06-01-2016 12:42 AM - edited 03-08-2019 06:01 AM
hi. we have Cisco ASR 1004 using IOS-XE Software (PPC_LINUX_IOSD-ADVENTERPRISEK9-M), Version 15.1(3)S2
I am trying to add another netflow destination but got an error. is there a way to increase destination for netflow, or is this a standard with max of 2 for netflow destination? Thanks in advance.
06-01-2016 01:35 AM
that's a limitation for the version netflow from what I remember
I think v9 can only support 1 destination as well under the exporter in ios-xe
2 redundant export destinations are allowed for
version 5
If you try to configure more, you will get:
“Exceeded maximum export destinations”
checked a couple other platforms there same issue only 2 max , 6500s,38s,37s all the same
06-01-2016 02:00 AM
we are using ip flow-export version 9, ok so there is really no work around for this. thank you.
