Cisco C9300-24S switch incorrectly configures port speed for SFP?
jeffreyfarrell
I've got 14 GLC-GE-100FX SFP's in a 9300 switch. Ports 1-10 with these SFP's have the correct port speed setting (100Mb/s), but ports 11-14 have have the incorrect port setting of 1000Mb/s. I cannot manually change the port speed. What are my options?
Switch#show interface status
Port Name Status Vlan Duplex Speed Type
Gi1/0/1 Short Tape notconnect 1 full 100 100BaseFX SFP
Gi1/0/2 Measuring Roll notconnect 1 full 100 100BaseFX SFP
Gi1/0/3 Long Tape notconnect 1 full 100 100BaseFX SFP
Gi1/0/4 Test Section notconnect 1 full 100 100BaseFX SFP
Gi1/0/5 Cutter notconnect 1 full 100 100BaseFX SFP
Gi1/0/6 Cooler notconnect 1 full 100 100BaseFX SFP
Gi1/0/7 **bleep** notconnect 1 full 100 100BaseFX SFP
Gi1/0/8 Outlet notconnect 1 full 100 100BaseFX SFP
Gi1/0/9 Tape connected 1 full 100 100BaseFX SFP
Gi1/0/10 Inlet notconnect 1 full 100 100BaseFX SFP
Gi1/0/11 connected 1 full 1000 100BaseFX SFP
Gi1/0/12 connected 1 full 1000 100BaseFX SFP
Gi1/0/13 connected 1 full 1000 100BaseFX SFP
Gi1/0/14 connected 1 full 1000 100BaseFX SFP
Gi1/0/15 notconnect 1 auto auto 10/100/1000BaseTX SFP
Gi1/0/16 Avtron to PLC Netw notconnect 1 auto auto 10/100/1000BaseTX SFP
Gi1/0/17 Drive Room PC notconnect 1 auto auto 10/100/1000BaseTX SFP
Gi1/0/18 Drive Room PC notconnect 1 auto auto 10/100/1000BaseTX SFP
Gi1/0/19 Drive Room PC notconnect 1 auto auto 10/100/1000BaseTX SFP
Gi1/0/20 Couch notconnect 1 auto auto 10/100/1000BaseTX SFP
Gi1/0/21 1st Press notconnect 1 auto auto 10/100/1000BaseTX SFP
Gi1/0/22 2nd Press notconnect 1 auto auto 10/100/1000BaseTX SFP
Gi1/0/23 Pre-dryer notconnect 1 auto auto 10/100/1000BaseTX SFP
Switch#show interface gi1/0/11
GigabitEthernet1/0/11 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 04bd.9775.450b (bia 04bd.9775.450b)
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Keepalive not set
Full-duplex, 1000Mb/s, link type is auto, media type is 100BaseFX SFP
input flow-control is on, output flow-control is unsupported
Last input never, output 00:00:32, output hang never
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 multicasts)
0 watchdog, 0 multicast, 0 pause input
146 packets output, 57224 bytes, 0 underruns
Output 20 broadcasts (0 multicasts)
0 output errors, 0 collisions, 2 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
Switch#show interface gi1/0/11 capabilities
Model: C9300-24S
Type: 100BaseFX SFP
Speed: 100
Duplex: full,half
Trunk encap. type: 802.1Q
Trunk mode: on,off,desirable,nonegotiate
Channel: yes
Broadcast suppression: percentage(0-100)
Unicast suppression: percentage(0-100)
Multicast suppression: percentage(0-100)
Flowcontrol: rx-(off,on,desired),tx-(none)
Fast Start: yes
QoS scheduling: rx-(not configurable on per port basis),
tx-(2p6q3t)
CoS rewrite: yes
ToS rewrite: yes
UDLD: yes
Inline power: no
SPAN: source/destination
PortSecure: yes
Dot1x: yes
Breakout Support: not applicable
15 Replies 15
I am using third party curvature optics and cisco optics. The problem seems to come at random with both.
