cisco c4500e with sup-7L
info0000284
hi mates,
i have one cisco catalyst 4506e with sup-7L and LAN base Ios.
i need ospf command but i don't know i need ip base ios or enterprise ios.
the cisco must replace one alpine switch with this ospf command
configure ospf add vlan "cs-fdi" area 0.0.0.0 link-type broadcast
configure ospf add vlan "dati" area 0.0.0.0 link-type broadcast
configure ospf add vlan "fonia" area 0.0.0.0 link-type broadcast
just ip base ios is ok for this command??
thx a lot
Luca
Seth Bjorn
Yes IP Base license will work for that. Obviously the commands will be different.
To verify what features you need work with which licenses, check this link:
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/release/note/OL_23474.html
Seth Bjorn
