: CZX50120023
NAME: "TwentyFiveGigE1/0/33", DESCR: "GE LX"
PID: GLC-LH-SMD , VID: V01 , SN: OPM23050SG3
NAME: "TwentyFiveGigE1/0/34", DESCR: "SFP+ 10GBASE-LR"
PID: SFP-10G-LR , VID: V04 , SN: CZX50120263
NAME: "TwentyFiveGigE1/0/35", DESCR: "GE LX"
PID: GLC-LH-SM , VID: , SN: 1311063105
NAME: "TwentyFiveGigE1/0/36", DESCR: "GE LX"
PID: GLC-LH-SMD , VID: V01 , SN: OPM241209XA
NAME: "TwentyFiveGigE1/0/37", DESCR: "SFP+ 10GBASE-LR"
PID: SFP-10G-LR , VID: V04 , SN: CZX50120236
NAME: "TwentyFiveGigE1/0/38", DESCR: "SFP+ 10GBASE-LR"
PID: SFP-10G-LR , VID: V04 , SN: CZX50120221
NAME: "TwentyFiveGigE1/0/39", DESCR: "GE LX"
PID: GLC-LH-SMD , VID: V01 , SN: OPM24120A60
NAME: "TwentyFiveGigE1/0/40", DESCR: "GE LX"
PID: GLC-LH-SMD , VID: V01 , SN: FNS17010115
NAME: "TwentyFiveGigE1/0/41", DESCR: "SFP+ 10GBASE-LR"
PID: SFP-10G-LR , VID: V04 , SN: CZX50120269
NAME: "TwentyFiveGigE1/0/42", DESCR: "SFP+ 10GBASE-LR"
PID: SFP-10G-LR , VID: V04 , SN: CZX50120257
NAME: "TwentyFiveGigE1/0/43", DESCR: "GE ZX"
PID: GLC-LH-SMD , VID: V01 , SN: CYXF1000003
NAME: "TwentyFiveGigE1/0/44", DESCR: "GE LX"
PID: GLC-LH-SMD , VID: V01 , SN: OPM241209BT
NAME: "TwentyFiveGigE1/0/46", DESCR: "SFP+ 10GBASE-LR"
PID: SFP-10G-LR , VID: V04 , SN: CZX50120267
NAME: "TwentyFiveGigE1/0/47", DESCR: "SFP+ 10GBASE-LR"
PID: SFP-10G-LR , VID: V04 , SN: CZX50120246
NAME: "TwentyFiveGigE1/0/48", DESCR: "SFP+ 10GBASE-LR"
PID: SFP-10G-LR , VID: V04 , SN: CZX50120248
NAME: "Switch 2 Chassis", DESCR: "Cisco Catalyst 9500 Series Chassis"
PID: C9500-48Y4C , VID: V04 , SN: FDO25501DSV
NAME: "Switch 2 Power Supply Module 1", DESCR: "Cisco Catalyst 9500 Series 650W AC Power Supply"
PID: C9K-PWR-650WAC-R , VID: V01 , SN: DCI255021NU
NAME: "Switch 2 Fan Tray 0", DESCR: "Cisco Catalyst 9500 Series Fan Tray"
NAME: "Switch 2 Fan Tray 1", DESCR: "Cisco Catalyst 9500 Series Fan Tray"
NAME: "Switch 2 Slot 1 Supervisor", DESCR: "Cisco Catalyst 9500 Series Router"
NAME: "TwentyFiveGigE2/0/1", DESCR: "GE LX"
PID: GLC-LH-SMD , VID: V01 , SN: FNS17520WHC
NAME: "TwentyFiveGigE2/0/2", DESCR: "GE LX"
PID: GLC-LH-SMD , VID: V01 , SN: OPM241209N7
NAME: "TwentyFiveGigE2/0/3", DESCR: "SFP+ 10GBASE-LR"
PID: SFP-10G-LR , VID: V04 , SN: CZX50120244
NAME: "TwentyFiveGigE2/0/4", DESCR: "SFP+ 10GBASE-LR"
PID: SFP-10G-LR , VID: V04 , SN: CZX50120241
NAME: "TwentyFiveGigE2/0/5", DESCR: "SFP+ 10GBASE-LR"
PID: SFP-10G-LR , VID: V04 , SN: CZX50120227
NAME: "TwentyFiveGigE2/0/6", DESCR: "SFP+ 10GBASE-LR"
PID: SFP-10G-LR , VID: V04 , SN: CZX50120242
NAME: "TwentyFiveGigE2/0/7", DESCR: "SFP+ 10GBASE-LR"
PID: SFP-10G-LR , VID: V04 , SN: CZX50120210
NAME: "TwentyFiveGigE2/0/8", DESCR: "SFP+ 10GBASE-LR"
PID: SFP-10G-LR , VID: V04 , SN: CZX50120209
NAME: "TwentyFiveGigE2/0/9", DESCR: "SFP+ 10GBASE-LR"
PID: SFP-10G-LR , VID: V04 , SN: CZX50120208
NAME: "TwentyFiveGigE2/0/10", DESCR: "SFP+ 10GBASE-LR"
PID: SFP-10G-LR , VID: V04 , SN: CZX50120207
NAME: "TwentyFiveGigE2/0/11", DESCR: "SFP+ 10GBASE-LR"
PID: SFP-10G-LR , VID: V04 , SN: CZX50120206
NAME: "TwentyFiveGigE2/0/12", DESCR: "SFP+ 10GBASE-LR"
PID: SFP-10G-LR , VID: V04 , SN: CZX50120201
NAME: "TwentyFiveGigE2/0/13", DESCR: "SFP+ 10GBASE-LR"
PID: SFP-10G-LR , VID: V04 , SN: CZX50120203
NAME: "TwentyFiveGigE2/0/14", DESCR: "SFP+ 10GBASE-LR"
PID: SFP-10G-LR , VID: V04 , SN: CZX50120294
NAME: "TwentyFiveGigE2/0/15", DESCR: "SFP+ 10GBASE-LR"
PID: SFP-10G-LR , VID: V04 , SN: CZX50120299
NAME: "TwentyFiveGigE2/0/16", DESCR: "SFP+ 10GBASE-LR"
PID: SFP-10G-LR , VID: V04 , SN: CZX50120204
NAME: "TwentyFiveGigE2/0/19", DESCR: "GE LX"
PID: GLC-LH-SMD , VID: V01 , SN: OPM241209M2
NAME: "TwentyFiveGigE2/0/22", DESCR: "SFP+ 10GBASE-LR"
PID: SFP-10G-LR , VID: V04 , SN: CZX50120243
NAME: "TwentyFiveGigE2/0/23", DESCR: "SFP+ 10GBASE-LR"
PID: SFP-10G-LR , VID: V04 , SN: CZX50120300
NAME: "TwentyFiveGigE2/0/24", DESCR: "SFP+ 10GBASE-LR"
PID: SFP-10G-LR , VID: V04 , SN: CZX50120298
NAME: "TwentyFiveGigE2/0/25", DESCR: "SFP+ 10GBASE-LR"
PID: SFP-10G-LR , VID: V04 , SN: CZX50120296
NAME: "TwentyFiveGigE2/0/26", DESCR: "SFP+ 10GBASE-LR"
PID: SFP-10G-LR , VID: V04 , SN: CZX50120297
NAME: "TwentyFiveGigE2/0/28", DESCR: "SFP+ 10GBASE-LR"
PID: SFP-10G-LR , VID: V04 , SN: CZX50120272
NAME: "TwentyFiveGigE2/0/46", DESCR: "SFP+ 10GBASE-LR"
PID: SFP-10G-LR , VID: V04 , SN: CZX50120264
NAME: "TwentyFiveGigE2/0/47", DESCR: "SFP+ 10GBASE-LR"
PID: SFP-10G-LR , VID: V04 , SN: CZX50120247
NAME: "TwentyFiveGigE2/0/48", DESCR: "SFP+ 10GBASE-LR"
PID: SFP-10G-LR , VID: V04 , SN: CZX50120289
M02@rt37
Hello @fikadu abdisa,
Do yo have checked the logs on core switch for any error messages related to the affected ports ?
Best regards
