Cisco Catalyst 3750x series switch
sjarasan
I have cisco catalyst 3750x 24 port switch series switch, and the switch has C3KX-NM-10G module.
Problem:
I have connected fibre optic in SFP+ transceiver on G2/TE1 (Uplink).  After 7 to 8 hours, the SFP+ transceiver stops working (Lights off state). There is no data transmission.  If I removed the SFP+ transceiver and reinserted, then the connection coming back to normal (Lights Blink). The data transmission starts again. This is happening daily.
Anybody has an idea about How to troubleshoot the switch.
12 Replies 12
marce1000
          - Check the logs when this happens, preferably use a syslog-server. for flexible logging monitoring
 M.
Reza Sharifi
Does show interface show any error messages? Also, try replacing the fiber patch cord connected to the optic, if that does not help, replace the SFP+.
While Checking the logs I found this error.
Tx power low alarm and Rx power low alarm (Is this an SFP transceiver issue)
ASW-G-L09-001#show logging
Log Buffer (8192 bytes):
D_VIOLATION: Te1/1/1: Tx power low alarm; Operating value: -40.0 dBm, Threshold value: -11.3 dBm.
019031: May 18 12:27:34.016: %PLATFORM_ENV-1-FRU_PS_ACCESS: FRU Power Supply is not responding
019032: May 18 12:32:21.988: %SFF8472-5-THRESHOLD_VIOLATION: Te1/1/1: Tx power low alarm; Operating value: -40.0 dBm, Threshold value: -11.3 dBm.
019071: May 18 14:48:36.536: %PLATFORM_ENV-1-FRU_PS_ACCESS: FRU Power Supply is not responding
019072: May 18 14:52:25.536: %SFF8472-5-THRESHOLD_VIOLATION: Te1/1/1: Rx power low alarm; Operating value: -40.0 dBm, Threshold value: -13.9 dBm.
019073: May 18 14:52:25.536: %SFF8472-5-THRESHOLD_VIOLATION: Te1/1/1: Tx power low alarm; Operating value: -40.0 dBm, Threshold value: -11.3 dBm.
019074: May 18 14:52:57.740: %LINK-3-UPDOWN: Interface TenGigabitEthernet1/1/1, changed state to up
019075: May 18 14:52:59.770: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/1/1, changed state to up
019076: May 18 14:53:28.812: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan10, changed state to up
Hello
Try upgrading the IOS if the logs don’t show anything, We had the same issue not log back with a 3750x distribution stack , Nothing in logs to show the failing transceivers, Put it down to possible buggy ios, once we upgraded the stack all good haven’t had a fail since..
Kind Regards
Paul
Leo Laohoo
Post the complete output to the following commands:
sh version
sh logs
sh interface <SFP PORT> controll
ASW-G-L09-001#show interfaces te1/1/1 transceiver detail
ITU Channel not available (Wavelength not available),
Transceiver is internally calibrated.
High Alarm High Warn Low Warn Low Alarm
Temperature Threshold Threshold Threshold Threshold
Port (Celsius) (Celsius) (Celsius) (Celsius) (Celsius)
Te1/1/1 29.4 75.0 70.0 0.0 -5.0
Voltage Threshold Threshold Threshold Threshold
Port (Volts) (Volts) (Volts) (Volts) (Volts)
Te1/1/1 3.30 3.63 3.46 3.13 2.97
Optical High Alarm High Warn Low Warn Low Alarm
Transmit Power Threshold Threshold Threshold Threshold
Port (dBm) (dBm) (dBm) (dBm) (dBm)
Te1/1/1 -2.2 1.7 -1.3 -7.3 -11.3
Receive Power Threshold Threshold Threshold Threshold
Te1/1/1 -3.7 2.0 -1.0 -9.9 -13.9
ASW-G-L09-001#show interface te1/1/1 controller
TenGigabitEthernet1/1/1 is up, line protocol is up (connected)
Hardware is Ten Gigabit Ethernet, address is b0aa.7720.729d (bia b0aa.7720.729d)
Description: Uplink to "CSW-G-L1-001"
MTU 1500 bytes, BW 10000000 Kbit/sec, DLY 10 usec,
Keepalive not set
Full-duplex, 10Gb/s, link type is auto, media type is SFP-10GBase-SR
input flow-control is off, output flow-control is unsupported
Last input 00:00:00, output 00:00:02, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 279000 bits/sec, 447 packets/sec
5 minute output rate 16000 bits/sec, 8 packets/sec
615261604 packets input, 48064745243 bytes, 0 no buffer
Received 599420455 broadcasts (525487445 multicasts)
5 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 525487445 multicast, 0 pause input
15469576 packets output, 3101889460 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
ASW-G-L09-001#show version
Cisco IOS Software, C3750E Software (C3750E-UNIVERSALK9NPE-M), Version 15.2(2)E, RELEASE SOFTWARE (fc3)
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : B0:AA:77:20:72:80
Motherboard assembly number : 73-12551-12
Motherboard serial number : FDO19090XL4
Model revision number : A0
Motherboard revision number : A0
Model number : WS-C3750X-24P-E
Daughterboard assembly number : 800-32727-03
Daughterboard serial number : FDO1909092D
System serial number : FDO1909P0PG
Top Assembly Part Number : 800-31325-09
Top Assembly Revision Number : F0
Version ID : V06
CLEI Code Number : CMMPP00DRA
Hardware Board Revision Number : 0x05
Switch Ports  Model                     SW Version  SW Image
* 1       30     WS-C3750X-24P   15.2(2)E       C3750E-UNIVERSALK9N
Keepalive not set
Ok
I want to see the same output taken from the other switch.
NOTE:  I'd seriously consider upgrading the firmware of the switch.  15.2(2)E is not a "stable" release.
johnlloyd_13
Level 9
Level 9
hi,
can you post the show inventory?
try to do: move to a spare port on the module card, swap SFP or clean the SFP with a foam swab/bud.
ASW-G-L09-001# show inventory
NAME: "1", DESCR: "WS-C3750X-24P"
PID: WS-C3750X-24P-E , VID: V06 , SN: FDO1909P0PG
NAME: "Switch 1 - Power Supply 2", DESCR: "FRU Power Supply"
PID: C3KX-PWR-715WAC , VID: V02D , SN: DCB1903A0DN
NAME: "Switch 1 - FRULink Slot 1 - FRULink Module", DESCR: "FRULink 10G ST Module"
PID: C3KX-NM-10G , VID: V01 , SN: FDO19090PVW
NAME: "TenGigabitEthernet1/1/2", DESCR: "SFP-10GBase-SR"
PID: SFP-10G-SR , VID: V03 , SN: JUR190601NE
