Bookmark
Subscribe
2362
Cisco ASA BGP with BIRD peering
kerstin-534
have somebody experince with ASA 9.2 or 9.3 BGP implementation.  Cannot get it working with BIRD as peer.
Get an malformed AS_PATH
bird> show pro bgp2
name     proto    table    state  since       info
bgp2     BGP      master   start  11:26:26    Idle          BGP Error: Malformed AS_PATH
protocol bgp bgp2 {
        description "ISP";
        local as 35000;
        neighbor 192.168.0.12 as 15000;
        error wait time 9,16;
        debug all;
        keepalive time 20;
        hold time 60;
        password "cisco";
        export where source=RTS_STATIC;
        export where source=RTS_DEVICE;
ASA:
router bgp 15000
 bgp log-neighbor-changes
 address-family ipv4 unicast
  neighbor 192.168.0.8 remote-as 35000
  neighbor 192.168.0.8 password *****
  neighbor 192.168.0.8 version 4
  neighbor 192.168.0.8 activate
  neighbor 192.168.0.8 filter-list 1 out
  redistribute connected route-map isp-out
  no auto-summary
  no synchronization
 exit-address-family
Peering with BIRD works with IOS
Feedback appreciated.
br Fritz
Akash Agrawal
from RFC 4271
 The AS_PATH attribute is checked for syntactic correctness.  If the
   path is syntactically incorrect, then the Error Subcode MUST be set
   to Malformed AS_PATH.
   If the UPDATE message is received from an external peer, the local
   system MAY check whether the leftmost (with respect to the position
   of octets in the protocol message) AS in the AS_PATH attribute is
   equal to the autonomous system number of the peer that sent the
   message.  If the check determines this is not the case, the Error
   Subcode MUST be set to Malformed AS_PATH.
Please check if you can take wireshark capture or any debug which can tell why as-path is getting corrupted and to what value.
One similar case from google search
http://marc.info/?l=bird-users&m=124515982116091&w=2
Akash
IOS uses 4 octet capability in the announcement and 4 octets (AS4) in the Update message.
This works
Internet Protocol Version 4, Src: 192.168.0.50 (192.168.0.50), Dst: 192.168.0.8 (192.168.0.8)
Transmission Control Protocol, Src Port: 33030 (33030), Dst Port: 179 (179), Seq: 3514092093, Ack: 3010016013, Len: 57
Border Gateway Protocol - OPEN Message
    Marker: ffffffffffffffffffffffffffffffff
    Length: 57
    Type: OPEN Message (1)
    Version: 4
    My AS: 20000
    Hold Time: 180
    BGP Identifier: 192.168.0.50 (192.168.0.50)
    Optional Parameters Length: 28
    Optional Parameters
        Optional Parameter: Capability
            Parameter Type: Capability (2)
            Parameter Length: 6
            Capability: Multiprotocol extensions capability
                Type: Multiprotocol extensions capability (1)
                Length: 4
                AFI: IPv4 (1)
                Reserved: 00
                SAFI: Unicast (1)
            Parameter Length: 2
            Capability: Route refresh capability
                Type: Route refresh capability (128)
                Length: 0
            Parameter Length: 2
                Type: Route refresh capability (2)
                Length: 0
            Parameter Length: 2
            Capability: Enhanced route refresh capability
                Type: Enhanced route refresh capability (70)
                Length: 0
            Parameter Length: 6
            Capability: Support for 4-octet AS number capability
                Type: Support for 4-octet AS number capability (65)
                Length: 4
                AS Number: 20000
Transmission Control Protocol, Src Port: 33030 (33030), Dst Port: 179 (179), Seq: 3514092188, Ack: 3010016081, Len: 77
Border Gateway Protocol - UPDATE Message
    Length: 54
    Type: UPDATE Message (2)
    Withdrawn Routes Length: 0
    Total Path Attribute Length: 27
    Path attributes
        Path Attribut - ORIGIN: INCOMPLETE
            Flags: 0x40: Well-known, Transitive, Complete
                0... .... = Optional: Well-known
                .1.. .... = Transitive: Transitive
                ..0. .... = Partial: Complete
                ...0 .... = Length: Regular length
            Type Code: ORIGIN (1)
            Length: 1
            Origin: INCOMPLETE (2)
        Path Attribut - AS_PATH: 20000
            Type Code: AS_PATH (2)
            Length: 6
            AS Path segment: 20000
                Segment type: AS_SEQUENCE (2)
                Segment length (number of ASN): 1
                AS4: 20000
        Path Attribut - NEXT_HOP: 192.168.0.50
            Type Code: NEXT_HOP (3)
            Length: 4
            Next hop: 192.168.0.50 (192.168.0.50)
        Path Attribut - MULTI_EXIT_DISC: 0
            Flags: 0x80: Optional, Non-transitive, Complete
                1... .... = Optional: Optional
                .0.. .... = Transitive: Non-transitive
            Type Code: MULTI_EXIT_DISC (4)
            Length: 4
            Multiple exit discriminator: 0
    Network Layer Reachability Information (NLRI)
        20.20.0.0/22
            NLRI prefix length: 22
            NLRI prefix: 20.20.0.0 (20.20.0.0)
    Length: 23
    Total Path Attribute Length: 0
ASA anounce 4 Octet capability for AS numbers and 4 byte AS in OPEN message.
ASA uses AS2 attribute in Updates
this works not
Cisco Adaptive Security Appliance Software Version 9.2(2)4
Internet Protocol Version 4, Src: 192.168.0.12 (192.168.0.12), Dst: 192.168.0.8 (192.168.0.8)
Transmission Control Protocol, Src Port: 179 (179), Dst Port: 46026 (46026), Seq: 364474835, Ack: 3117933697, Len: 53
    Length: 53
    Version: 4
    My AS: 15000
    Hold Time: 180
    BGP Identifier: 192.168.2.12 (192.168.2.12)
    Optional Parameters Length: 24
    Optional Parameters
            Parameter Length: 6
                Length: 4
                AFI: IPv4 (1)
                Reserved: 00
                SAFI: Unicast (1)
            Parameter Length: 2
                Length: 0
            Parameter Length: 2
                Length: 0
            Parameter Length: 6
                Length: 4
                AS Number: 15000
Transmission Control Protocol, Src Port: 179 (179), Dst Port: 46026 (46026), Seq: 364474926, Ack: 3117933739, Len: 75
    Length: 52
    Total Path Attribute Length: 25
    Path attributes
            Length: 1
        Path Attribut - AS_PATH: 15000
            Length: 4
            AS Path segment: 15000
                AS2: 15000
        Path Attribut - NEXT_HOP: 192.168.0.12
            Length: 4
            Next hop: 192.168.0.12 (192.168.0.12)
            Length: 4
        192.168.1.0/24
            NLRI prefix length: 24
            NLRI prefix: 192.168.1.0 (192.168.1.0)
    Length: 23
