Cisco catalyst 3560G switch
haristufail
hi everyone,
i have cisco 3560G switch.
i am facing following problem. plz anyboby suggest me.
what is problem, thanks in advance.
Base ethernet MAC Address: 00:14:f2:09:47:00
Xmodem file system is available.
The password-recovery mechanism is enabled.
Initializing Flash...
flashfs[0]: 361 files, 7 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 32514048
flashfs[0]: Bytes used: 2469376
flashfs[0]: Bytes available: 30044672
flashfs[0]: flashfs fsck took 6 seconds.
...done Initializing Flash.
Boot Sector Filesystem (bs) installed, fsid: 3
done.
Loading "flash:c3560-ipbase-mz.122-25.SEB2/c3560-ipbase-mz.122-25.SEB2.bin"...fl
ash:c3560-ipbase-mz.122-25.SEB2/c3560-ipbase-mz.122-25.SEB2.bin: short read: bad
mzip file
Error loading "flash:c3560-ipbase-mz.122-25.SEB2/c3560-ipbase-mz.122-25.SEB2.bin
Interrupt within 5 seconds to abort boot process.
Boot process failed...
The system is unable to boot automatically. The BOOT
environment variable needs to be set to a bootable
image.
switch:
Philip D'Ath
You'll need to download a new image (which requires a Cisco maintenance contract like SmartNet) and do a ROMMON image recovery.
http://www.cisco.com/c/en/us/support/docs/switches/catalyst-2950-series-switches/41845-192.html
