Cisco bandwidth throttling
jaybak105
I need to be able to control the through put on an interface by sub-interfaces.  Here is the situation:
Fa0/0 - Outside interface (DHCP client from ISP)
Fa0/1 - Inside interface to vlan'd switch
Fa0/1.1 - VLAN1 for VIP users (no throttling, DHCP Pool 192.168.1.50-100)
Fa0/1.2 - VLAN2 for non-VIP users (throttling enabled, DHCP Pool 192.168.2.50-100)
If there is traffic from both VLANs at the same time, VLAN2 must be throttled down to 25%.  If there is no VLAN1 traffic then VLAN2 can enjoy full speed until the VIP users need it.
Question 1: What Cisco Router model can support this?
Question 2: What programming is need to accomplish this?
Thanks for the help...
Jay
Ruben Cocheno
You will need a Branch router but depends what is the capacity vs number users
http://www.cisco.com/c/en/us/products/routers/index.html
The features to achieve your requirements are:
Even the lowest models do subinterfaces, DHCP, NAT and filtering
QoS with LLQ
The rigth model depends how many users and the capacity you will need for the next 2/3 years. Probably you will need a switch as well
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
Hello.
I guess you are talking about limiting Internet traffic to VLAN2, if VLAN1 needs more bandwidth.
If so, then you need some solution to apply QoS on inbound traffic. None of Cisco branch routers has this functionality (but you could try sustitute it with some available feature).
Gents....
I was reading this post:
https://supportforums.cisco.com/discussion/10956426/limiting-bandwidth-cisco-router-possible-1800-series
It is close to what I need but they have an upper limit set of inbound traffic.  My traffic will change depending on the ISP that supplies it.
I know I need (and have a) switch for separating the VLANs.  As for user numbers...that will vary around 12-24 ish total.
So I have a brand new 2901 router and switch.  The vlans are configured but during the config of the router, the command "bandwidth" was not supported.  Any thoughts?
