Cisco catalyst 2960 & 3560
xatuute
 am working in small company that have 4 switches all ready configured from old employer, i wanna to access the switches web interface then ask me user and password can i access it without reset coz i don't want to lose the configuration
lpersing
Hello, Do you know if the web interface is enabled? That would be the first place to start I would imagine.
mostafamakwar99
get to Rommon switch:
 Enter these commands into the switch
  • switch: flash _init
  • switch: load_helper
  • switch: dir flash:Directory of flash:
  • 13 drwx   192 Mar 01 1993 22:30:48 c2960-mz-124-0.0.53
  • 11 -rwx   5825 Mar 01 1993 22:31:59 config.text
  • 18 -rwx   720 Mar 01 1993 02:21:30 vlan.da
  • switch: rename flash:config.text flash:config.text.old
  • switch: boot
Once the switch reboots, answer NO to “Would you like to enter system configuration dialog? [Yes/No]:
 Get into the privilege prompt.
  • Switch>enable
  • Switch#rename flash:config.text.old flash:config.text
  • Switch#copy flash:config.text system:running-config
  • Source filename [config.text]?
  • Destination filename [running-config]?
  • Press Enter to copy
 Get into global configuration
  • Switch#conf t
  • Switch (config)#enable secret password
  • Enter the password you would like
 Return to Privilege mode and save your config
  • Switch (config)#exit
  • Switch#copy run start
